Class to pass an attribute's (widget's) entry info extracted from xml file. More...
#include <Config_AttributeMessage.h>
| CONFIG_EXPORT | Config_AttributeMessage (const Events_ID theId, const void *theParent=0) |
| Constructor. More... | |
| virtual CONFIG_EXPORT | ~Config_AttributeMessage () |
| Destructor. More... | |
| CONFIG_EXPORT const std::string & | attributeId () const |
| Returns attribute's unique id. More... | |
| CONFIG_EXPORT const std::string & | featureId () const |
| Returns attribute's feature's unique id. More... | |
| CONFIG_EXPORT bool | isObligatory () const |
| Returns true if attribute is obligatory: Required to be set by user, else it's feature is invalid. More... | |
| CONFIG_EXPORT bool | isConcealment () const |
| Returns true if attribute should conceal input features. More... | |
| CONFIG_EXPORT bool | isMainArgument () const |
| Returns true if attribute is a main argument of the feature. More... | |
| CONFIG_EXPORT bool | isGeometricalSelection () const |
| Returns true if attribute selects geometry instead of shape;. More... | |
| CONFIG_EXPORT const std::list< std::pair< std::string, std::string > > & | getCases () const |
| Returns container of ids of pair of a case and switches. More... | |
| CONFIG_EXPORT void | setCases (const std::list< std::pair< std::string, std::string > > &theCases) |
| Sets ids of pair of a case and switches. More... | |
| CONFIG_EXPORT void | setAttributeId (const std::string &theId) |
| Set attribute's unique id. More... | |
| CONFIG_EXPORT void | setFeatureId (const std::string &id) |
| Set attribute's feature's unique id. More... | |
| CONFIG_EXPORT void | setConcealment (bool isConcealment) |
| Set attribute's concealment state. More... | |
| CONFIG_EXPORT void | setObligatory (bool isObligatory) |
| Set attribute's obligatory state. More... | |
| CONFIG_EXPORT void | setMainArgument (bool isMainArg) |
| Set a state that the attribute is a main argument of the feature. More... | |
| CONFIG_EXPORT void | setGeometricalSelection (bool isGeometricalSelection) |
| Set attribute's geometrical selection state. More... | |
| const Events_ID & | eventID () const |
| Returns identifier of the message. More... | |
| void * | sender () const |
| Returns sender of the message or NULL if it is anonymous message. More... | |
| static const char * | MODEL_EVENT () |
| Same event as Config_FeatureMessage::MODEL_EVENT() More... | |
| Config_AttributeMessage::Config_AttributeMessage | ( | const Events_ID | theId, |
| const void * | theParent = 0 |
inlinestatic |
| const std::string & Config_AttributeMessage::attributeId | ( | ) | const |
| const std::string & Config_AttributeMessage::featureId | ( | ) | const |
| bool Config_AttributeMessage::isObligatory | ( | ) | const |
| bool Config_AttributeMessage::isConcealment | ( | ) | const |
| bool Config_AttributeMessage::isMainArgument | ( | ) | const |
| bool Config_AttributeMessage::isGeometricalSelection | ( | ) | const |
| const std::list< std::pair< std::string, std::string > > & Config_AttributeMessage::getCases | ( | ) | const |
| void Config_AttributeMessage::setCases | ( | const std::list< std::pair< std::string, std::string > > & | theCases | ) |
| void Config_AttributeMessage::setAttributeId | ( | const std::string & | theId | ) |
| void Config_AttributeMessage::setFeatureId | ( | const std::string & | id | ) |
| void Config_AttributeMessage::setConcealment | ( | bool | isConcealment | ) |
| void Config_AttributeMessage::setObligatory | ( | bool | isObligatory | ) |
| void Config_AttributeMessage::setMainArgument | ( | bool | isMainArg | ) |
| void Config_AttributeMessage::setGeometricalSelection | ( | bool | isGeometricalSelection | ) |
inlineinherited |
inlineinherited |
