XAO::BrepGeometry Class Reference
Representation of a BRep Geometry. More...
#include <XAO_BrepGeometry.hxx>
Inheritance diagram for XAO::BrepGeometry:
 BrepGeometry ()
 Default Constructor. More...
 BrepGeometry (const std::string &name)
virtual XAO::Format getFormat ()
 Gets the format of the geometry. More...
virtual const std::string getShapeString ()
 Gets the shape as a string. More...
virtual void setShapeString (const std::string &shape)
 Sets the shape from a string. More...
virtual void writeShapeFile (const std::string &fileName)
 Writes shape to a file. More...
virtual void readShapeFile (const std::string &fileName)
 Reads shape from a file. More...
TopoDS_Shape getTopoDS_Shape ()
 Gets the shape as a TopoDS_Shape. More...
void setTopoDS_Shape (const TopoDS_Shape &shape)
 Sets the shape from a TopoDS_Shape. More...
void getEdgeVertices (int edgeIndex, int &vertexA, int &vertexB)
 Gives the two extrimities of an edge. More...
int countFaceWires (int faceIndex)
 Gets the number of wires of a face (including holes). More...
std::vector< int > getFaceEdges (int faceIndex, int wireIndex)
 Gets the indices of the wires of the face. More...
int countSolidShells (int solidIndex)
 Gets the number of shells of a solid (including cavities). More...
std::vector< int > getSolidFaces (int solidIndex, int shellIndex)
 Gets the indices of the shells of the solids. More...
void getVertexXYZ (int vertexIndex, double &xCoord, double &yCoord, double &zCoord)
 Gets the coordinates of a vertex. More...
double getEdgeLength (int index)
 Gets the length of an edge. More...
double getFaceArea (int index)
 Gets the are of a face. More...
double getSolidVolume (int index)
 Gets the volume of a solid. More...
int getVertexID (int index)
 Gets the ID of a vertex. More...
int getEdgeID (int index)
 Gets the ID of an edge. More...
int getFaceID (int index)
 Gets the ID of a face. More...
int getSolidID (int index)
 Gets the ID of a solid. More...
void setVertexID (int index, int id)
 Sets the ID of a vertex. More...
void setEdgeID (int index, int id)
 Sets the ID of an edge. More...
void setFaceID (int index, int id)
 Sets the ID of a face. More...
void setSolidID (int index, int id)
 Sets the ID of a solid. More...
int findVertex (int id)
 Finds a vertex with its ID. More...
int findEdge (int id)
 Finds an edge with its ID. More...
int findFace (int id)
 Finds a face with its ID. More...
int findSolid (int id)
 Finds a solid with its ID. More...
const std::string findVertexName (int id)
 Finds the name of a vertex with its ID. More...
const std::string findEdgeName (int id)
 Finds the name of an edge with its ID. More...
const std::string findFaceName (int id)
 Finds the name of a face with its ID. More...
const std::string findSolidName (int id)
 Finds the name of a solid with its ID. More...
void changeVertexName (int id, const std::string &name)
 Changes the name of a vertex. More...
void changeEdgeName (int id, const std::string &name)
 Changes the name of an edge. More...
void changeFaceName (int id, const std::string &name)
 Changes the name of a face. More...
void changeSolidName (int id, const std::string &name)
 Changes the name of a solid. More...
static Geometry * createGeometry (XAO::Format format)
 Creates a geometry. More...
name the name of the geometry.
Creates a geometry.
the created geometry.
const std::string getName ()
 Gets the name of the geometry. More...
 Sets the name of the geometry. More...
int countElements (XAO::Dimension dim) const
int countVertices () const
int countEdges () const
int countFaces () const
int countSolids () const
void setCountVertices (int nb)
void setCountEdges (int nb)
void setCountFaces (int nb)
void setCountSolids (int nb)
const std::string getVertexName (int index)
const std::string getEdgeName (int index)
const std::string getFaceName (int index)
const std::string getSolidName (int index)
void setVertexName (int index, const std::string &name)
void setEdgeName (int index, const std::string &name)
void setFaceName (int index, const std::string &name)
void setSolidName (int index, const std::string &name)
bool hasVertexName (int index)
bool hasEdgeName (int index)
bool hasFaceName (int index)
bool hasSolidName (int index)
const std::string getVertexReference (int index)
const std::string getEdgeReference (int index)
const std::string getFaceReference (int index)
const std::string getSolidReference (int index)
const std::string getElementReference (XAO::Dimension dim, int index)
void setVertexReference (int index, const std::string &reference)
void setEdgeReference (int index, const std::string &reference)
void setFaceReference (int index, const std::string &reference)
void setSolidReference (int index, const std::string &reference)
void setVertex (int index, const std::string &name, const std::string &reference)
void setEdge (int index, const std::string &name, const std::string &reference)
void setFace (int index, const std::string &name, const std::string &reference)
void setSolid (int index, const std::string &name, const std::string &reference)
int getVertexIndexByReference (const std::string &reference)
int getEdgeIndexByReference (const std::string &reference)
int getFaceIndexByReference (const std::string &reference)
int getSolidIndexByReference (const std::string &reference)
int getElementIndexByReference (XAO::Dimension dim, const std::string &reference)
GeometricElementList::iterator begin (XAO::Dimension dim)
GeometricElementList::iterator end (XAO::Dimension dim)
bool isReadOnly ()
 Verifies if the geometry is read only. More...
void setReadOnly ()
 Sets the geometry read only. More...
std::string m_name
GeometricElementList m_vertices
GeometricElementList m_edges
GeometricElementList m_faces
GeometricElementList m_solids
bool m_readOnly
static Geometry * createGeometry (XAO::Format format, const std::string &name)
void checkReadOnly ()
◆ BrepGeometry() [1/2]
BrepGeometry::BrepGeometry ( )
◆ BrepGeometry() [2/2]
BrepGeometry::BrepGeometry ( const std::string &  name)
namethe name of the geometry.
