SketcherPrs_SymbolPrs.h
20#ifndef SketcherPrs_SymbolPrs_H
21#define SketcherPrs_SymbolPrs_H
23#include "SketcherPrs_SensitivePoint.h"
24#include <SketchPlugin_Sketch.h>
26#include <ModelAPI_AttributeRefList.h>
27
28#include <AIS_InteractiveObject.hxx>
29#include <GeomAPI_Ax3.h>
30#include <Graphic3d_ArrayOfPoints.hxx>
31#include <Graphic3d_AspectMarker3d.hxx>
32#include <Image_AlienPixMap.hxx>
33#include <SelectMgr_EntityOwner.hxx>
34#include <Select3D_EntitySequence.hxx>
35
36#include <Standard_DefineHandle.hxx>
37#include <map>
38
39#include <OpenGl_Workspace.hxx>
40
41class OpenGl_Context;
42
43
44DEFINE_STANDARD_HANDLE(SketcherPrs_SymbolPrs, AIS_InteractiveObject)
45
52{
53public:
57 Standard_EXPORT SketcherPrs_SymbolPrs(ModelAPI_Feature* theConstraint,
58 SketchPlugin_Sketch* theSketcher);
59
60 virtual ~SketcherPrs_SymbolPrs();
61
63 Standard_EXPORT virtual void HilightSelected(const Handle(PrsMgr_PresentationManager3d)& thePM,
64 const SelectMgr_SequenceOfOwner& theOwners);
65
67 Standard_EXPORT virtual void HilightOwnerWithColor(
68 const Handle(PrsMgr_PresentationManager3d)& thePM,
69 const Handle(Prs3d_Drawer)& theStyle,
70 const Handle(SelectMgr_EntityOwner)& theOwner);
71
73 Standard_EXPORT std::shared_ptr<GeomAPI_Ax3> plane() const
74 {
76 }
77
79 Standard_EXPORT ModelAPI_Feature* feature() const { return myConstraint; }
80
82 Standard_EXPORT ModelAPI_CompositeFeature* sketcher() const { return mySketcher; }
83
85 const Handle(Graphic3d_ArrayOfPoints)& pointsArray() const { return myPntArray; }
86
91 Standard_EXPORT void SetCustomColor(const std::vector<int>& theColor);
92
95 Standard_EXPORT virtual void BoundingBox (Bnd_Box& theBndBox) Standard_OVERRIDE;
96
97 DEFINE_STANDARD_RTTIEXT(SketcherPrs_SymbolPrs, AIS_InteractiveObject)
98
99protected:
101 Standard_EXPORT virtual void Compute(
102 const Handle(PrsMgr_PresentationManager3d)& thePresentationManager,
103 const Handle(Prs3d_Presentation)& thePresentation, const Standard_Integer theMode = 0);
104
108 Standard_EXPORT virtual void ComputeSelection(const Handle(SelectMgr_Selection)& aSelection,
109 const Standard_Integer aMode);
110
112 virtual const char* iconName(bool isActiveIcon = true) const = 0;
113
116 virtual void prepareAspect();
117
119 Handle(Image_AlienPixMap) icon();
120
124 void addLine(const Handle(Graphic3d_Group)& theGroup, std::string theAttrName) const;
125
129 virtual void drawLines(const Handle(Prs3d_Presentation)& /*thePrs*/,
130 Quantity_Color /*theColor*/) const {}
131
134 virtual bool updateIfReadyToDisplay(double /*theStep*/, bool /*withColor*/) const { return true; }
135
139 void drawShape(const std::shared_ptr<GeomAPI_Shape>& theShape,
140 const Handle(Prs3d_Presentation)& thePrs, Quantity_Color theColor) const;
141
145 void drawListOfShapes(const std::shared_ptr<ModelAPI_AttributeRefList>& theListAttr,
146 const Handle(Prs3d_Presentation)& thePrs, Quantity_Color theColor) const;
147
148protected:
151
154
156 Handle(Graphic3d_AspectMarker3d) myAspect;
157
159 mutable Handle(Graphic3d_ArrayOfPoints) myPntArray;
160
162 Handle(SelectMgr_EntityOwner) myOwner;
163
164private:
166 static std::map<const char*, Handle(Image_AlienPixMap)> myIconsMap;
167
168 Select3D_EntitySequence mySPoints;
169
170 bool myIsCustomColor;
171 Quantity_Color myCustomColor;
172
173 //bool myIsConflicting; /// state if the presentation is visualized in error state
174 Handle(Image_AlienPixMap) myErrorIcon;
175 Handle(Graphic3d_MarkerImage) myErrorImage;
176
177 friend class SketcherPrs_SymbolArray;
178};
179
180#endif
Feature that consists of other features: like sketcher with edges inside.
