GeomAlgoAPI_ShapeAPI::GeomAlgoAPI_ShapeAPI Class Reference
static std::shared_ptr< GeomAPI_Shape > makeBox (const double theDx, const double theDy, const double theDz)
 Creates a box using the dimensions. More...
static std::shared_ptr< GeomAPI_Shape > makeBox (std::shared_ptr< GeomAPI_Pnt > theFirstPoint, std::shared_ptr< GeomAPI_Pnt > theSecondPoint)
 Creates a box using the two points that defined a diagonal. More...
static std::shared_ptr< GeomAPI_Shape > makeCylinder (std::shared_ptr< GeomAPI_Pnt > theBasePoint, std::shared_ptr< GeomAPI_Edge > theEdge, double theRadius, double theHeight)
 Creates a cylinder using a center, an axis, a radius and a height. More...
static std::shared_ptr< GeomAPI_Shape > makeCylinder (std::shared_ptr< GeomAPI_Pnt > theBasePoint, std::shared_ptr< GeomAPI_Edge > theEdge, double theRadius, double theHeight, double theAngle)
 Creates a portion of cylinder using a center, an axis, a radius, a height and an angle. More...
static std::shared_ptr< GeomAPI_Shape > makeCylinder (double theRadius, double theHeight)
 Creates a cylinder using the origin, the OZ axis, a radius and a height. More...
static std::shared_ptr< GeomAPI_Shape > makeCylinder (double theRadius, double theHeight, double theAngle)
 Creates a portion of cylinder using the origin, the OZ axis, a radius, a height and an angle. More...
static std::shared_ptr< GeomAPI_Shape > makeSphere (std::shared_ptr< GeomAPI_Pnt > theCenterPoint, double theRadius)
 Creates a sphere using a center and a radius. More...
static std::shared_ptr< GeomAPI_Shape > makeSphere (double theRadius)
 Creates a sphere using the origin and a radius. More...
static std::shared_ptr< GeomAPI_Shape > makeTorus (std::shared_ptr< GeomAPI_Pnt > theBasePoint, std::shared_ptr< GeomAPI_Edge > theEdge, double theRadius, double theRingRadius)
 Creates a torus using a base point, an axis, a radius and a ring radius. More...
static std::shared_ptr< GeomAPI_Shape > makeTorus (double theRadius, double theRingRadius)
 Creates a torus using a radius and a ring radius. More...
static std::shared_ptr< GeomAPI_Shape > makeCone (std::shared_ptr< GeomAPI_Pnt > theBasePoint, std::shared_ptr< GeomAPI_Edge > theEdge, double theBaseRadius, double theTopRadius, double theHeight)
 Creates a cone using a base point, an axis, a base radius, a top radius and a height. More...
static std::shared_ptr< GeomAPI_Shape > makeCone (double theBaseRadius, double theTopRadius, double theHeight)
 Creates a cone using a base radius, a top radius and a height. More...
static std::shared_ptr< GeomAPI_Shape > makeTranslation (std::shared_ptr< GeomAPI_Shape > theSourceShape, std::shared_ptr< GeomAPI_Ax1 > theAxis, const double theDistance)
 Performs a translation from an axis and a distance. More...
static std::shared_ptr< GeomAPI_Shape > makeTranslation (std::shared_ptr< GeomAPI_Shape > theSourceShape, const double theDx, const double theDy, const double theDz)
 Performs a translation from dimensions. More...
static std::shared_ptr< GeomAPI_Shape > makeTranslation (std::shared_ptr< GeomAPI_Shape > theSourceShape, std::shared_ptr< GeomAPI_Pnt > theStartPoint, std::shared_ptr< GeomAPI_Pnt > theEndPoint)
 Performs a translation from two points. More...
static std::shared_ptr< GeomAPI_Shape > makeRotation (std::shared_ptr< GeomAPI_Shape > theSourceShape, std::shared_ptr< GeomAPI_Ax1 > theAxis, const double theAngle)
 Performs a rotation from an axis and an angle. More...
static std::shared_ptr< GeomAPI_Shape > makeRotation (std::shared_ptr< GeomAPI_Shape > theSourceShape, std::shared_ptr< GeomAPI_Pnt > theCenterPoint, std::shared_ptr< GeomAPI_Pnt > theStartPoint, std::shared_ptr< GeomAPI_Pnt > theEndPoint)
 Performs a rotation from three points. More...
static std::shared_ptr< GeomAPI_Shape > makeSymmetry (std::shared_ptr< GeomAPI_Shape > theSourceShape, std::shared_ptr< GeomAPI_Pnt > thePoint)
 Performs a symmetry by a point. More...
static std::shared_ptr< GeomAPI_Shape > makeSymmetry (std::shared_ptr< GeomAPI_Shape > theSourceShape, std::shared_ptr< GeomAPI_Ax1 > theAxis)
 Performs a symmetry by an axis. More...
