Collects all sketch solver error' codes as inline static functions. More...
#include <SketchSolver_Error.h>
| static const std::string & | CONSTRAINTS () |
| The value parameter for the constraint. More... | |
| static const std::string & | INFINITE_LOOP () |
| Cyclic dependency of copied features with their originals. More... | |
| static const std::string & | NEED_OBJECT_NOT_FEATURE () |
| Constraints should use objects instead of features as attributes. More... | |
| static const std::string & | NO_COINCIDENT_POINTS () |
| The entities need to have shared point, but they have not. More... | |
| static const std::string & | NOT_INITIALIZED () |
| Attribute of a feature is not initialized. More... | |
| static const std::string & | INCORRECT_ATTRIBUTE () |
| Constraint has wrong attributes. More... | |
| static const std::string & | INCORRECT_TANGENCY_ATTRIBUTE () |
| Tangency constraint has wrong attributes. More... | |
| static const std::string & | INCORRECT_MIRROR_ATTRIBUTE () |
| Mirror constraint has wrong attributes. More... | |
| static const std::string & | ALREADY_FIXED () |
| Entity is already fixed. More... | |
| static const std::string & | TANGENCY_FAILED () |
| Tangency constraint has been built with wrong attributes (for example, line and arc have two coincident points) More... | |
| static const std::string & | SOLVESPACE_CRASH () |
| Crash in SolveSpace. More... | |
| static const std::string & | WRONG_CONSTRAINT_TYPE () |
| Constraint has wrong type. More... | |
| static const std::string & | DEGENERATED_GEOMETRY () |
| Sketch contains degenerated geometry. More... | |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
