Creates a geometry.
- Returns
- the created geometry.
std::string | m_name |
GeometricElementList | m_vertices |
GeometricElementList | m_edges |
GeometricElementList | m_faces |
GeometricElementList | m_solids |
bool | m_readOnly |
void | checkReadOnly () |
static Geometry * | createGeometry (XAO::Format format, const std::string &name) |
| virtual | ~Geometry () |
| | Destructor. More...
| const std::string | getName () |
| | Gets the name of the geometry. More...
| void | setName (const std::string &name) |
| | Sets the name of the geometry. More...
| virtual XAO::Format | getFormat ()=0 |
| | Gets the format of the geometry. More...
| virtual const std::string | getShapeString ()=0 |
| virtual void | setShapeString (const std::string &shape)=0 |
| virtual void | writeShapeFile (const std::string &fileName)=0 |
| virtual void | readShapeFile (const std::string &fileName)=0 |
int | countElements (XAO::Dimension dim) const |
int | countVertices () const |
int | countEdges () const |
int | countFaces () const |
int | countSolids () const |
void | setCountVertices (int nb) |
void | setCountEdges (int nb) |
void | setCountFaces (int nb) |
void | setCountSolids (int nb) |
const std::string | getVertexName (int index) |
const std::string | getEdgeName (int index) |
const std::string | getFaceName (int index) |
const std::string | getSolidName (int index) |
void | setVertexName (int index, const std::string &name) |
void | setEdgeName (int index, const std::string &name) |
void | setFaceName (int index, const std::string &name) |
void | setSolidName (int index, const std::string &name) |
bool | hasVertexName (int index) |
bool | hasEdgeName (int index) |
bool | hasFaceName (int index) |
bool | hasSolidName (int index) |
const std::string | getVertexReference (int index) |
const std::string | getEdgeReference (int index) |
const std::string | getFaceReference (int index) |
const std::string | getSolidReference (int index) |
const std::string | getElementReference (XAO::Dimension dim, int index) |
void | setVertexReference (int index, const std::string &reference) |
void | setEdgeReference (int index, const std::string &reference) |
void | setFaceReference (int index, const std::string &reference) |
void | setSolidReference (int index, const std::string &reference) |
void | setVertex (int index, const std::string &name, const std::string &reference) |
void | setEdge (int index, const std::string &name, const std::string &reference) |
void | setFace (int index, const std::string &name, const std::string &reference) |
void | setSolid (int index, const std::string &name, const std::string &reference) |
int | getVertexIndexByReference (const std::string &reference) |
int | getEdgeIndexByReference (const std::string &reference) |
int | getFaceIndexByReference (const std::string &reference) |
int | getSolidIndexByReference (const std::string &reference) |
int | getElementIndexByReference (XAO::Dimension dim, const std::string &reference) |
GeometricElementList::iterator | begin (XAO::Dimension dim) |
GeometricElementList::iterator | end (XAO::Dimension dim) |
| bool | isReadOnly () |
| | Verifies if the geometry is read only. More...
| void | setReadOnly () |
| | Sets the geometry read only. More...
Base class for geometries.
