A redefinition of standard AIS Interactive Object in order to provide
presentation of parallel constraint.
More...
#include <SketcherPrs_Parallel.h>
| SketcherPrs_Parallel (ModelAPI_Feature *theConstraint, SketchPlugin_Sketch *theSketcher) | |
| Constructor. More... | |
| DEFINE_STANDARD_RTTIEXT (SketcherPrs_Parallel, SketcherPrs_SymbolPrs) static bool IsReadyToDisplay(ModelAPI_Feature *theConstraint | |
| Returns true if the constraint feature arguments are correctly filled to build AIS presentation. More... | |
| virtual void | HilightSelected (const Handle &thePM, const SelectMgr_SequenceOfOwner &theOwners) |
| Method which draws selected owners ( for fast presentation draw ) More... | |
| virtual void | HilightOwnerWithColor (const Handle &thePM, const Handle &theStyle, const Handle &theOwner) |
| Method which highlight an owner belonging to. More... | |
| std::shared_ptr< GeomAPI_Ax3 > | plane () const |
| Returns sketcher plane. More... | |
| ModelAPI_Feature * | feature () const |
| Returns feature object. More... | |
| ModelAPI_CompositeFeature * | sketcher () const |
| Returns Sketcher object (owner of the constraint) More... | |
| const Handle & | pointsArray () const |
| Return array of points where symbols will be placed. More... | |
| void | SetCustomColor (const std::vector< int > &theColor) |
| Set state of the presentation, in case of conflicting state, the icon of the presentation is visualized in error color. More... | |
| virtual void | BoundingBox (Bnd_Box &theBndBox) Standard_OVERRIDE |
| Add a bounding box of the presentation to common bounding box. More... | |
| virtual DEFINE_STANDARD_RTTIEXT(SketcherPrs_SymbolPrs, AIS_InteractiveObject) protected void | ComputeSelection (const Handle &aSelection, const Standard_Integer aMode) |
| Redefinition of virtual function. More... | |
| virtual void | prepareAspect () |
| Check and creates if it is necessary myAspect member. More... | |
| Handle | icon () |
| Returns icon corresponded to the current constraint type. More... | |
| void | addLine (const Handle &theGroup, std::string theAttrName) const |
| Add a line into the given group. More... | |
| void | drawShape (const std::shared_ptr< GeomAPI_Shape > &theShape, const Handle &thePrs, Quantity_Color theColor) const |
| Draw a shape into the given presentation scene. More... | |
| void | drawListOfShapes (const std::shared_ptr< ModelAPI_AttributeRefList > &theListAttr, const Handle &thePrs, Quantity_Color theColor) const |
| Draw a list of shapes stored in a RefListAttribute. More... | |
Data Fields | |
| const std::shared_ptr< GeomAPI_Ax3 > & | thePlane |
| virtual const char * | iconName (bool isActiveIcon=true) const |
| Returns an icon file name. Has to be redefined in successors. More... | |
| virtual void | drawLines (const Handle &thePrs, Quantity_Color theColor) const |
| Redefine this function in order to add additional lines of constraint base. More... | |
| virtual bool | updateIfReadyToDisplay (double theStep, bool withColor) const |
| Update myPntArray according to presentation positions. More... | |
Protected Attributes | |
| ModelAPI_Feature * | myConstraint |
| Constraint feature. More... | |
| SketchPlugin_Sketch * | mySketcher |
| Sketcher feature. More... | |
| Handle | myAspect |
| Aspect for entities drawing. More... | |
| Handle | myPntArray |
| Array of symbols positions. More... | |
| Handle | myOwner |
| An owner object of the presentation. More... | |
| SketcherPrs_Parallel::SketcherPrs_Parallel | ( | ModelAPI_Feature * | theConstraint, |
| SketchPlugin_Sketch * | theSketcher | ||
| theConstraint | a constraint feature |
| theSketcher | a sketcher object |
| SketcherPrs_Parallel::DEFINE_STANDARD_RTTIEXT | ( | SketcherPrs_Parallel | , |
| SketcherPrs_SymbolPrs | |||
| thePlane | a coordinate plane of current sketch |
inlineprotectedvirtual |
Implements SketcherPrs_SymbolPrs.
protectedvirtual |
| thePrs | a presentation |
| theColor | a color of additional lines |
Reimplemented from SketcherPrs_SymbolPrs.
protectedvirtual |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
The state is stored in an internal field, so should be changed when constraint become not conflicting
| theColor | a color for conflicting object |
| theBndBox | the common bounding box to update |
| aSelection | selection |
| aMode | compute mode |
It has to be called before the object computation
| theGroup | a group for drawing |
| theAttrName | an attribute name which corresponds to referenced line |
| theShape | the shape to draw |
| thePrs | the presentation scene |
| theListAttr | the attribute of reference3s list |
protectedinherited |
Constraint feature.
Sketcher feature.
mutableprotectedinherited |