static std::shared_ptr< GeomAPI_Shape > makeSymmetry (std::shared_ptr< GeomAPI_Shape > theSourceShape, std::shared_ptr< GeomAPI_Ax2 > thePlane)
 Performs a symmetry by a plane. More...
static std::shared_ptr< GeomAPI_Shape > makeScale (std::shared_ptr< GeomAPI_Shape > theSourceShape, std::shared_ptr< GeomAPI_Pnt > theCenterPoint, const double theScaleFactor)
 Performs a scale by a scale factor. More...
static std::shared_ptr< GeomAPI_Shape > makeScale (std::shared_ptr< GeomAPI_Shape > theSourceShape, std::shared_ptr< GeomAPI_Pnt > theCenterPoint, const double theScaleFactorX, const double theScaleFactorY, const double theScaleFactorZ)
 Performs a scale by dimensions. More...
static std::shared_ptr< GeomAPI_Shape > makeMultiTranslation (std::shared_ptr< GeomAPI_Shape > theSourceShape, std::shared_ptr< GeomAPI_Ax1 > theAxis, const double theStep, const int theNumber)
 Performs a multi translation along one axis, at a distance and a number of times. More...
static std::shared_ptr< GeomAPI_Shape > makeMultiTranslation (std::shared_ptr< GeomAPI_Shape > theSourceShape, std::shared_ptr< GeomAPI_Ax1 > theFirstAxis, const double theFirstStep, const int theFirstNumber, std::shared_ptr< GeomAPI_Ax1 > theSecondAxis, const double theSecondStep, const int theSecondNumber)
 Performs a multi translation along two axis : a different distance on each axis and a different number of times for each axis. More...
static std::shared_ptr< GeomAPI_Shape > makeMultiRotation (std::shared_ptr< GeomAPI_Shape > theSourceShape, std::shared_ptr< GeomAPI_Ax1 > theAxis, const int theNumber)
 Performs a multi rotation along one axis and a number of times. More...
static std::shared_ptr< GeomAPI_Shape > makeMultiRotation (std::shared_ptr< GeomAPI_Shape > theSourceShape, std::shared_ptr< GeomAPI_Ax1 > theAxis, const double theStep, const int theNumber)
 Performs a multi rotation along one axis, at a step and a number of times. More...
static std::shared_ptr< GeomAPI_Shape > makeConeSegment (const double theRMin1, const double theRMax1, const double theRMin2, const double theRMax2, const double theZ, const double theStartPhi, const double theDeltaPhi)
 Creates a cone segment using standard GDML parameters. More...
◆ makeBox() [1/2]
std::shared_ptr< GeomAPI_Shape > GeomAlgoAPI_ShapeAPI::GeomAlgoAPI_ShapeAPI::makeBox ( const double  theDx,
const double  theDy,
const double  theDz
theDxThe dimension on X
theDyThe dimension on Y
theDzThe dimension on Z
a shape
◆ makeBox() [2/2]
std::shared_ptr< GeomAPI_Shape > GeomAlgoAPI_ShapeAPI::GeomAlgoAPI_ShapeAPI::makeBox ( std::shared_ptr< GeomAPI_Pnt >  theFirstPoint,
theFirstPointOne extermity of the diagonal
theSecondPointThe other extremity of the diagonal
a shape
◆ makeCylinder() [1/4]
std::shared_ptr< GeomAPI_Shape > GeomAlgoAPI_ShapeAPI::GeomAlgoAPI_ShapeAPI::makeCylinder ( std::shared_ptr< GeomAPI_Pnt >  theBasePoint,
double  theRadius,
double  theHeight
theBasePointThe center of the lower base of the cylinder
theEdgeThe axis of the cylinder
theRadiusThe radius of the cylinder
theHeightThe height of the cylinder
◆ makeCylinder() [2/4]
double  theRadius,
double  theHeight,
double  theAngle
theAngleThe angle defining the portion
◆ makeCylinder() [3/4]
std::shared_ptr< GeomAPI_Shape > GeomAlgoAPI_ShapeAPI::GeomAlgoAPI_ShapeAPI::makeCylinder ( double  theRadius,
double  theHeight
◆ makeCylinder() [4/4]
double  theHeight,
double  theAngle
◆ makeSphere() [1/2]
std::shared_ptr< GeomAPI_Shape > GeomAlgoAPI_ShapeAPI::GeomAlgoAPI_ShapeAPI::makeSphere ( std::shared_ptr< GeomAPI_Pnt >  theCenterPoint,
double  theRadius
theCenterPointThe center of the sphere
theRadiusThe radius of the sphere
◆ makeSphere() [2/2]
std::shared_ptr< GeomAPI_Shape > GeomAlgoAPI_ShapeAPI::GeomAlgoAPI_ShapeAPI::makeSphere ( double  theRadius)
