PlaneGCSSolver_ScalarArrayWrapper Class Reference
Wrapper providing operations with array of PlaneGCS scalars. More...
#include <PlaneGCSSolver_ScalarArrayWrapper.h>
Inheritance diagram for PlaneGCSSolver_ScalarArrayWrapper:
 PlaneGCSSolver_ScalarArrayWrapper (const GCS::VEC_pD &theParam)
int size () const
 Size of array. More...
const GCS::VEC_pD & array () const
 Return array of PlaneGCS parameters. More...
void setArray (const GCS::VEC_pD &theParams)
 Set array of parameters. More...
virtual SketchSolver_EntityType type () const
 Return type of current entity. More...
void setExternal (bool theExternal)
 Change flag indicating the entity cannot be changed in the solver. More...
bool isExternal () const
 Return the External flag. More...
void setAdditionalAttributes (const std::map< std::string, EntityWrapperPtr > &theAttribues)
 Store names of attributes and their values if necessary. More...
const std::map< std::string, EntityWrapperPtr > & additionalAttributes () const
 Return the list of additional attributes. More...
virtual bool update (std::shared_ptr< ModelAPI_Attribute > theAttribute)
 Update entity by the values of theAttribute. More...
GCS::VEC_pD myValue
 list of pointers to values provided by the storage More...
◆ size()
int PlaneGCSSolver_ScalarArrayWrapper::size ( ) const
Size of array.
◆ array()
const GCS::VEC_pD & PlaneGCSSolver_ScalarArrayWrapper::array ( ) const
◆ setArray()
void PlaneGCSSolver_ScalarArrayWrapper::setArray ( const GCS::VEC_pD &  theParams)
◆ type()
virtual SketchSolver_EntityType PlaneGCSSolver_ScalarArrayWrapper::type ( ) const
Implements PlaneGCSSolver_EntityWrapper.
◆ update()
bool PlaneGCSSolver_ScalarArrayWrapper::update ( std::shared_ptr< ModelAPI_Attribute >  theAttribute)
true if any value of attribute is not equal to the stored in the entity
Reimplemented from PlaneGCSSolver_EntityWrapper.
◆ setExternal()
void PlaneGCSSolver_EntityWrapper::setExternal ( bool  theExternal)
◆ isExternal()
bool PlaneGCSSolver_EntityWrapper::isExternal ( ) const
◆ setAdditionalAttributes()
void PlaneGCSSolver_EntityWrapper::setAdditionalAttributes ( const std::map< std::string, EntityWrapperPtr > &  theAttribues)
◆ additionalAttributes()
const std::map< std::string, EntityWrapperPtr > & PlaneGCSSolver_EntityWrapper::additionalAttributes ( ) const
◆ myValue
GCS::VEC_pD PlaneGCSSolver_ScalarArrayWrapper::myValue
