| def | __init__ (self) |
| def | name (self) |
| def | isSupported (self, theType) |
| def | isMultiple (self) |
| def | isOk (self, theShape, theResult, theArgs) |
| def | xmlRepresentation (self) |
| def | initAttributes (self, theArgs) |
| def | adjacentFaces (self, theFace, theMapSA, theShapeType, theApplicableFaces, theRecursive=True) |
| virtual const std::string & | name () const =0 |
| Returns name of the filter to represent it in GUI. More... | |
| virtual bool | isSupported (GeomAPI_Shape::ShapeType theType) const =0 |
| Returns true if the given shape type is supported. More... | |
| virtual bool | isOk (const GeomShapePtr &theShape, const ResultPtr &theResult, const ModelAPI_FiltersArgs &theArgs) const =0 |
| This method should contain the filter logic. More... | |
| virtual bool | isMultiple () const |
| Returns True if the filter can be used several times within one filtering. More... | |
| virtual std::string | xmlRepresentation () const |
| Returns XML string which represents GUI of the filter By default it returns nothing (no GUI) More... | |
| virtual void | initAttributes (ModelAPI_FiltersArgs &) |
| Initializes arguments of a filter. More... | |
| virtual std::string | xmlFromFile (const std::string &theConfigFile) const |
| Returns XML string which represents GUI of the filter by reading corresponding XML file. More... | |
Data Fields | |
| myCached | |
Filter for faces topologically connected to the selected object.
| def FiltersPlugin_TopoConnectedFaces.FiltersPlugin_TopoConnectedFaces.__init__ | ( | self | ) |
x.__init__(...) initializes x; see x.__class__.__doc__ for signature
| def FiltersPlugin_TopoConnectedFaces.FiltersPlugin_TopoConnectedFaces.name | ( | self | ) |
Description of the filter
| def FiltersPlugin_TopoConnectedFaces.FiltersPlugin_TopoConnectedFaces.isSupported | ( | self, | |
| theType | |||
Supported types of filtered shapes
| def FiltersPlugin_TopoConnectedFaces.FiltersPlugin_TopoConnectedFaces.isMultiple | ( | self | ) |
Returns True if the filter can be used several times within one selection
| def FiltersPlugin_TopoConnectedFaces.FiltersPlugin_TopoConnectedFaces.isOk | ( | self, | |
| theShape, | |||
| theResult, | |||
| theArgs | |||
True if theShape is applicable for the filter
| def FiltersPlugin_TopoConnectedFaces.FiltersPlugin_TopoConnectedFaces.xmlRepresentation | ( | self | ) |
| def FiltersPlugin_TopoConnectedFaces.FiltersPlugin_TopoConnectedFaces.initAttributes | ( | self, | |
| theArgs | |||
| def FiltersPlugin_TopoConnectedFaces.FiltersPlugin_TopoConnectedFaces.adjacentFaces | ( | self, | |
| theFace, | |||
| theMapSA, | |||
| theShapeType, | |||
| theApplicableFaces, | |||
theRecursive = True |
Find all faces neighbour to theFace
pure virtualinherited |
Implemented in FiltersPlugin_BelongsTo, FiltersPlugin_ContinuousFaces, FiltersPlugin_EdgeSize, FiltersPlugin_ExternalFaces, FiltersPlugin_FaceSize, FiltersPlugin_FeatureEdges, FiltersPlugin_HorizontalFace, FiltersPlugin_OnGeometry, FiltersPlugin_OnLine, FiltersPlugin_OnPlane, FiltersPlugin_OnPlaneSide, FiltersPlugin_OnShapeName, FiltersPlugin_OppositeToEdge, FiltersPlugin_RelativeToSolid, FiltersPlugin_VerticalFace, and FiltersPlugin_VolumeSize.
It returns true if the given shape is accepted by the filter.
| theShape | the given shape |
| theResult | parent result of the shape to be checked |
| theArgs | arguments of the filter |
Implemented in FiltersPlugin_BelongsTo, FiltersPlugin_ContinuousFaces, FiltersPlugin_EdgeSize, FiltersPlugin_FaceSize, FiltersPlugin_FeatureEdges, FiltersPlugin_HorizontalFace, FiltersPlugin_OnGeometry, FiltersPlugin_OnLine, FiltersPlugin_OnPlane, FiltersPlugin_OnPlaneSide, FiltersPlugin_OppositeToEdge, FiltersPlugin_RelativeToSolid, FiltersPlugin_VerticalFace, FiltersPlugin_VolumeSize, FiltersPlugin_ExternalFaces, and FiltersPlugin_OnShapeName.
inlinevirtualinherited |
Reimplemented in FiltersPlugin_OnLine, FiltersPlugin_OnPlane, FiltersPlugin_OnPlaneSide, and FiltersPlugin_RelativeToSolid.
Reimplemented in FiltersPlugin_BelongsTo, FiltersPlugin_ContinuousFaces, FiltersPlugin_EdgeSize, FiltersPlugin_FaceSize, FiltersPlugin_FeatureEdges, FiltersPlugin_OnGeometry, FiltersPlugin_OnLine, FiltersPlugin_OnPlane, FiltersPlugin_OnPlaneSide, FiltersPlugin_OnShapeName, FiltersPlugin_OppositeToEdge, FiltersPlugin_RelativeToSolid, and FiltersPlugin_VolumeSize.
If a filter has no arguments, this method may be not redefined.
