SketchSolver_Manager.h
20#ifndef SketchSolver_Manager_H_
21#define SketchSolver_Manager_H_
23#include <SketchSolver_Group.h>
24
25#include <Events_Listener.h>
26
27#include <list>
28#include <set>
30class GeomAPI_Pnt2d;
34
43{
44public:
49
53 virtual void processEvent(const std::shared_ptr<Events_Message>& theMessage);
54
59 virtual bool groupMessages();
60
61protected:
64
69 bool updateFeature(const std::shared_ptr<SketchPlugin_Feature>& theFeature);
70
75 bool updateSketch(const std::shared_ptr<ModelAPI_CompositeFeature>& theSketch);
76
83 bool moveFeature(const std::shared_ptr<SketchPlugin_Feature>& theMovedFeature,
84 const std::shared_ptr<GeomAPI_Pnt2d>& theFromPoint,
85 const std::shared_ptr<GeomAPI_Pnt2d>& theToPoint);
86
94 bool moveAttribute(const std::shared_ptr<ModelAPI_Attribute>& theMovedAttribute,
95 const int theMovedPointIndex,
96 const std::shared_ptr<GeomAPI_Pnt2d>& theFromPoint,
97 const std::shared_ptr<GeomAPI_Pnt2d>& theToPoint);
98
103 bool removeConstraint(std::shared_ptr<SketchPlugin_Constraint> theConstraint);
104
109 bool resolveConstraints();
110
111private:
116 SketchGroupPtr findGroup(std::shared_ptr<SketchPlugin_Feature> theFeature);
121 SketchGroupPtr findGroup(std::shared_ptr<ModelAPI_CompositeFeature> theSketch);
122
125 bool stopSendUpdate() const;
127 void allowSendUpdate() const;
128
130 void releaseFeaturesIfEventsBlocked() const;
131
132private:
133 std::list<SketchGroupPtr> myGroups;
136 bool myIsComputed;
137};
138
139#endif
Base interface for any event listener.
Definition: Events_Listener.h:37
Feature that consists of other features: like sketcher with edges inside.
Definition: ModelAPI_CompositeFeature.h:33
Abstract interface to the SketchPlugin_ConstraintBase For more info see: SketchPlugin_ConstraintBase....
Definition: SketchPlugin_Constraint.h:37
Listens the changes of SketchPlugin features and transforms the Constraint feature into the format un...
Definition: SketchSolver_Manager.h:43
bool moveAttribute(const std::shared_ptr< ModelAPI_Attribute > &theMovedAttribute, const int theMovedPointIndex, const std::shared_ptr< GeomAPI_Pnt2d > &theFromPoint, const std::shared_ptr< GeomAPI_Pnt2d > &theToPoint)
Move feature using its moved attribute.
Definition: SketchSolver_Manager.cpp:365
bool updateFeature(const std::shared_ptr< SketchPlugin_Feature > &theFeature)
Adds or updates a constraint or an entity in the suitable group.
Definition: SketchSolver_Manager.cpp:309
bool updateSketch(const std::shared_ptr< ModelAPI_CompositeFeature > &theSketch)
Updates the sketch and related constraints, if the sketch plane is changed.
Definition: SketchSolver_Manager.cpp:290
virtual void processEvent(const std::shared_ptr< Events_Message > &theMessage)
Implementation of Event Listener method.
Definition: SketchSolver_Manager.cpp:148
bool removeConstraint(std::shared_ptr< SketchPlugin_Constraint > theConstraint)
Removes a constraint from the manager.
The solver needs all the updated objects are transferred in one group, not one by one.
Definition: SketchSolver_Manager.cpp:139
Goes through the list of groups and solve the constraints.
Definition: SketchSolver_Manager.cpp:439
bool moveFeature(const std::shared_ptr< SketchPlugin_Feature > &theMovedFeature, const std::shared_ptr< GeomAPI_Pnt2d > &theFromPoint, const std::shared_ptr< GeomAPI_Pnt2d > &theToPoint)
Move feature.
Definition: SketchSolver_Manager.cpp:334
static SketchSolver_Manager * instance()
Main method to create constraint manager.
Definition: SketchSolver_Manager.cpp:109
