PartSet_IconFactory Class Reference
This is a class is redefined in order to provide icons of objects for object browser specific for PartSetModule. More...
#include <PartSet_IconFactory.h>
Inheritance diagram for PartSet_IconFactory:
 PartSet_IconFactory (PartSet_Module *theModule)
virtual QIcon getIcon (ObjectPtr theObj)
 Returns Icon for the given object. More...
virtual void processEvent (const std::shared_ptr< Events_Message > &theMessage)
 Event Listener method. More...
virtual EVENTS_EXPORT bool groupMessages ()
 Listener that needs mostly grouped messages received returns true in this method. More...
static ModuleBase_IconFactory * get ()
 Returns icons factory instance. More...
static QIcon loadIcon (const QString &theValue)
 Finds an icon for the given value. More...
static QPixmap loadPixmap (const QString &theValue)
 Finds a pixmap for the given value. More...
static QImage loadImage (const QString &theValue)
 Finds an image for the given value. More...
void groupWhileFlush (const std::shared_ptr< Events_Message > &theMessage)
 Allows to group messages while they are flushed (for flush for groupMessages=true listeners) More...
EVENTS_EXPORT void flushGrouped (const Events_ID &theID)
 Sends myGroups on flush finish. More...
static void setFactory (ModuleBase_IconFactory *theFactory)
 Set the current icons factory instance. More...
◆ PartSet_IconFactory()
PartSet_IconFactory::PartSet_IconFactory ( PartSet_Module *  theModule)
◆ getIcon()
QIcon PartSet_IconFactory::getIcon ( ObjectPtr  theObj)
theObjan object
Reimplemented from ModuleBase_IconFactory.
◆ processEvent()
void PartSet_IconFactory::processEvent ( const std::shared_ptr< Events_Message > &  theMessage)
theMessagean event message
Implements Events_Listener.
◆ get()
ModuleBase_IconFactory * ModuleBase_IconFactory::get ( )
◆ loadIcon()
QIcon ModuleBase_IconFactory::loadIcon ( const QString &  theValue)
The icon is loaded: firstly from qrc file, then by the icon path. If the path contains ":" , it will be treated as absolute path to the icon, or relative path from the plugin library
theValuean icon information
a loaded or empty icon
◆ loadPixmap()
QPixmap ModuleBase_IconFactory::loadPixmap ( const QString &  theValue)
It is loaded: firstly from qrc file, then by the absolute path. If the pixmap is not loaded, it is searched in relative plugin path
theValuea pixmap information
a loaded or empty pixmap
◆ loadImage()
QImage ModuleBase_IconFactory::loadImage ( const QString &  theValue)
It is loaded: firstly from qrc file, then by the absolute path. If the image is not loaded, it is searched in relative plugin path
theValuea image information
◆ setFactory()
void ModuleBase_IconFactory::setFactory ( ModuleBase_IconFactory *  theFactory)
staticprotectedinherited
theFactorya new factory
◆ groupMessages()
virtual EVENTS_EXPORT bool Events_Listener::groupMessages ( )
inlinevirtualinherited
In this case during the message is flushed, all the new messages are grouped, not sended immideately and then sent in the end of flush.
Reimplemented in SketchPlugin_OverConstraintsResolver, and SketchSolver_Manager.
◆ groupWhileFlush()
void Events_Listener::groupWhileFlush ( const std::shared_ptr< Events_Message > &  theMessage)
◆ flushGrouped()
void Events_Listener::flushGrouped ( const Events_ID &  theID)