Definition: ModelAPI_CompositeFeature.h:33
Feature for creation of the new part in PartSet.
Definition: SketchPlugin_Sketch.h:47
std::shared_ptr< GeomAPI_Ax3 > coordinatePlane() const
Returns currently defined plane as an object of Ax3.
Definition: SketchPlugin_Sketch.h:248
Redefinition of OpenGl_Element.
Definition: SketcherPrs_SymbolPrs.cpp:67
A base class of constraint presentation which is represented by an icon.
Definition: SketcherPrs_SymbolPrs.h:52
Handle myAspect
Aspect for entities drawing.
Definition: SketcherPrs_SymbolPrs.h:156
void SetCustomColor(const std::vector< int > &theColor)
Set state of the presentation, in case of conflicting state, the icon of the presentation is visualiz...
Definition: SketcherPrs_SymbolPrs.cpp:344
virtual const char * iconName(bool isActiveIcon=true) const =0
Returns an icon file name. Has to be redefined in successors.
Check and creates if it is necessary myAspect member.
Definition: SketcherPrs_SymbolPrs.cpp:208
Handle myOwner
An owner object of the presentation.
Definition: SketcherPrs_SymbolPrs.h:162
Handle myPntArray
Array of symbols positions.
Definition: SketcherPrs_SymbolPrs.h:159
SketcherPrs_SymbolPrs(ModelAPI_Feature *theConstraint, SketchPlugin_Sketch *theSketcher)
Definition: SketcherPrs_SymbolPrs.cpp:120
ModelAPI_Feature * myConstraint
Constraint feature.
Definition: SketcherPrs_SymbolPrs.h:150
virtual DEFINE_STANDARD_RTTIEXT(SketcherPrs_SymbolPrs, AIS_InteractiveObject) protected void ComputeSelection(const Handle &aSelection, const Standard_Integer aMode)
Redefinition of virtual function.
Definition: SketcherPrs_SymbolPrs.cpp:333
ModelAPI_CompositeFeature * sketcher() const
Returns Sketcher object (owner of the constraint)
Definition: SketcherPrs_SymbolPrs.h:82
virtual void drawLines(const Handle &, Quantity_Color) const
Redefine this function in order to add additional lines of constraint base.
Definition: SketcherPrs_SymbolPrs.h:129
std::shared_ptr< GeomAPI_Ax3 > plane() const
Returns sketcher plane.
Definition: SketcherPrs_SymbolPrs.h:73
virtual void HilightSelected(const Handle &thePM, const SelectMgr_SequenceOfOwner &theOwners)
Method which draws selected owners ( for fast presentation draw )
Definition: SketcherPrs_SymbolPrs.cpp:239
void drawShape(const std::shared_ptr< GeomAPI_Shape > &theShape, const Handle &thePrs, Quantity_Color theColor) const
Draw a shape into the given presentation scene.
Definition: SketcherPrs_SymbolPrs.cpp:370
virtual void HilightOwnerWithColor(const Handle &thePM, const Handle &theStyle, const Handle &theOwner)
Method which highlight an owner belonging to.
Definition: SketcherPrs_SymbolPrs.cpp:252
ModelAPI_Feature * feature() const
Returns feature object.
Definition: SketcherPrs_SymbolPrs.h:79
virtual bool updateIfReadyToDisplay(double, bool) const
Update myPntArray according to presentation positions.
Definition: SketcherPrs_SymbolPrs.h:134
void addLine(const Handle &theGroup, std::string theAttrName) const
Add a line into the given group.
Definition: SketcherPrs_SymbolPrs.cpp:219
SketchPlugin_Sketch * mySketcher
Sketcher feature.
Definition: SketcherPrs_SymbolPrs.h:153
Handle icon()
Returns icon corresponded to the current constraint type.
Definition: SketcherPrs_SymbolPrs.cpp:160
const Handle & pointsArray() const
Return array of points where symbols will be placed.
Definition: SketcherPrs_SymbolPrs.h:85
void drawListOfShapes(const std::shared_ptr< ModelAPI_AttributeRefList > &theListAttr, const Handle &thePrs, Quantity_Color theColor) const
Draw a list of shapes stored in a RefListAttribute.
Definition: SketcherPrs_SymbolPrs.cpp:411
virtual void BoundingBox(Bnd_Box &theBndBox) Standard_OVERRIDE
Add a bounding box of the presentation to common bounding box.
Definition: SketcherPrs_SymbolPrs.cpp:429
