Converts collinear constraint to the constraint applicable for solver. More...
#include <SketchSolver_ConstraintCollinear.h>
| SketchSolver_ConstraintCollinear (ConstraintPtr theConstraint) | |
| Constructor based on SketchPlugin constraint. More... | |
| virtual void | notify (const FeaturePtr &theFeature, PlaneGCSSolver_Update *theUpdater) |
| Notify this object about the feature is changed somewhere. More... | |
| void | process (StoragePtr theStorage, bool theEvensBlocked) |
| Initializes parameters and start constraint creation. More... | |
| virtual void | update () |
| Update constraint. More... | |
| virtual bool | remove () |
| Tries to remove constraint. More... | |
| virtual void | blockEvents (bool isBlocked) |
| Block or unblock events from this constraint. More... | |
| virtual SketchSolver_ConstraintType | getType () const |
| Returns the type of constraint. More... | |
| const std::string & | error () const |
| Shows error message. More... | |
| static SketchSolver_ConstraintType | TYPE (ConstraintPtr theConstraint) |
| Obtain a type of SketchPlugin constraint. More... | |
| virtual void | process () |
| Converts SketchPlugin constraint to a list of solver constraints. More... | |
| virtual void | getAttributes (EntityWrapperPtr &theValue, std::vector< EntityWrapperPtr > &theAttributes) |
| Generate list of attributes of constraint in order useful for constraints. More... | |
| virtual void | adjustConstraint () |
| This method is used in derived objects to check consistency of constraint. More... | |
| void | cleanErrorMsg () |
| Removes last error. More... | |
Protected Attributes | |
| ConstraintPtr | myBaseConstraint |
| base SketchPlugin constraint More... | |
| ConstraintWrapperPtr | mySolverConstraint |
| wrapper for PlaneGCS constraint More... | |
| StoragePtr | myStorage |
| storage, which contains all information about entities and constraints More... | |
| SketchSolver_ConstraintType | myType |
| type of constraint More... | |
| std::list< EntityWrapperPtr > | myAttributes |
| attributes of constraint More... | |
| std::string | myErrorMsg |
| error message More... | |
inline |
protectedvirtual |
| theStorage | [in] storage where to place new constraint |
| theEventsBlocked | [in] all events from this constraint should be blocked |
Update constraint.
Reimplemented in SketchSolver_ConstraintDistance, SketchSolver_ConstraintMirror, SketchSolver_ConstraintMulti, and SketchSolver_ConstraintOffset.
false, if current constraint contains another SketchPlugin constraints (like for multiple coincidence) Reimplemented in SketchSolver_ConstraintCoincidence, SketchSolver_ConstraintDistance, SketchSolver_ConstraintEqual, SketchSolver_ConstraintMiddle, SketchSolver_ConstraintMulti, and SketchSolver_ConstraintTangent.
Reimplemented in SketchSolver_ConstraintFixed, SketchSolver_ConstraintMirror, SketchSolver_ConstraintMovement, and SketchSolver_ConstraintMulti.
staticinherited |
inlinevirtualinherited |
inlineinherited |
protectedvirtualinherited |
| [out] | theValue | numerical characteristic of constraint (e.g. distance) |
| [out] | theAttributes | list of attributes to be filled |
Reimplemented in SketchSolver_ConstraintFixed, SketchSolver_ConstraintMirror, SketchSolver_ConstraintMulti, SketchSolver_ConstraintOffset, SketchSolver_ConstraintAngle, SketchSolver_ConstraintCoincidence, SketchSolver_ConstraintDistance, SketchSolver_ConstraintEqual, SketchSolver_ConstraintLength, and SketchSolver_ConstraintMiddle.
E.g. the distance between line and point may be signed.
Reimplemented in SketchSolver_ConstraintAngle, SketchSolver_ConstraintCoincidence, SketchSolver_ConstraintDistance, SketchSolver_ConstraintMirror, SketchSolver_ConstraintMulti, SketchSolver_ConstraintMultiRotation, SketchSolver_ConstraintMultiTranslation, and SketchSolver_ConstraintTangent.
inlineprotectedinherited |
Removes last error.
type of constraint
error message
