Config_PropManager Class Reference
Class which let to register properties. More...
#include <Config_PropManager.h>
static Config_Prop * registerProp (const std::string &theSection, const std::string &theName, const std::string &theTitle, Config_Prop::PropType theType, const std::string &theDefValue="", const std::string &theMin="", const std::string &theMax="")
 Registers property parameters. More...
static Config_Prop * findProp (const std::string &theSection, const std::string &theName)
 Finds property in the given section by the given name, if property not found returns NULL. More...
static Config_Properties getProperties ()
 Returns std::list of all existing properties. More...
static std::list< std::string > getSections ()
 Returns list of registered section names. More...
static Config_Properties getProperties (const std::string &theSection)
 Returns list of properties by its owner and section. More...
static std::string string (const std::string &theSection, const std::string &theName)
 Returns value of the property by its owner, section, and name. More...
static std::vector< int > color (const std::string &theSection, const std::string &theName)
 Returns color by given section and name as 3-element vector {r,g,b}. More...
static int integer (const std::string &theSection, const std::string &theName)
 Returns integer by given section and name. More...
static double real (const std::string &theSection, const std::string &theName)
 Returns real by given section and name. More...
static bool boolean (const std::string &theSection, const std::string &theName)
 Returns boolean by given section and name. More...
static double stringToDouble (const std::string &theDouble)
 Returns conversion of the string to double value. More...
static bool getAutoColorStatus ()
 Returns Auto-color status as a Boolean. More...
static void setAutoColorStatus (const bool theValue)
 Set Auto-color boolean value. More...
◆ registerProp()
Config_Prop * Config_PropManager::registerProp ( const std::string &  theSection,
const std::string &  theName,
const std::string &  theTitle,
const std::string &  theDefValue = "",
const std::string &  theMin = "",
const std::string &  theMax = ""
theSection- name of section (domain of using) of the property.
theName- name (title) of the value.
theTitle- title of the value.
theType- type of the value.
theDefValue- default and initial value of the property
theMin- minimal value
theMax- maximal value Returns True if the property successfully registered
◆ findProp()
Config_Prop * Config_PropManager::findProp ( const std::string &  theSection,
◆ getProperties() [1/2]
Config_Properties Config_PropManager::getProperties ( )
◆ getSections()
std::list< std::string > Config_PropManager::getSections ( )
◆ getProperties() [2/2]
Config_Properties Config_PropManager::getProperties ( const std::string &  theSection)
◆ string()
std::string Config_PropManager::string ( const std::string &  theSection,
◆ color()
std::vector< int > Config_PropManager::color ( const std::string &  theSection,
◆ integer()
int Config_PropManager::integer ( const std::string &  theSection,
◆ real()
double Config_PropManager::real ( const std::string &  theSection,
◆ boolean()
bool Config_PropManager::boolean ( const std::string &  theSection,
◆ stringToDouble()
double Config_PropManager::stringToDouble ( const std::string &  theDouble)
Temporary changes locale to process values contained "," or "." separator.
theDoublea value to be converted
double result or zero
◆ getAutoColorStatus()
bool Config_PropManager::getAutoColorStatus ( )
◆ setAutoColorStatus()
void Config_PropManager::setAutoColorStatus ( const bool  theValue)
theValuea value to use
