SketchSolver_ConstraintMiddle Class Reference
Converts middle-point constraint to the constraint applicable for solver. More...
#include <SketchSolver_ConstraintMiddle.h>
Inheritance diagram for SketchSolver_ConstraintMiddle:
 SketchSolver_ConstraintMiddle (ConstraintPtr theConstraint)
 Constructor based on SketchPlugin constraint. More...
virtual void notify (const FeaturePtr &theFeature, PlaneGCSSolver_Update *theUpdater)
 Notify this object about the feature is changed somewhere. More...
virtual bool remove ()
 Remove constraint. More...
void process (StoragePtr theStorage, bool theEvensBlocked)
 Initializes parameters and start constraint creation. More...
virtual void update ()
 Update constraint. More...
virtual void blockEvents (bool isBlocked)
 Block or unblock events from this constraint. More...
virtual SketchSolver_ConstraintType getType () const
 Returns the type of constraint. More...
const std::string & error () const
 Shows error message. More...
static SketchSolver_ConstraintType TYPE (ConstraintPtr theConstraint)
 Obtain a type of SketchPlugin constraint. More...
virtual void getAttributes (EntityWrapperPtr &theValue, std::vector< EntityWrapperPtr > &theAttributes)
 Generate list of attributes of constraint in order useful for constraints. More...
virtual void process ()
 Converts SketchPlugin constraint to a list of solver constraints. More...
virtual void adjustConstraint ()
 This method is used in derived objects to check consistency of constraint. More...
void cleanErrorMsg ()
 Removes last error. More...
bool myInSolver
 shows the constraint is added to the solver More...
EntityWrapperPtr myFeatureExtremities [2]
 extremities of a feature, a point is coincident to More...
ScalarWrapperPtr myAuxValue
 parameter on B-spline curve More...
ConstraintPtr myBaseConstraint
 base SketchPlugin constraint More...
ConstraintWrapperPtr mySolverConstraint
 wrapper for PlaneGCS constraint More...
StoragePtr myStorage
 storage, which contains all information about entities and constraints More...
SketchSolver_ConstraintType myType
 type of constraint More...
std::list< EntityWrapperPtr > myAttributes
 attributes of constraint More...
std::string myErrorMsg
 error message More...
◆ SketchSolver_ConstraintMiddle()
SketchSolver_ConstraintMiddle::SketchSolver_ConstraintMiddle ( ConstraintPtr  theConstraint)
◆ notify()
void SketchSolver_ConstraintMiddle::notify ( const FeaturePtr &  theFeature,
PlaneGCSSolver_Update *  theUpdater
Reimplemented from SketchSolver_ConstraintCoincidence.
◆ remove()
bool SketchSolver_ConstraintMiddle::remove ( )
Remove constraint.
◆ getAttributes()
void SketchSolver_ConstraintMiddle::getAttributes ( EntityWrapperPtr &  theValue,
std::vector< EntityWrapperPtr > &  theAttributes
[out]theValuenumerical characteristic of constraint (e.g. distance)
[out]theAttributeslist of attributes to be filled
◆ process() [1/2]
void SketchSolver_ConstraintCoincidence::process ( )
◆ process() [2/2]
void SketchSolver_Constraint::process ( StoragePtr  theStorage,
theStorage[in] storage where to place new constraint
theEventsBlocked[in] all events from this constraint should be blocked
◆ adjustConstraint()
void SketchSolver_ConstraintCoincidence::adjustConstraint ( )
E.g. the distance between line and point may be signed.
◆ update()
void SketchSolver_Constraint::update ( )
◆ blockEvents()
void SketchSolver_Constraint::blockEvents ( bool  isBlocked)
◆ TYPE()
SketchSolver_ConstraintType SketchSolver_Constraint::TYPE ( ConstraintPtr  theConstraint)
◆ getType()
virtual SketchSolver_ConstraintType SketchSolver_Constraint::getType ( ) const
inlinevirtualinherited
◆ error()
const std::string & SketchSolver_Constraint::error ( ) const
◆ cleanErrorMsg()
void SketchSolver_Constraint::cleanErrorMsg ( )
inlineprotectedinherited
Removes last error.
◆ myInSolver
bool SketchSolver_ConstraintCoincidence::myInSolver
◆ myFeatureExtremities
EntityWrapperPtr SketchSolver_ConstraintCoincidence::myFeatureExtremities[2]
◆ myAuxValue
ScalarWrapperPtr SketchSolver_ConstraintCoincidence::myAuxValue
◆ myBaseConstraint
ConstraintPtr SketchSolver_Constraint::myBaseConstraint
◆ mySolverConstraint
ConstraintWrapperPtr SketchSolver_Constraint::mySolverConstraint
◆ myStorage
StoragePtr SketchSolver_Constraint::myStorage
◆ myType
SketchSolver_ConstraintType SketchSolver_Constraint::myType
type of constraint
◆ myAttributes
std::list<EntityWrapperPtr> SketchSolver_Constraint::myAttributes
◆ myErrorMsg
std::string SketchSolver_Constraint::myErrorMsg
error message
