SMESH_Homard.idl
1// Copyright (C) 2011-2026 CEA, EDF
20#ifndef _SMESH_HOMARD_IDL
21#define _SMESH_HOMARD_IDL
23#include "SMESH_Mesh.idl"
24
25#include "SALOME_Exception.idl"
26#include "SALOMEDS.idl"
27
28module SMESHHOMARD
29{
30 typedef sequence<double> double_array;
31 typedef sequence<double> extrema;
32 typedef sequence<string> ListGroupType;
33 typedef sequence<string> ListBoundaryGroupType;
34 typedef sequence<string> listeBoundarys;
35
36 interface HOMARD_Boundary : SALOME::GenericObj
37 {
38 // Generalites
39 void SetName(in string Name) raises (SALOME::SALOME_Exception);
40 string GetName() raises (SALOME::SALOME_Exception);
41
42 // Caracteristiques
43 void SetType (in long Type) raises (SALOME::SALOME_Exception);
44 long GetType() raises (SALOME::SALOME_Exception);
45
46 void SetDataFile(in string DataFile) raises (SALOME::SALOME_Exception);
47 string GetDataFile() raises (SALOME::SALOME_Exception);
48
49 void SetMeshName(in string MeshName) raises (SALOME::SALOME_Exception);
50 string GetMeshName() raises (SALOME::SALOME_Exception);
51
52 void SetCylinder (in double Xcentre, in double Ycentre, in double Zcentre,
53 in double Xaxe, in double Yaxe, in double Zaxe, in double rayon)
54 raises (SALOME::SALOME_Exception);
55
56 void SetSphere (in double Xcentre, in double Ycentre, in double Zcentre, in double rayon)
57 raises (SALOME::SALOME_Exception);
58
59 void SetConeR (in double Xcentre1, in double Ycentre1, in double Zcentre1,
60 in double Rayon1,
61 in double Xcentre2, in double Ycentre2, in double Zcentre2,
62 in double Rayon2) raises (SALOME::SALOME_Exception);
63
64 void SetConeA(in double Xaxe, in double Yaxe, in double Zaxe, in double Angle,
65 in double Xcentre, in double Ycentre, in double ZCentre)
66 raises (SALOME::SALOME_Exception);
67
68 void SetTorus (in double Xcentre, in double Ycentre, in double Zcentre,
69 in double Xaxe, in double Yaxe, in double Zaxe,
70 in double rayonRev, in double rayonPri)
71 raises (SALOME::SALOME_Exception);
72
73 SMESHHOMARD::double_array GetCoords() raises (SALOME::SALOME_Exception);
74
75 void SetLimit (in double Xincr, in double Yincr, in double Zincr)
76 raises (SALOME::SALOME_Exception);
77 SMESHHOMARD::double_array GetLimit() raises (SALOME::SALOME_Exception);
78
79 void AddGroup(in string LeGroupe) raises (SALOME::SALOME_Exception);
80 void SetGroups(in ListGroupType ListGroup) raises (SALOME::SALOME_Exception);
81 ListGroupType GetGroups() raises (SALOME::SALOME_Exception);
82
83 string GetDumpPython() raises (SALOME::SALOME_Exception);
84 };
85
86 interface HOMARD_Cas : SALOME::GenericObj
87 {
88 void SetDirName(in string NomDir) raises (SALOME::SALOME_Exception);
89 string GetDirName() raises (SALOME::SALOME_Exception);
90
91 void SetBoundingBox(in extrema LesExtremes) raises (SALOME::SALOME_Exception);
92 extrema GetBoundingBox() raises (SALOME::SALOME_Exception);
93
94 void AddGroup(in string Group) raises (SALOME::SALOME_Exception);
95 void SetGroups(in ListGroupType ListGroup) raises (SALOME::SALOME_Exception);
96 ListGroupType GetGroups() raises (SALOME::SALOME_Exception);
97
98 void AddBoundary(in string BoundaryName) raises (SALOME::SALOME_Exception);
99 void AddBoundaryGroup(in string BoundaryName,
100 in string Group) raises (SALOME::SALOME_Exception);
101 ListBoundaryGroupType GetBoundaryGroup() raises (SALOME::SALOME_Exception);
102 void SupprBoundaryGroup() raises (SALOME::SALOME_Exception);
103
104 string GetDumpPython() raises (SALOME::SALOME_Exception);
105 };
106
107 interface HOMARD_Gen : SALOME::GenericObj
108 {
109 // Create boundaries
110 HOMARD_Boundary CreateBoundaryCAO (in string BoundaryName, in string FileName)
111 raises(SALOME::SALOME_Exception);
112 HOMARD_Boundary CreateBoundaryDi (in string BoundaryName, in string MeshName,
113 in string FileName)
114 raises(SALOME::SALOME_Exception);
116 in double Xcentre, in double Ycentre, in double Zcentre,
117 in double Xaxis, in double Yaxis, in double Zaxis,
