Realization of Open CASCADE application abstraction. More...
#include <Model_Application.h>
| DEFINE_STANDARD_RTTIEXT (Model_Application, TDocStd_Application) MODEL_EXPORT static Handle getApplication() | |
| Definition of "Handles" usage. More... | |
| MODEL_EXPORT std::shared_ptr< Model_Document > | document (const int theDocID) |
| Returns the document by the identifier. More... | |
| MODEL_EXPORT bool | hasDocument (const int theDocID) |
| Returns true if document has been created. More... | |
| MODEL_EXPORT bool | hasRoot () |
| Returns true if root document has been created. More... | |
| MODEL_EXPORT std::shared_ptr< Model_Document > | rootDocument () |
| Returns root document, if created (or null otherwise) More... | |
| MODEL_EXPORT void | deleteDocument (const int theDocID) |
| Deletes the document from the application. More... | |
| MODEL_EXPORT void | deleteAllDocuments () |
| Deletes all documents existing in the application. More... | |
| MODEL_EXPORT void | createDocument (const int theDocID) |
| Creates a new document an returns an id of this document. More... | |
| MODEL_EXPORT bool | loadDocument (const std::wstring theDocName, const int theDocID) |
| Loads document by the file name (if it is registered as load by demand) More... | |
| void | setLoadPath (std::string thePath) |
| Set path for the loaded by demand documents. More... | |
| const std::string & | loadPath () const |
| Returns the path for the loaded by demand documents. More... | |
| void | setLoadByDemand (std::wstring theID, const int theDocID) |
| Defines that specified document must be loaded by demand. More... | |
| bool | isLoadByDemand (std::wstring theID, const int theDocIndex) |
| Returns true if specified document must be loaded by demand. More... | |
| int | generateDocumentId () |
| produces new unique identifier of the document More... | |
| Standard_CString | ResourcesName () |
| Return name of resource (i.e. "Standard") More... | |
| virtual void | Formats (TColStd_SequenceOfExtendedString &theFormats) |
| Return format (i.e "MDTV-Standard") More... | |
| Model_Application () | |
| Constructor Use method GetInstance() method to obtain the static instance of the object (or derive your own application) More... | |
Class for internal use only.
Application supports the formats and document management. It is uses OCAF-lke architecture and just implements specific features of the module.
| Model_Application::Model_Application | ( | ) |
| Model_Application::DEFINE_STANDARD_RTTIEXT | ( | Model_Application | , |
| TDocStd_Application | |||
| Model_Application | is the class name that is covered by the OCCT Handle Returns the application: one per process |
| std::shared_ptr< Model_Document > Model_Application::document | ( | const int | theDocID | ) |
| bool Model_Application::hasDocument | ( | const int | theDocID | ) |
| bool Model_Application::hasRoot | ( | ) |
| std::shared_ptr< Model_Document > Model_Application::rootDocument | ( | ) |
| void Model_Application::deleteDocument | ( | const int | theDocID | ) |
| void Model_Application::deleteAllDocuments | ( | ) |
| void Model_Application::createDocument | ( | const int | theDocID | ) |
| theDocID | if it is zero, the root document is created |
| bool Model_Application::loadDocument | ( | const std::wstring | theDocName, |
| const int | theDocID | ||
| theDocName | name of the document file |
| theDocID | the identifier of the loaded document (to be created) |
| void Model_Application::setLoadPath | ( | std::string | thePath | ) |
| const std::string & Model_Application::loadPath | ( | ) | const |
| void Model_Application::setLoadByDemand | ( | std::wstring | theID, |
| bool Model_Application::isLoadByDemand | ( | std::wstring | theID, |
| const int | theDocIndex | ||
| int Model_Application::generateDocumentId | ( | ) |
| Standard_CString Model_Application::ResourcesName | ( | ) |
| theFormats | sequence of allowed formats for input/output |
