SketchSolver_ConstraintMovement Class Reference
Stores data to the Fixed constraint for the moved feature only. More...
#include <SketchSolver_ConstraintMovement.h>
Inheritance diagram for SketchSolver_ConstraintMovement:
 SketchSolver_ConstraintMovement (FeaturePtr theFeature)
 Creates movement constraint based on feature. More...
 SketchSolver_ConstraintMovement (AttributePtr theMovedAttribute, const int thePointIndex=-1)
 Creates movement constraint based on point. More...
void startPoint (const std::shared_ptr< GeomAPI_Pnt2d > &theStartPoint)
 Set coordinates of the start point of the movement. More...
void moveTo (const std::shared_ptr< GeomAPI_Pnt2d > &theDestinationPoint)
 Set coordinates of fixed feature to the values where it has been dragged. More...
virtual void blockEvents (bool isBlocked)
 Block or unblock events from this constraint. More...
FeaturePtr movedFeature () const
 Returns moved feature. More...
void process (StoragePtr theStorage, bool theEvensBlocked)
 Initializes parameters and start constraint creation. More...
virtual void notify (const FeaturePtr &theFeature, PlaneGCSSolver_Update *theUpdater)
 Notify this object about the feature is changed somewhere. More...
virtual void update ()
 Update constraint. More...
virtual bool remove ()
 Tries to remove constraint. More...
virtual SketchSolver_ConstraintType getType () const
 Returns the type of constraint. More...
const std::string & error () const
 Shows error message. More...
static SketchSolver_ConstraintType TYPE (ConstraintPtr theConstraint)
 Obtain a type of SketchPlugin constraint. More...
virtual void process ()
 Converts SketchPlugin constraint to a list of SolveSpace constraints. More...
ConstraintWrapperPtr initMovement ()
 Create Fixed constraint for the feature basing on its type and moved point. More...
ConstraintWrapperPtr fixArcExtremity (const EntityWrapperPtr &theArcExtremity)
 Create constraint to fix moved arc extremity. More...
ConstraintWrapperPtr fixPointOnCircle (const EntityWrapperPtr &theCircular)
 Create constraint to fix moved point on circle/arc. More...
ConstraintWrapperPtr fixPointOnEllipse (const EntityWrapperPtr &theConic)
 Create constraint to fix moved point on ellipse/elliptic arc. More...
virtual void getAttributes (EntityWrapperPtr &, std::vector< EntityWrapperPtr > &)
 Generate list of attributes of constraint in order useful for constraints. More...
EntityWrapperPtr entityToFix ()
 Obtain entity to be fixed. More...
ConstraintWrapperPtr fixFeature (EntityWrapperPtr theFeature)
 Create Fixed constraint for the feature basing on its type. More...
virtual void adjustConstraint ()
 This method is used in derived objects to check consistency of constraint. More...
void cleanErrorMsg ()
 Removes last error. More...
std::vector< double > myFixedValues
ConstraintPtr myBaseConstraint
 base SketchPlugin constraint More...
ConstraintWrapperPtr mySolverConstraint
 wrapper for PlaneGCS constraint More...
StoragePtr myStorage
 storage, which contains all information about entities and constraints More...
SketchSolver_ConstraintType myType
 type of constraint More...
std::list< EntityWrapperPtr > myAttributes
 attributes of constraint More...
std::string myErrorMsg
 error message More...
◆ SketchSolver_ConstraintMovement() [1/2]
SketchSolver_ConstraintMovement::SketchSolver_ConstraintMovement ( FeaturePtr  theFeature)
◆ SketchSolver_ConstraintMovement() [2/2]
SketchSolver_ConstraintMovement::SketchSolver_ConstraintMovement ( AttributePtr  theMovedAttribute,
const int  thePointIndex = -1
◆ startPoint()
void SketchSolver_ConstraintMovement::startPoint ( const std::shared_ptr< GeomAPI_Pnt2d > &  theStartPoint)
◆ moveTo()
void SketchSolver_ConstraintMovement::moveTo ( const std::shared_ptr< GeomAPI_Pnt2d > &  theDestinationPoint)
Useful when the feature is being moved.
