SketchSolver_ConstraintMultiRotation Class Reference
Convert rotated features to the list of SolveSpace constraints. More...
#include <SketchSolver_ConstraintMultiRotation.h>
Inheritance diagram for SketchSolver_ConstraintMultiRotation:
 SketchSolver_ConstraintMultiRotation (ConstraintPtr theConstraint)
 Constructor based on SketchPlugin constraint. More...
virtual void update ()
 Update constraint. More...
virtual void notify (const FeaturePtr &theFeature, PlaneGCSSolver_Update *)
 Notify this object about the feature is changed somewhere. More...
virtual bool remove ()
 Tries to remove constraint. More...
virtual void blockEvents (bool isBlocked)
 Block or unblock events from this constraint. More...
void process (StoragePtr theStorage, bool theEvensBlocked)
 Initializes parameters and start constraint creation. More...
virtual SketchSolver_ConstraintType getType () const
 Returns the type of constraint. More...
const std::string & error () const
 Shows error message. More...
static SketchSolver_ConstraintType TYPE (ConstraintPtr theConstraint)
 Obtain a type of SketchPlugin constraint. More...
virtual void process ()
 Converts SketchPlugin constraint to a list of SolveSpace constraints. More...
void getAttributes (EntityWrapperPtr &theCenter, ScalarWrapperPtr &theAngle, bool &theFullValue, bool &theReversed, std::list< EntityWrapperPtr > &theEntities)
 Generate list of rotated entities. More...
virtual void adjustConstraint ()
 This method is used in derived objects to check consistence of constraint. More...
virtual void updateLocal ()
 Update parameters (called from base class) More...
void getEntities (std::list< EntityWrapperPtr > &theEntities)
 Collect entities which are translated or rotated (not their copies) More...
virtual void getAttributes (EntityWrapperPtr &, std::vector< EntityWrapperPtr > &)
 Generate list of attributes of constraint in order useful for SolveSpace constraints. More...
void cleanErrorMsg ()
 Removes last error. More...
int myNumberOfObjects
 number of previous initial objects More...
int myNumberOfCopies
 number of previous copies of initial objects More...
bool myIsFullValue
 value whether the angle/distance is a full or single for objects More...
bool myAdjusted
 the constraint is already adjusted (to not do it several times) More...
std::set< FeaturePtr > myOriginalFeatures
 lists of original features and their copies to find whether some of them are disappeared More...
std::set< FeaturePtr > myCopiedFeatures
bool myIsEventsBlocked
bool myIsProcessingNotify
 the notification is already processing More...
ConstraintPtr myBaseConstraint
 base SketchPlugin constraint More...
ConstraintWrapperPtr mySolverConstraint
 wrapper for PlaneGCS constraint More...
StoragePtr myStorage
 storage, which contains all information about entities and constraints More...
SketchSolver_ConstraintType myType
 type of constraint More...
std::list< EntityWrapperPtr > myAttributes
 attributes of constraint More...
std::string myErrorMsg
 error message More...
◆ SketchSolver_ConstraintMultiRotation()
SketchSolver_ConstraintMultiRotation::SketchSolver_ConstraintMultiRotation ( ConstraintPtr  theConstraint)
◆ process() [1/2]
void SketchSolver_ConstraintMultiRotation::process ( )
Reimplemented from SketchSolver_ConstraintMulti.
◆ getAttributes() [1/2]
void SketchSolver_ConstraintMultiRotation::getAttributes ( EntityWrapperPtr &  theCenter,
ScalarWrapperPtr &  theAngle,
bool &  theFullValue,
bool &  theReversed,
std::list< EntityWrapperPtr > &  theEntities
[out]theCentercentral point of rotation
[out]theAnglerotation angle
[out]theFullValueapplying translation using the distance as a full or single value
[out]theReversedrotation angle is negative
[out]theEntitieslist of base entities
◆ adjustConstraint()
void SketchSolver_ConstraintMultiRotation::adjustConstraint ( )
◆ updateLocal()
void SketchSolver_ConstraintMultiRotation::updateLocal ( )
Implements SketchSolver_ConstraintMulti.
◆ update()
void SketchSolver_ConstraintMulti::update ( )
Update constraint.
◆ notify()
void SketchSolver_ConstraintMulti::notify ( const FeaturePtr &  theFeature,
◆ remove()
bool SketchSolver_ConstraintMulti::remove ( )
false, if current constraint contains another SketchPlugin constraints (like for multiple coincidence)
◆ blockEvents()
void SketchSolver_ConstraintMulti::blockEvents ( bool  isBlocked)
◆ process() [2/2]
void SketchSolver_Constraint::process ( StoragePtr  theStorage,
theStorage[in] storage where to place new constraint
theEventsBlocked[in] all events from this constraint should be blocked
◆ getEntities()
void SketchSolver_ConstraintMulti::getEntities ( std::list< EntityWrapperPtr > &  theEntities)
◆ getAttributes() [2/2]
virtual void SketchSolver_ConstraintMulti::getAttributes ( EntityWrapperPtr &  ,
◆ TYPE()
SketchSolver_ConstraintType SketchSolver_Constraint::TYPE ( ConstraintPtr  theConstraint)
◆ getType()
virtual SketchSolver_ConstraintType SketchSolver_Constraint::getType ( ) const
inlinevirtualinherited
◆ error()
const std::string & SketchSolver_Constraint::error ( ) const
◆ cleanErrorMsg()
void SketchSolver_Constraint::cleanErrorMsg ( )
inlineprotectedinherited
Removes last error.
◆ myNumberOfObjects
int SketchSolver_ConstraintMulti::myNumberOfObjects
◆ myNumberOfCopies
int SketchSolver_ConstraintMulti::myNumberOfCopies
◆ myIsFullValue
bool SketchSolver_ConstraintMulti::myIsFullValue
◆ myAdjusted
bool SketchSolver_ConstraintMulti::myAdjusted
◆ myOriginalFeatures
std::set<FeaturePtr> SketchSolver_ConstraintMulti::myOriginalFeatures
◆ myIsProcessingNotify
bool SketchSolver_ConstraintMulti::myIsProcessingNotify
◆ myBaseConstraint
ConstraintPtr SketchSolver_Constraint::myBaseConstraint
◆ mySolverConstraint
ConstraintWrapperPtr SketchSolver_Constraint::mySolverConstraint
◆ myStorage
StoragePtr SketchSolver_Constraint::myStorage
◆ myType
SketchSolver_ConstraintType SketchSolver_Constraint::myType
type of constraint
◆ myAttributes
std::list<EntityWrapperPtr> SketchSolver_Constraint::myAttributes
◆ myErrorMsg
std::string SketchSolver_Constraint::myErrorMsg
error message