◆ makeTorus() [1/2]
std::shared_ptr< GeomAPI_Shape > GeomAlgoAPI_ShapeAPI::GeomAlgoAPI_ShapeAPI::makeTorus ( std::shared_ptr< GeomAPI_Pnt >  theBasePoint,
double  theRadius,
theBasePointThe center of the torus
theEdgeThe axis of the torus
theRadiusThe radius of the torus
theRingRadiusThe ring radius of the torus
◆ makeTorus() [2/2]
std::shared_ptr< GeomAPI_Shape > GeomAlgoAPI_ShapeAPI::GeomAlgoAPI_ShapeAPI::makeTorus ( double  theRadius,
◆ makeCone() [1/2]
std::shared_ptr< GeomAPI_Shape > GeomAlgoAPI_ShapeAPI::GeomAlgoAPI_ShapeAPI::makeCone ( std::shared_ptr< GeomAPI_Pnt >  theBasePoint,
double  theHeight
theBasePointThe center of the lower base of the cone
theEdgeThe axis of the cone
theBaseRadiusThe base radius of the cone
theTopRadiusThe top radius of the cone
theHeightThe height of the cone
◆ makeCone() [2/2]
std::shared_ptr< GeomAPI_Shape > GeomAlgoAPI_ShapeAPI::GeomAlgoAPI_ShapeAPI::makeCone ( double  theBaseRadius,
double  theHeight
◆ makeTranslation() [1/3]
std::shared_ptr< GeomAPI_Shape > GeomAlgoAPI_ShapeAPI::GeomAlgoAPI_ShapeAPI::makeTranslation ( std::shared_ptr< GeomAPI_Shape >  theSourceShape,
theSourceShapeShape to be moved
theAxisMovement axis
theDistanceMovement distance
a shape
◆ makeTranslation() [2/3]
const double  theDx,
const double  theDy,
const double  theDz
theDxMovement dimension on X
theDyMovement dimension on Y
theDzMovement dimension on Z
a shape
◆ makeTranslation() [3/3]
theStartPointMovement start point
theEndPointMovement end point
a shape
◆ makeRotation() [1/2]
std::shared_ptr< GeomAPI_Shape > GeomAlgoAPI_ShapeAPI::GeomAlgoAPI_ShapeAPI::makeRotation ( std::shared_ptr< GeomAPI_Shape >  theSourceShape,
theSourceShapeShape to be rotated
theAngleMovement angle
a shape
◆ makeRotation() [2/2]
theCenterPointMovement center point
a shape
◆ makeSymmetry() [1/3]
std::shared_ptr< GeomAPI_Shape > GeomAlgoAPI_ShapeAPI::GeomAlgoAPI_ShapeAPI::makeSymmetry ( std::shared_ptr< GeomAPI_Shape >  theSourceShape,
theSourceShapeShape be symmetrized
thePointPoint of symmetry
◆ makeSymmetry() [2/3]
theAxisAxis of symmetry
◆ makeSymmetry() [3/3]
thePlanePlane of symmetry
◆ makeScale() [1/2]
std::shared_ptr< GeomAPI_Shape > GeomAlgoAPI_ShapeAPI::GeomAlgoAPI_ShapeAPI::makeScale ( std::shared_ptr< GeomAPI_Shape >  theSourceShape,
theSourceShapeShape be scaled
theCenterPointPoint of scale
theScaleFactorFactor of scale
◆ makeScale() [2/2]
theScaleFactorXFactor of scale in X
theScaleFactorYFactor of scale in Y
theScaleFactorZFactor of scale in Z
◆ makeMultiTranslation() [1/2]
std::shared_ptr< GeomAPI_Shape > GeomAlgoAPI_ShapeAPI::GeomAlgoAPI_ShapeAPI::makeMultiTranslation ( std::shared_ptr< GeomAPI_Shape >  theSourceShape,
const int  theNumber
theStepMovement step
theNumberMovement number
a shape
◆ makeMultiTranslation() [2/2]
theFirstAxisFirst movement axis
theFirstStepFirst movement step
theFirstNumberFirst movement number
theSecondAxisFirst movement axis
theSecondStepFirst movement step
theSecondNumberFirst movement number
a shape
◆ makeMultiRotation() [1/2]
std::shared_ptr< GeomAPI_Shape > GeomAlgoAPI_ShapeAPI::GeomAlgoAPI_ShapeAPI::makeMultiRotation ( std::shared_ptr< GeomAPI_Shape >  theSourceShape,
const int  theNumber
[in]theSourceShapeShape to be rotated
[in]theAxisAxis for the rotation
[in]theNumberNumber of copies
◆ makeMultiRotation() [2/2]
const int  theNumber
[in]theStepAngle for each rotation
◆ makeConeSegment()
std::shared_ptr< GeomAPI_Shape > GeomAlgoAPI_ShapeAPI::GeomAlgoAPI_ShapeAPI::makeConeSegment ( const double  theRMin1,
const double  theZ,
theRMin1Inner radius at base of cone
theRMax1Outer radius at base of cone
theRMin2Inner radius at top of cone
theRMax2Outer radius at top of cone
theZHeight of cone segment
theStartPhiStart angle of the segment
theDeltaPhiAngle of the segment