◆ blockEvents()
void SketchSolver_ConstraintMovement::blockEvents ( bool  isBlocked)
Reimplemented from SketchSolver_ConstraintFixed.
◆ movedFeature()
FeaturePtr SketchSolver_ConstraintMovement::movedFeature ( ) const
◆ process() [1/2]
void SketchSolver_ConstraintMovement::process ( )
◆ initMovement()
ConstraintWrapperPtr SketchSolver_ConstraintMovement::initMovement ( )
Fixed constraint
◆ fixArcExtremity()
ConstraintWrapperPtr SketchSolver_ConstraintMovement::fixArcExtremity ( const EntityWrapperPtr &  theArcExtremity)
◆ fixPointOnCircle()
ConstraintWrapperPtr SketchSolver_ConstraintMovement::fixPointOnCircle ( const EntityWrapperPtr &  theCircular)
◆ fixPointOnEllipse()
ConstraintWrapperPtr SketchSolver_ConstraintMovement::fixPointOnEllipse ( const EntityWrapperPtr &  theConic)
◆ process() [2/2]
void SketchSolver_Constraint::process ( StoragePtr  theStorage,
theStorage[in] storage where to place new constraint
theEventsBlocked[in] all events from this constraint should be blocked
◆ getAttributes()
virtual void SketchSolver_ConstraintFixed::getAttributes ( EntityWrapperPtr &  ,
[out]theValuenumerical characteristic of constraint (e.g. distance)
[out]theAttributeslist of attributes to be filled
◆ entityToFix()
EntityWrapperPtr SketchSolver_ConstraintFixed::entityToFix ( )
◆ fixFeature()
ConstraintWrapperPtr SketchSolver_ConstraintFixed::fixFeature ( EntityWrapperPtr  theFeature)
theFeature[in] feature, converted to solver specific format
Fixed constraint
◆ notify()
virtual void SketchSolver_Constraint::notify ( const FeaturePtr &  theFeature,
PlaneGCSSolver_Update *  theUpdater
inlinevirtualinherited
◆ update()
void SketchSolver_Constraint::update ( )
◆ remove()
bool SketchSolver_Constraint::remove ( )
false, if current constraint contains another SketchPlugin constraints (like for multiple coincidence)
Reimplemented in SketchSolver_ConstraintCoincidence, SketchSolver_ConstraintDistance, SketchSolver_ConstraintEqual, SketchSolver_ConstraintMiddle, SketchSolver_ConstraintMulti, and SketchSolver_ConstraintTangent.
◆ TYPE()
SketchSolver_ConstraintType SketchSolver_Constraint::TYPE ( ConstraintPtr  theConstraint)
◆ getType()
virtual SketchSolver_ConstraintType SketchSolver_Constraint::getType ( ) const
◆ error()
const std::string & SketchSolver_Constraint::error ( ) const
◆ adjustConstraint()
virtual void SketchSolver_Constraint::adjustConstraint ( )
◆ cleanErrorMsg()
void SketchSolver_Constraint::cleanErrorMsg ( )
inlineprotectedinherited
Removes last error.
◆ myBaseConstraint
ConstraintPtr SketchSolver_Constraint::myBaseConstraint
◆ mySolverConstraint
ConstraintWrapperPtr SketchSolver_Constraint::mySolverConstraint
◆ myStorage
StoragePtr SketchSolver_Constraint::myStorage
◆ myType
SketchSolver_ConstraintType SketchSolver_Constraint::myType
type of constraint
◆ myAttributes
std::list<EntityWrapperPtr> SketchSolver_Constraint::myAttributes
◆ myErrorMsg
std::string SketchSolver_Constraint::myErrorMsg
error message
