SketchSolver_ConstraintDistance Class Reference
Convert distance constraint to SolveSpace structure. More...
#include <SketchSolver_ConstraintDistance.h>
Inheritance diagram for SketchSolver_ConstraintDistance:
 SketchSolver_ConstraintDistance (ConstraintPtr theConstraint)
 Constructor based on SketchPlugin constraint. More...
virtual void update ()
 Update constraint. More...
virtual bool remove ()
 Remove constraint. More...
virtual void notify (const FeaturePtr &theFeature, PlaneGCSSolver_Update *)
 Notify this object about the feature is changed somewhere. More...
void process (StoragePtr theStorage, bool theEvensBlocked)
 Initializes parameters and start constraint creation. More...
virtual void blockEvents (bool isBlocked)
 Block or unblock events from this constraint. More...
virtual SketchSolver_ConstraintType getType () const
 Returns the type of constraint. More...
const std::string & error () const
 Shows error message. More...
static SketchSolver_ConstraintType TYPE (ConstraintPtr theConstraint)
 Obtain a type of SketchPlugin constraint. More...
virtual void getAttributes (EntityWrapperPtr &theValue, std::vector< EntityWrapperPtr > &theAttributes)
 Generate list of attributes of constraint in order useful for constraints. More...
virtual void adjustConstraint ()
 This method is used in derived objects to check consistence of constraint. More...
virtual void process ()
 Converts SketchPlugin constraint to a list of solver's constraints. More...
void cleanErrorMsg ()
 Removes last error. More...
ConstraintPtr myBaseConstraint
 base SketchPlugin constraint More...
ConstraintWrapperPtr mySolverConstraint
 wrapper for PlaneGCS constraint More...
StoragePtr myStorage
 storage, which contains all information about entities and constraints More...
SketchSolver_ConstraintType myType
 type of constraint More...
std::list< EntityWrapperPtr > myAttributes
 attributes of constraint More...
std::string myErrorMsg
 error message More...
◆ SketchSolver_ConstraintDistance()
SketchSolver_ConstraintDistance::SketchSolver_ConstraintDistance ( ConstraintPtr  theConstraint)
◆ update()
void SketchSolver_ConstraintDistance::update ( )
Update constraint.
◆ remove()
bool SketchSolver_ConstraintDistance::remove ( )
Remove constraint.
◆ notify()
void SketchSolver_ConstraintDistance::notify ( const FeaturePtr &  theFeature,
◆ getAttributes()
void SketchSolver_ConstraintDistance::getAttributes ( EntityWrapperPtr &  theValue,
std::vector< EntityWrapperPtr > &  theAttributes
[out]theValuenumerical characteristic of constraint (e.g. distance)
[out]theAttributeslist of attributes to be filled
◆ adjustConstraint()
void SketchSolver_ConstraintDistance::adjustConstraint ( )
E.g. the distance between line and point may be signed.
◆ process() [1/2]
void SketchSolver_Constraint::process ( StoragePtr  theStorage,
theStorage[in] storage where to place new constraint
theEventsBlocked[in] all events from this constraint should be blocked
◆ process() [2/2]
◆ blockEvents()
void SketchSolver_Constraint::blockEvents ( bool  isBlocked)
◆ TYPE()
SketchSolver_ConstraintType SketchSolver_Constraint::TYPE ( ConstraintPtr  theConstraint)
◆ getType()
virtual SketchSolver_ConstraintType SketchSolver_Constraint::getType ( ) const
inlinevirtualinherited
◆ error()
const std::string & SketchSolver_Constraint::error ( ) const
◆ cleanErrorMsg()
void SketchSolver_Constraint::cleanErrorMsg ( )
inlineprotectedinherited
Removes last error.
◆ myBaseConstraint
ConstraintPtr SketchSolver_Constraint::myBaseConstraint
◆ mySolverConstraint
ConstraintWrapperPtr SketchSolver_Constraint::mySolverConstraint
◆ myStorage
StoragePtr SketchSolver_Constraint::myStorage
◆ myType
SketchSolver_ConstraintType SketchSolver_Constraint::myType
type of constraint
◆ myAttributes
std::list<EntityWrapperPtr> SketchSolver_Constraint::myAttributes
◆ myErrorMsg
std::string SketchSolver_Constraint::myErrorMsg
error message
