This is a class which provides icons of objects for object browser. More...
#include <ModuleBase_IconFactory.h>
| virtual QIcon | getIcon (ObjectPtr theObj) |
| Returns Icon for the given object. More... | |
| static ModuleBase_IconFactory * | get () |
| Returns icons factory instance. More... | |
| static QIcon | loadIcon (const QString &theValue) |
| Finds an icon for the given value. More... | |
| static QPixmap | loadPixmap (const QString &theValue) |
| Finds a pixmap for the given value. More... | |
| static QImage | loadImage (const QString &theValue) |
| Finds an image for the given value. More... | |
Static Protected Member Functions | |
| static void | setFactory (ModuleBase_IconFactory *theFactory) |
| Set the current icons factory instance. More... | |
static |
static |
The icon is loaded: firstly from qrc file, then by the icon path. If the path contains ":" , it will be treated as absolute path to the icon, or relative path from the plugin library
| theValue | an icon information |
static |
It is loaded: firstly from qrc file, then by the absolute path. If the pixmap is not loaded, it is searched in relative plugin path
| theValue | a pixmap information |
static |
It is loaded: firstly from qrc file, then by the absolute path. If the image is not loaded, it is searched in relative plugin path
| theValue | a image information |
staticprotected |
| theFactory | a new factory |
