GeomAPI_BSpline2d Class Reference
B-spline curve in 2D. More...
#include <GeomAPI_BSpline2d.h>
Inheritance diagram for GeomAPI_BSpline2d:
GEOMAPI_EXPORT GeomAPI_BSpline2d (const std::list< std::shared_ptr< GeomAPI_Pnt2d > > &thePoles, const std::list< double > &theWeights, const bool thePeriodic=false)
 Creation of B-spline curve defined by list of poles and weights. More...
GEOMAPI_EXPORT GeomAPI_BSpline2d (const int theDegree, const std::list< std::shared_ptr< GeomAPI_Pnt2d > > &thePoles, const std::list< double > &theWeights, const std::list< double > &theKnots=std::list< double >(), const std::list< int > &theMults=std::list< int >(), const bool thePeriodic=false)
GEOMAPI_EXPORT bool isNull () const
 Returns true if curve is not initialized. More...
GEOMAPI_EXPORT int degree () const
 Returns degree of the curve. More...
GEOMAPI_EXPORT std::list< double > knots () const
 Knots of the curve. More...
GEOMAPI_EXPORT std::list< int > mults () const
 Multiplicities of the knots. More...
GEOMAPI_EXPORT const bool parameter (const std::shared_ptr< GeomAPI_Pnt2d > thePoint, const double theTolerance, double &theParameter) const
 Computes the parameter of a given point on a circle. More...
GEOMAPI_EXPORT void D0 (const double theU, std::shared_ptr< GeomAPI_Pnt2d > &thePoint)
 Calculate point on B-spline curve according to the given parameter. More...
GEOMAPI_EXPORT void D1 (const double theU, std::shared_ptr< GeomAPI_Pnt2d > &thePoint, std::shared_ptr< GeomAPI_XY > &theDerivative)
 Calculate point and first derivative for B-spline curve according to the given parameter. More...
template<class T >
T * implPtr ()
template<class T >
const T * implPtr () const
template<class T >
const T & impl () const
template<class T >
void setImpl (T *theImpl)
◆ GeomAPI_BSpline2d() [1/2]
GeomAPI_BSpline2d::GeomAPI_BSpline2d ( const std::list< std::shared_ptr< GeomAPI_Pnt2d > > &  thePoles,
const std::list< double > &  theWeights,
const bool  thePeriodic = false
◆ GeomAPI_BSpline2d() [2/2]
GeomAPI_BSpline2d::GeomAPI_BSpline2d ( const int  theDegree,
const std::list< double > &  theKnots = std::list<double>(),
const std::list< int > &  theMults = std::list<int>(),
◆ isNull()
bool GeomAPI_BSpline2d::isNull ( ) const
◆ degree()
int GeomAPI_BSpline2d::degree ( ) const
◆ knots()
std::list< double > GeomAPI_BSpline2d::knots ( ) const
Knots of the curve.
◆ mults()
std::list< int > GeomAPI_BSpline2d::mults ( ) const
◆ parameter()
const bool GeomAPI_BSpline2d::parameter ( const std::shared_ptr< GeomAPI_Pnt2d >  thePoint,
double &  theParameter
The point must be located either on the circle itself or relatively to the latter at a distance less than the tolerance value. Return FALSE if the point is beyond the tolerance limit or if computation fails. Max Tolerance value is currently limited to 1.e-4
[in]thePointpoint of origin.
[in]theTolerancetolerance of computation.
[out]theParameterresulting parameter.
◆ D0()
void GeomAPI_BSpline2d::D0 ( const double  theU,
std::shared_ptr< GeomAPI_Pnt2d > &  thePoint
◆ D1()
void GeomAPI_BSpline2d::D1 ( const double  theU,
std::shared_ptr< GeomAPI_Pnt2d > &  thePoint,
std::shared_ptr< GeomAPI_XY > &  theDerivative
◆ implPtr() [1/2]
template<class T >
◆ implPtr() [2/2]
template<class T >
◆ impl()
template<class T >
◆ setImpl()
template<class T >
◆ empty()
