MeshCut_Globals.hxx File Reference
#include "MeshCut_Maillage.hxx"
#include <map>
Include dependency graph for MeshCut_Globals.hxx:
namespace  MESHCUT
Variables
std::map< std::string, int > MESHCUT::intersections
 Table des points d'intersection calculés. More...
int MESHCUT::indexNouvellesMailles
int MESHCUT::indexNouveauxNoeuds
int MESHCUT::offsetMailles
std::string MESHCUT::str_id_GMplus
std::string MESHCUT::str_id_GMmoins
Maillage * MESHCUT::MAILLAGE1
Maillage * MESHCUT::MAILLAGE2
std::vector< float > MESHCUT::newXX
std::vector< float > MESHCUT::newYY
std::vector< float > MESHCUT::newZZ
std::map< TYPE_MAILLE, std::vector< int > > MESHCUT::newCNX
std::map< TYPE_MAILLE, int > MESHCUT::cptNouvellesMailles
std::map< TYPE_MAILLE, std::vector< int > > MESHCUT::GMplus
std::map< TYPE_MAILLE, std::vector< int > > MESHCUT::GMmoins
std::vector< int > MESHCUT::cutTetras
float * MESHCUT::DNP
 Distance Noeud Plan. More...
int * MESHCUT::POSN
 Version -1/0/+1 du précédent, selon epsilon. More...
std::string MESHCUT::str_id_maillagenew
float MESHCUT::normale [3]
float MESHCUT::pointPlan [3]
 Définition du plan de coupe. More...
float MESHCUT::d
 coefficient constant de l'équation du plan de coupe More...
float MESHCUT::epsilon
 distance en dessous de laquelle un point est considéré comme appartenant au plan de coupe More...
bool MESHCUT::debug
int MESHCUT::Naretes
