SketchSolver_ConstraintEqual Class Reference
Convert equality constraint to SolveSpace structure. More...
#include <SketchSolver_ConstraintEqual.h>
Inheritance diagram for SketchSolver_ConstraintEqual:
 SketchSolver_ConstraintEqual (ConstraintPtr theConstraint)
 Constructor based on SketchPlugin constraint. More...
virtual bool remove ()
 Tries to remove constraint. More...
void process (StoragePtr theStorage, bool theEvensBlocked)
 Initializes parameters and start constraint creation. More...
virtual void notify (const FeaturePtr &theFeature, PlaneGCSSolver_Update *theUpdater)
 Notify this object about the feature is changed somewhere. More...
virtual void update ()
 Update constraint. More...
virtual void blockEvents (bool isBlocked)
 Block or unblock events from this constraint. More...
virtual SketchSolver_ConstraintType getType () const
 Returns the type of constraint. More...
const std::string & error () const
 Shows error message. More...
static SketchSolver_ConstraintType TYPE (ConstraintPtr theConstraint)
 Obtain a type of SketchPlugin constraint. More...
virtual void getAttributes (EntityWrapperPtr &theValue, std::vector< EntityWrapperPtr > &theAttributes)
 Generate list of attributes of constraint in order useful for constraints. More...
virtual void process ()
 Converts SketchPlugin constraint to a list of solver's constraints. More...
virtual void adjustConstraint ()
 This method is used in derived objects to check consistency of constraint. More...
void cleanErrorMsg ()
 Removes last error. More...
ConstraintPtr myBaseConstraint
 base SketchPlugin constraint More...
ConstraintWrapperPtr mySolverConstraint
 wrapper for PlaneGCS constraint More...
StoragePtr myStorage
 storage, which contains all information about entities and constraints More...
SketchSolver_ConstraintType myType
 type of constraint More...
std::list< EntityWrapperPtr > myAttributes
 attributes of constraint More...
std::string myErrorMsg
 error message More...
◆ SketchSolver_ConstraintEqual()
SketchSolver_ConstraintEqual::SketchSolver_ConstraintEqual ( ConstraintPtr  theConstraint)
◆ remove()
bool SketchSolver_ConstraintEqual::remove ( )
false, if current constraint contains another SketchPlugin constraints (like for multiple coincidence)
◆ getAttributes()
void SketchSolver_ConstraintEqual::getAttributes ( EntityWrapperPtr &  theValue,
std::vector< EntityWrapperPtr > &  theAttributes
[out]theValuenumerical characteristic of constraint (e.g. distance)
[out]theAttributeslist of attributes to be filled
◆ process() [1/2]
void SketchSolver_Constraint::process ( StoragePtr  theStorage,
theStorage[in] storage where to place new constraint
theEventsBlocked[in] all events from this constraint should be blocked
◆ process() [2/2]
◆ notify()
virtual void SketchSolver_Constraint::notify ( const FeaturePtr &  theFeature,
PlaneGCSSolver_Update *  theUpdater
inlinevirtualinherited
◆ update()
void SketchSolver_Constraint::update ( )
◆ blockEvents()
void SketchSolver_Constraint::blockEvents ( bool  isBlocked)
◆ TYPE()
SketchSolver_ConstraintType SketchSolver_Constraint::TYPE ( ConstraintPtr  theConstraint)
◆ getType()
virtual SketchSolver_ConstraintType SketchSolver_Constraint::getType ( ) const
◆ error()
const std::string & SketchSolver_Constraint::error ( ) const
◆ adjustConstraint()
virtual void SketchSolver_Constraint::adjustConstraint ( )
◆ cleanErrorMsg()
void SketchSolver_Constraint::cleanErrorMsg ( )
inlineprotectedinherited
Removes last error.
◆ myBaseConstraint
ConstraintPtr SketchSolver_Constraint::myBaseConstraint
◆ mySolverConstraint
ConstraintWrapperPtr SketchSolver_Constraint::mySolverConstraint
◆ myStorage
StoragePtr SketchSolver_Constraint::myStorage
◆ myType
SketchSolver_ConstraintType SketchSolver_Constraint::myType
type of constraint
◆ myAttributes
std::list<EntityWrapperPtr> SketchSolver_Constraint::myAttributes
◆ myErrorMsg
std::string SketchSolver_Constraint::myErrorMsg
error message
