SketcherPrs_Tangent Class Reference
A redefinition of standard AIS Interactive Object in order to provide
presentation of tangent constraint. More...
#include <SketcherPrs_Tangent.h>
Inheritance diagram for SketcherPrs_Tangent:
 SketcherPrs_Tangent (ModelAPI_Feature *theConstraint, SketchPlugin_Sketch *theSketcher)
 DEFINE_STANDARD_RTTIEXT (SketcherPrs_Tangent, SketcherPrs_SymbolPrs) static bool IsReadyToDisplay(ModelAPI_Feature *theConstraint
 Returns true if the constraint feature arguments are correctly filled to build AIS presentation. More...
virtual void HilightSelected (const Handle &thePM, const SelectMgr_SequenceOfOwner &theOwners)
 Method which draws selected owners ( for fast presentation draw ) More...
virtual void HilightOwnerWithColor (const Handle &thePM, const Handle &theStyle, const Handle &theOwner)
 Method which highlight an owner belonging to. More...
std::shared_ptr< GeomAPI_Ax3 > plane () const
 Returns sketcher plane. More...
ModelAPI_Feature * feature () const
 Returns feature object. More...
ModelAPI_CompositeFeature * sketcher () const
 Returns Sketcher object (owner of the constraint) More...
const Handle & pointsArray () const
 Return array of points where symbols will be placed. More...
void SetCustomColor (const std::vector< int > &theColor)
 Set state of the presentation, in case of conflicting state, the icon of the presentation is visualized in error color. More...
virtual void BoundingBox (Bnd_Box &theBndBox) Standard_OVERRIDE
 Add a bounding box of the presentation to common bounding box. More...
virtual DEFINE_STANDARD_RTTIEXT(SketcherPrs_SymbolPrs, AIS_InteractiveObject) protected void ComputeSelection (const Handle &aSelection, const Standard_Integer aMode)
 Redefinition of virtual function. More...
virtual void prepareAspect ()
 Check and creates if it is necessary myAspect member. More...
Handle icon ()
 Returns icon corresponded to the current constraint type. More...
void addLine (const Handle &theGroup, std::string theAttrName) const
 Add a line into the given group. More...
void drawShape (const std::shared_ptr< GeomAPI_Shape > &theShape, const Handle &thePrs, Quantity_Color theColor) const
 Draw a shape into the given presentation scene. More...
void drawListOfShapes (const std::shared_ptr< ModelAPI_AttributeRefList > &theListAttr, const Handle &thePrs, Quantity_Color theColor) const
 Draw a list of shapes stored in a RefListAttribute. More...
Data Fields
const std::shared_ptr< GeomAPI_Ax3 > & thePlane
virtual const char * iconName (bool isActiveIcon=true) const
 Returns an icon file name. Has to be redefined in successors. More...
virtual void drawLines (const Handle &thePrs, Quantity_Color theColor) const
 Redefine this function in order to add additional lines of constraint base. More...
virtual bool updateIfReadyToDisplay (double theStep, bool withColor) const
 Update myPntArray according to presentation positions. More...
ModelAPI_Feature * myConstraint
 Constraint feature. More...
SketchPlugin_Sketch * mySketcher
 Sketcher feature. More...
Handle myAspect
 Aspect for entities drawing. More...
Handle myPntArray
 Array of symbols positions. More...
Handle myOwner
 An owner object of the presentation. More...
◆ SketcherPrs_Tangent()
SketcherPrs_Tangent::SketcherPrs_Tangent ( ModelAPI_Feature *  theConstraint,
SketchPlugin_Sketch *  theSketcher
theConstrainta constraint feature
theSketchera sketcher object
◆ DEFINE_STANDARD_RTTIEXT()
SketcherPrs_Tangent::DEFINE_STANDARD_RTTIEXT ( SketcherPrs_Tangent  ,
thePlanea coordinate plane of current sketch
boolean result value
◆ iconName()
virtual const char * SketcherPrs_Tangent::iconName ( bool  isActiveIcon = true) const
inlineprotectedvirtual
Implements SketcherPrs_SymbolPrs.
◆ drawLines()
void SketcherPrs_Tangent::drawLines ( const Handle &  ,
Quantity_Color
thePrsa presentation
theColora color of additional lines
Reimplemented from SketcherPrs_SymbolPrs.
◆ updateIfReadyToDisplay()
bool SketcherPrs_Tangent::updateIfReadyToDisplay ( double  theStep,
bool  withColor
true in case of success
◆ HilightSelected()
void SketcherPrs_SymbolPrs::HilightSelected ( const Handle &  thePM,
const SelectMgr_SequenceOfOwner &  theOwners
◆ HilightOwnerWithColor()
void SketcherPrs_SymbolPrs::HilightOwnerWithColor ( const Handle &  thePM,
const Handle &  theStyle,
const Handle &  theOwner
◆ plane()
std::shared_ptr< GeomAPI_Ax3 > SketcherPrs_SymbolPrs::plane ( ) const
◆ feature()
ModelAPI_Feature * SketcherPrs_SymbolPrs::feature ( ) const
◆ sketcher()
ModelAPI_CompositeFeature * SketcherPrs_SymbolPrs::sketcher ( ) const
◆ pointsArray()
const Handle & SketcherPrs_SymbolPrs::pointsArray ( ) const
◆ SetCustomColor()
void SketcherPrs_SymbolPrs::SetCustomColor ( const std::vector< int > &  theColor)
The state is stored in an internal field, so should be changed when constraint become not conflicting
theColora color for conflicting object
◆ BoundingBox()
void SketcherPrs_SymbolPrs::BoundingBox ( Bnd_Box &  theBndBox)
theBndBoxthe common bounding box to update
◆ ComputeSelection()
void SketcherPrs_SymbolPrs::ComputeSelection ( const Handle &  aSelection,
aSelectionselection
aModecompute mode
◆ prepareAspect()
void SketcherPrs_SymbolPrs::prepareAspect ( )
It has to be called before the object computation
◆ icon()
Handle SketcherPrs_SymbolPrs::icon ( )
◆ addLine()
void SketcherPrs_SymbolPrs::addLine ( const Handle &  theGroup,
theGroupa group for drawing
theAttrNamean attribute name which corresponds to referenced line
◆ drawShape()
void SketcherPrs_SymbolPrs::drawShape ( const std::shared_ptr< GeomAPI_Shape > &  theShape,
const Handle &  thePrs,
theShapethe shape to draw
thePrsthe presentation scene
◆ drawListOfShapes()
void SketcherPrs_SymbolPrs::drawListOfShapes ( const std::shared_ptr< ModelAPI_AttributeRefList > &  theListAttr,
theListAttrthe attribute of reference3s list
◆ myConstraint
ModelAPI_Feature* SketcherPrs_SymbolPrs::myConstraint
Constraint feature.
◆ mySketcher
SketchPlugin_Sketch* SketcherPrs_SymbolPrs::mySketcher
Sketcher feature.
◆ myAspect
Handle SketcherPrs_SymbolPrs::myAspect
◆ myPntArray
Handle SketcherPrs_SymbolPrs::myPntArray
mutableprotectedinherited
◆ myOwner
Handle SketcherPrs_SymbolPrs::myOwner
