A base class of constraint presentation which is represented by an icon. More...
#include <SketcherPrs_SymbolPrs.h>
| SketcherPrs_SymbolPrs (ModelAPI_Feature *theConstraint, SketchPlugin_Sketch *theSketcher) | |
| Constructor. More... | |
| virtual void | HilightSelected (const Handle &thePM, const SelectMgr_SequenceOfOwner &theOwners) |
| Method which draws selected owners ( for fast presentation draw ) More... | |
| virtual void | HilightOwnerWithColor (const Handle &thePM, const Handle &theStyle, const Handle &theOwner) |
| Method which highlight an owner belonging to. More... | |
| std::shared_ptr< GeomAPI_Ax3 > | plane () const |
| Returns sketcher plane. More... | |
| ModelAPI_Feature * | feature () const |
| Returns feature object. More... | |
| ModelAPI_CompositeFeature * | sketcher () const |
| Returns Sketcher object (owner of the constraint) More... | |
| const Handle & | pointsArray () const |
| Return array of points where symbols will be placed. More... | |
| void | SetCustomColor (const std::vector< int > &theColor) |
| Set state of the presentation, in case of conflicting state, the icon of the presentation is visualized in error color. More... | |
| virtual void | BoundingBox (Bnd_Box &theBndBox) Standard_OVERRIDE |
| Add a bounding box of the presentation to common bounding box. More... | |
| virtual DEFINE_STANDARD_RTTIEXT(SketcherPrs_SymbolPrs, AIS_InteractiveObject) protected void | ComputeSelection (const Handle &aSelection, const Standard_Integer aMode) |
| Redefinition of virtual function. More... | |
| virtual const char * | iconName (bool isActiveIcon=true) const =0 |
| Returns an icon file name. Has to be redefined in successors. More... | |
| virtual void | prepareAspect () |
| Check and creates if it is necessary myAspect member. More... | |
| Handle | icon () |
| Returns icon corresponded to the current constraint type. More... | |
| void | addLine (const Handle &theGroup, std::string theAttrName) const |
| Add a line into the given group. More... | |
| virtual void | drawLines (const Handle &, Quantity_Color) const |
| Redefine this function in order to add additional lines of constraint base. More... | |
| virtual bool | updateIfReadyToDisplay (double, bool) const |
| Update myPntArray according to presentation positions. More... | |
| void | drawShape (const std::shared_ptr< GeomAPI_Shape > &theShape, const Handle &thePrs, Quantity_Color theColor) const |
| Draw a shape into the given presentation scene. More... | |
| void | drawListOfShapes (const std::shared_ptr< ModelAPI_AttributeRefList > &theListAttr, const Handle &thePrs, Quantity_Color theColor) const |
| Draw a list of shapes stored in a RefListAttribute. More... | |
Protected Attributes | |
| ModelAPI_Feature * | myConstraint |
| Constraint feature. More... | |
| SketchPlugin_Sketch * | mySketcher |
| Sketcher feature. More... | |
| Handle | myAspect |
| Aspect for entities drawing. More... | |
| Handle | myPntArray |
| Array of symbols positions. More... | |
| Handle | myOwner |
| An owner object of the presentation. More... | |
Friends | |
| class | SketcherPrs_SymbolArray |
| SketcherPrs_SymbolPrs::SketcherPrs_SymbolPrs | ( | ModelAPI_Feature * | theConstraint, |
| SketchPlugin_Sketch * | theSketcher | ||
| theConstraint | a constraint feature |
| thePlane | a coordinate plane of current sketch |
inline |
inline |
inline |
inline |
| void SketcherPrs_SymbolPrs::SetCustomColor | ( | const std::vector< int > & | theColor | ) |
The state is stored in an internal field, so should be changed when constraint become not conflicting
| theColor | a color for conflicting object |
| theBndBox | the common bounding box to update |
| aSelection | selection |
| aMode | compute mode |
pure virtual |
Implemented in SketcherPrs_Collinear, SketcherPrs_Equal, SketcherPrs_HVDirection, SketcherPrs_Middle, SketcherPrs_Parallel, SketcherPrs_Perpendicular, SketcherPrs_Rigid, SketcherPrs_Tangent, SketcherPrs_Mirror, SketcherPrs_Offset, and SketcherPrs_Transformation.
It has to be called before the object computation
| Handle SketcherPrs_SymbolPrs::icon | ( | ) |
| void SketcherPrs_SymbolPrs::addLine | ( | const Handle & | theGroup, |
| std::string | theAttrName | ||
| ) | const |
| theGroup | a group for drawing |
| theAttrName | an attribute name which corresponds to referenced line |
inlinevirtual |
| thePrs | a presentation |
| theColor | a color of additional lines |
Reimplemented in SketcherPrs_Collinear, SketcherPrs_Equal, SketcherPrs_HVDirection, SketcherPrs_Middle, SketcherPrs_Mirror, SketcherPrs_Offset, SketcherPrs_Parallel, SketcherPrs_Perpendicular, SketcherPrs_Rigid, SketcherPrs_Tangent, and SketcherPrs_Transformation.
inlinevirtual |
| void SketcherPrs_SymbolPrs::drawShape | ( | const std::shared_ptr< GeomAPI_Shape > & | theShape, |
| const Handle & | thePrs, | ||
| Quantity_Color | theColor | ||
| ) | const |
| theShape | the shape to draw |
| thePrs | the presentation scene |
| void SketcherPrs_SymbolPrs::drawListOfShapes | ( | const std::shared_ptr< ModelAPI_AttributeRefList > & | theListAttr, |
| ) | const |
| theListAttr | the attribute of reference3s list |
protected |
Constraint feature.
protected |
Sketcher feature.
protected |
mutableprotected |
protected |