◆ getFormat()
virtual XAO::Format XAO::BrepGeometry::getFormat ( )
Implements XAO::Geometry.
◆ getShapeString()
const std::string BrepGeometry::getShapeString ( )
◆ setShapeString()
void BrepGeometry::setShapeString ( const std::string &  shape)
shapethe shape as a string.
◆ writeShapeFile()
void BrepGeometry::writeShapeFile ( const std::string &  fileName)
fileNamethe path to the file
◆ readShapeFile()
void BrepGeometry::readShapeFile ( const std::string &  fileName)
◆ getTopoDS_Shape()
TopoDS_Shape BrepGeometry::getTopoDS_Shape ( )
the TopoDS_Shape.
◆ setTopoDS_Shape()
void BrepGeometry::setTopoDS_Shape ( const TopoDS_Shape &  shape)
shapethe TopoDS_Shape to set.
◆ getEdgeVertices()
void BrepGeometry::getEdgeVertices ( int  edgeIndex,
int &  vertexA,
int &  vertexB
edgeIndexthe index of the edge.
vertexA
vertexB
◆ countFaceWires()
int BrepGeometry::countFaceWires ( int  faceIndex)
faceIndexthe index of the face.
the number of wires.
◆ getFaceEdges()
std::vector< int > BrepGeometry::getFaceEdges ( int  faceIndex,
int  wireIndex
wireIndexthe index of the wire.
the list of wires for the given face.
◆ countSolidShells()
int BrepGeometry::countSolidShells ( int  solidIndex)
solidIndexthe index of the solid.
the number of shells.
◆ getSolidFaces()
std::vector< int > BrepGeometry::getSolidFaces ( int  solidIndex,
int  shellIndex
shellIndexthe index of the shell (for the given solid).
the list of shells for the given solid.
◆ getVertexXYZ()
void BrepGeometry::getVertexXYZ ( int  vertexIndex,
double &  xCoord,
double &  yCoord,
double &  zCoord
vertexIndexthe index of the vertex.
xCoordthe X coordinate.
yCoordthe Y coordinate.
zCoordthe Z coordinate.
◆ getEdgeLength()
double BrepGeometry::getEdgeLength ( int  index)
indexthe index of the edge.
the length of the edge.
◆ getFaceArea()
double BrepGeometry::getFaceArea ( int  index)
indexthe index of a face.
the area of the face.
◆ getSolidVolume()
double BrepGeometry::getSolidVolume ( int  index)
indexthe index of the solid.
the volume of the solid.
◆ getVertexID()
int BrepGeometry::getVertexID ( int  index)
indexthe index of the vertex.
the ID of the vertex.
◆ getEdgeID()
int BrepGeometry::getEdgeID ( int  index)
the ID of the edge.
◆ getFaceID()
int BrepGeometry::getFaceID ( int  index)
indexthe index of the face.
the ID of the face.
◆ getSolidID()
int BrepGeometry::getSolidID ( int  index)
the ID of the solid.
◆ setVertexID()
void BrepGeometry::setVertexID ( int  index,
int  id
indexthe index of the vertex to set.
idthe id to set.
◆ setEdgeID()
void BrepGeometry::setEdgeID ( int  index,
int  id
indexthe index of the edge to set.
idthe id to set.
◆ setFaceID()
void BrepGeometry::setFaceID ( int  index,
int  id
indexthe index of the face to set.
idthe id to set.
◆ setSolidID()
void BrepGeometry::setSolidID ( int  index,
int  id
indexthe index of the solid to set.
idthe id to set.
◆ findVertex()
int BrepGeometry::findVertex ( int  id)
idthe ID of the vertex.
◆ findEdge()
int BrepGeometry::findEdge ( int  id)
idthe ID of the edge.
◆ findFace()
int BrepGeometry::findFace ( int  id)
idthe ID of the face.
◆ findSolid()
int BrepGeometry::findSolid ( int  id)
idthe ID of the solid.
th index of the solid.
◆ findVertexName()
const std::string BrepGeometry::findVertexName ( int  id)
the name of the vertex.
◆ findEdgeName()
const std::string BrepGeometry::findEdgeName ( int  id)
the name of the edge.
◆ findFaceName()
const std::string BrepGeometry::findFaceName ( int  id)
the name of the face.
◆ findSolidName()
const std::string BrepGeometry::findSolidName ( int  id)
the name of the solid.
◆ changeVertexName()
void BrepGeometry::changeVertexName ( int  id,
namethe name to set.
◆ changeEdgeName()
void BrepGeometry::changeEdgeName ( int  id,
◆ changeFaceName()
void BrepGeometry::changeFaceName ( int  id,
◆ changeSolidName()
void BrepGeometry::changeSolidName ( int  id,
◆ createGeometry()
Geometry * Geometry::createGeometry ( XAO::Format  format)
Creates a geometry.
formatthe format of the geometry.
◆ getName()
const std::string XAO::Geometry::getName ( )
◆ setName()
void XAO::Geometry::setName ( const std::string &  name)
◆ isReadOnly()
bool XAO::Geometry::isReadOnly ( )
true if the geometry is read only.
◆ setReadOnly()
void XAO::Geometry::setReadOnly ( )
