SketchSolver_ConstraintDistance.h
20#ifndef SketchSolver_ConstraintDistance_H_
21#define SketchSolver_ConstraintDistance_H_
23#include <SketchSolver_Constraint.h>
24
30{
31public:
33 SketchSolver_ConstraintDistance(ConstraintPtr theConstraint) :
34 SketchSolver_Constraint(theConstraint),
35 myIsSigned(false),
36 mySignValue(0.0)
37 {}
38
40 virtual void update();
41
43 virtual bool remove();
44
46 virtual void notify(const FeaturePtr& theFeature, PlaneGCSSolver_Update*);
47
48protected:
52 virtual void getAttributes(EntityWrapperPtr& theValue,
53 std::vector<EntityWrapperPtr>& theAttributes);
54
57 virtual void adjustConstraint();
58
59private:
60 void addConstraintsToKeepSign();
61 void removeConstraintsKeepingSign();
62
63private:
64 double myPrevValue;
65 bool myIsSigned;
66 GCSPointPtr myOddPoint;
67 double mySignValue;
68};
69
70#endif
Send events to listeners about changing a feature.
Definition: PlaneGCSSolver_Update.h:38
Convert distance constraint to SolveSpace structure.
Definition: SketchSolver_ConstraintDistance.h:30
This method is used in derived objects to check consistence of constraint.
Definition: SketchSolver_ConstraintDistance.cpp:192
Remove constraint.
Definition: SketchSolver_ConstraintDistance.cpp:261
virtual void getAttributes(EntityWrapperPtr &theValue, std::vector< EntityWrapperPtr > &theAttributes)
Generate list of attributes of constraint in order useful for constraints.
Definition: SketchSolver_ConstraintDistance.cpp:156
Update constraint.
Definition: SketchSolver_ConstraintDistance.cpp:215
Constructor based on SketchPlugin constraint.
Definition: SketchSolver_ConstraintDistance.h:33
virtual void notify(const FeaturePtr &theFeature, PlaneGCSSolver_Update *)
Notify this object about the feature is changed somewhere.
Definition: SketchSolver_ConstraintDistance.cpp:343
Converts SketchPlugin constraint to the constraint applicable for solver.
Definition: SketchSolver_Constraint.h:39
