Performs high-level operations to solve sketch in SolveSpace.
More...
#include <SolveSpaceSolver_Solver.h>
| void | setParameters (Slvs_Param *theParameters, int theSize) |
| | Change array of parameters. More...
| void | setEntities (Slvs_Entity *theEntities, int theSize) |
| | Change array of entities. More...
| void | setConstraints (Slvs_Constraint *theConstraints, int theSize) |
| | Change array of constraints. More...
| void | setDraggedParameters (const Slvs_hParam *theDragged) |
| | Store the parameters of the point which was moved by user. More...
| virtual SketchSolver_SolveStatus | solve () |
| | Solve the set of equations. More...
| virtual void | prepare () |
| | Prepare for solving. Store initial values of parameters for undo. More...
| virtual void | undo () |
| | Revert solution to initial values. More...
| virtual bool | isConflicting (const ConstraintID &theConstraint) const |
| | Check the constraint is conflicted with others. More...
| virtual int | dof () const |
| | Degrees of freedom. More...
◆ setParameters()
| void SolveSpaceSolver_Solver::setParameters |
Slvs_Param * |
theParameters, |
int |
theSize |
- Parameters
| [in] | theParameters | pointer to the array of parameters |
| [in] | theSize | size of this array |
◆ setEntities()
| void SolveSpaceSolver_Solver::setEntities |
Slvs_Entity * |
theEntities, |
int |
theSize |
- Parameters
| [in] | theEntities | pointer to the array of entities |
◆ setConstraints()
| void SolveSpaceSolver_Solver::setConstraints |
Slvs_Constraint * |
theConstraints, |
int |
theSize |
- Parameters
| [in] | theConstraints | pointer to the array of constraints |
◆ setDraggedParameters()
| void SolveSpaceSolver_Solver::setDraggedParameters |
const Slvs_hParam * |
theDragged | ) |
The solver will watch this items to be constant
- Parameters
| [in] | theDragged | list of parameters (not more than 4) which should not be changed during solving |
◆ solve()
| SketchSolver_SolveStatus SolveSpaceSolver_Solver::solve |
- Returns
- identifier whether solution succeeded
◆ prepare()
| void SolveSpaceSolver_Solver::prepare |
◆ undo()
| void SolveSpaceSolver_Solver::undo |
◆ isConflicting()
| bool SolveSpaceSolver_Solver::isConflicting |
const ConstraintID & |
theConstraint | ) |
const |
◆ dof()
| int SolveSpaceSolver_Solver::dof |
const |
