PartSet_PreviewSketchPlane Class Reference
Visualization of 2D-bluebrint' accessories: translucent rectangular substrate, basis axes, grid. More...
#include <PartSet_PreviewSketchPlane.h>
enum  GridSnappingMode { Off , SnapAnyway , SnapInProximity }
 PartSet_PreviewSketchPlane (PartSet_SketcherMgr *theManager)
 PartSet_PreviewSketchPlane (const PartSet_PreviewSketchPlane &)=delete
PartSet_PreviewSketchPlane & operator= (const PartSet_PreviewSketchPlane &)=delete
void savePreferencesIntoSketchData (std::shared_ptr< ModelAPI_CompositeFeature > theSketch) const
void saveRectangularGridPreferencesIntoSketchData (std::shared_ptr< ModelAPI_CompositeFeature > theSketch) const
void saveCircularGridPreferencesIntoSketchData (std::shared_ptr< ModelAPI_CompositeFeature > theSketch) const
void setCSAndSize (const gp_Ax3 &theCS, double theSize)
 Updates CS (coordinate system), dimensions and accessories' configuration. More...
bool setAllUsingSketch (std::shared_ptr< ModelAPI_CompositeFeature > theSketch)
 Updates CS (coordinate system), dimensions and accessories' configuration. Updates visibility of accessories - visibility preferences are also retrieved from theSketch data. If sketch data contains uninitialized grid steps, the method assigns default ones. For rectangular grid default step is a fraction of corresponding dimension. More...
bool reconfigureGrid ()
 Call it, after any preference of grid, except grid type, is changed using methods of this instance. Updates grid configuration. Does not affect visibility of grid. More...
bool reconfigureGridUsingSketch (std::shared_ptr< ModelAPI_CompositeFeature > theSketch)
 Call it, after any preference of grid is changed in theSketch data directly. Updates grid configuration. Updates grid visibility - preference is also retrieved from theSketch data. If sketch data contains uninitialized grid steps, the method assigns default ones. For rectangular grid default step is a fraction of corresponding dimension. More...
bool showAxes (bool theShow)
bool showSubstrate (bool theShow)
bool setGridType (PartSet_Tools::SketchPlaneGridType::Enum theType)
 Changes grid type and reconfigures grid. Shows grid, if theType != SketchPlaneGridType::No. More...
PartSet_Tools::SketchPlaneGridType::Enum getGridType () const
void hideAll ()
 Hides all accessories. More...
std::pair< double, double > getDimensions () const
 Substrate dimensions. Substrate dimension coincides with one of the sketch face, if the latter is non-zero. More...
bool isShowAxes () const
bool isShowSubstrate () const
bool isShowGrid () const
GridSnappingMode getGridSnappingMode () const
void setGridSnappingMode (GridSnappingMode theMode)
void resetRectangularGrid ()
 Sets default steps and zero offsets. More...
void setRectangularGridStepX (double theStepX)
void setRectangularGridStepY (double theStepY)
std::pair< double, double > getRectangularGridSteps () const
void setRectangularGridOffsetX (double theOffsetX)
void setRectangularGridOffsetY (double theOffsetY)
void setRectangularGridOffsetA (double theOffsetAngle)
std::pair< std::pair< double, double >, double > getRectangularGridOffsets () const
int getRectangularGridDimOfNodeSpace () const
void resetCircularGrid ()
void setCircularGridRadialStep (double theStep)
void setCircularGridNumOfAngularSegments (int theNum)
std::pair< double, int > getCircularGrid_dR_and_NAS () const
void setCircularGridOffsetX (double theOffset)
void setCircularGridOffsetY (double theOffset)
void setCircularGridOffsetA (double theOffset)
std::pair< std::pair< double, double >, double > getCircularGridOffsets () const
int getCircularGridDimOfNodeSpace () const
void setUseSizeOfView (const bool isUseSizeOfView)
bool isUseSizeOfView () const
static bool SketchAccessoryDbg ()
static bool SketchAccessoryDbg (const QString &theString)
static bool SketchAccessoryDbg (const char *theString)
static bool SketchAccessoryDbg (const char *theCSDescription, const gp_Ax3 &theCS)
static bool SketchAccessoryDbg (const char *theCSDescription, const gp_Pnt &thePoint)
static bool SketchAccessoryDbg (const char *theCSDescription, const gp_Trsf &theMatrix)
static double defaultSketchSize ()
Static Public Attributes
static const double DEFAULT_RELATIVE_STEP_INVERSE = 20
static const int DEFAULT_NUM_OF_ANGULAR_SECTIONS = 18
static const int SNAP_PROXIMITY_P = 10
All methods do not modify sketch data, unless otherwise is stated.
◆ PartSet_PreviewSketchPlane()
PartSet_PreviewSketchPlane::PartSet_PreviewSketchPlane ( PartSet_SketcherMgr *  theManager)
theManagermust not be nullptr.
◆ setCSAndSize()
void PartSet_PreviewSketchPlane::setCSAndSize ( const gp_Ax3 &  theCS,
double  theSize
◆ setAllUsingSketch()
bool PartSet_PreviewSketchPlane::setAllUsingSketch ( std::shared_ptr< ModelAPI_CompositeFeature >  theSketch)
true, on success (if theSketch is valid).
◆ reconfigureGrid()
bool PartSet_PreviewSketchPlane::reconfigureGrid ( )
true, if grid is successfully configured.
◆ reconfigureGridUsingSketch()
bool PartSet_PreviewSketchPlane::reconfigureGridUsingSketch ( std::shared_ptr< ModelAPI_CompositeFeature >  theSketch)
◆ showAxes()
bool PartSet_PreviewSketchPlane::showAxes ( bool  theShow)
true on success.
◆ showSubstrate()
bool PartSet_PreviewSketchPlane::showSubstrate ( bool  theShow)
true on success.
◆ setGridType()
bool PartSet_PreviewSketchPlane::setGridType ( PartSet_Tools::SketchPlaneGridType::Enum  theType)
true on success.
◆ hideAll()
void PartSet_PreviewSketchPlane::hideAll ( )
◆ getDimensions()
std::pair< double, double > PartSet_PreviewSketchPlane::getDimensions ( ) const
◆ resetRectangularGrid()
void PartSet_PreviewSketchPlane::resetRectangularGrid ( )
◆ resetCircularGrid()
void PartSet_PreviewSketchPlane::resetCircularGrid ( )
◆ defaultSketchSize()
double PartSet_PreviewSketchPlane::defaultSketchSize ( )
Default size from Config_PropManager (if > 0), or DEFAULT_SKETCH_SIZE.