118 in double Radius)
119 raises (SALOME::SALOME_Exception);
120 HOMARD_Boundary CreateBoundarySphere (in string BoundaryName,
121 in double Xcentre, in double Ycentre, in double Zcentre,
122 in double Radius)
123 raises(SALOME::SALOME_Exception);
124 HOMARD_Boundary CreateBoundaryConeR (in string BoundaryName,
125 in double Xcentre1, in double Ycentre1, in double Zcentre1,
126 in double Radius1,
127 in double Xcentre2, in double Ycentre2, in double Zcentre2,
128 in double Radius2)
129 raises(SALOME::SALOME_Exception);
130 HOMARD_Boundary CreateBoundaryConeA (in string BoundaryName,
131 in double Xaxis, in double Yaxis, in double Zaxis,
132 in double Angle,
133 in double Xcentre, in double Ycentre, in double Zcentre)
134 raises(SALOME::SALOME_Exception);
135 HOMARD_Boundary CreateBoundaryTorus (in string BoundaryName,
136 in double Xcentre, in double Ycentre, in double Zcentre,
137 in double Xaxis, in double Yaxis, in double Zaxis,
138 in double RadiusRev, in double RadiusPri)
139 raises (SALOME::SALOME_Exception);
140
141 // Set mesh (SMESH_Mesh object or MED file) and working directory
142 HOMARD_Cas CreateCaseOnMesh(in string MeshName,
143 in SMESH::SMESH_Mesh smeshMesh,
144 in string theWorkingDir) raises(SALOME::SALOME_Exception);
145 HOMARD_Cas CreateCase(in string MeshName,
146 in string FileName,
147 in string theWorkingDir) raises(SALOME::SALOME_Exception);
148
149 // Associate boundaries to groups
150 void AddBoundary(in string BoundaryName) raises (SALOME::SALOME_Exception);
151 void AddBoundaryGroup(in string BoundaryName,
152 in string Group) raises (SALOME::SALOME_Exception);
153
154 // Information
155 HOMARD_Boundary GetBoundary(in string BoundaryName) raises (SALOME::SALOME_Exception);
156 HOMARD_Cas GetCase() raises (SALOME::SALOME_Exception);
157 listeBoundarys GetAllBoundarysName() raises (SALOME::SALOME_Exception);
158
159 // Preferences
160 void SetConfType(in long ConfType) raises (SALOME::SALOME_Exception);
161 void SetKeepMedOUT (in boolean theKeepMedOUT);
162 void SetPublishMeshOUT (in boolean thePublishMeshOUT);
163 void SetMeshNameOUT (in string theMeshName) raises (SALOME::SALOME_Exception);
164 void SetMeshFileOUT (in string theFileName) raises (SALOME::SALOME_Exception);
165
166 void SetVerboseLevel (in long theLevel);
167 void SetKeepWorkingFiles (in boolean theKeepWorkingFiles);
168 void SetLogInFile (in boolean theLogInFile);
169 void SetLogFile (in string theFileName) raises (SALOME::SALOME_Exception);
170 void SetRemoveLogOnSuccess (in boolean theRemoveLogOnSuccess);
171
172 // Computation
173 long Compute() raises (SALOME::SALOME_Exception);
174
175 // Clean data
176 void InvalideBoundary (in string BoundaryName) raises (SALOME::SALOME_Exception);
177 long DeleteBoundary (in string BoundaryName) raises (SALOME::SALOME_Exception);
178 void DeleteCase() raises (SALOME::SALOME_Exception);
179 };
180
181}; // module SMESHHOMARD
182
183#endif
const int Radius
Definition: SMESHGUI_PatternWidget.cxx:35
Definition: SMESH_Homard.idl:37
Definition: SMESH_Homard.idl:87
Definition: SMESH_Homard.idl:108
HOMARD_Boundary CreateBoundaryDi(in string BoundaryName, in string MeshName, in string FileName)
HOMARD_Boundary CreateBoundaryConeA(in string BoundaryName, in double Xaxis, in double Yaxis, in double Zaxis, in double Angle, in double Xcentre, in double Ycentre, in double Zcentre)
HOMARD_Cas CreateCaseOnMesh(in string MeshName, in SMESH::SMESH_Mesh smeshMesh, in string theWorkingDir)
HOMARD_Boundary CreateBoundaryConeR(in string BoundaryName, in double Xcentre1, in double Ycentre1, in double Zcentre1, in double Radius1, in double Xcentre2, in double Ycentre2, in double Zcentre2, in double Radius2)
HOMARD_Boundary CreateBoundaryCAO(in string BoundaryName, in string FileName)
HOMARD_Boundary CreateBoundarySphere(in string BoundaryName, in double Xcentre, in double Ycentre, in double Zcentre, in double Radius)
HOMARD_Cas CreateCase(in string MeshName, in string FileName, in string theWorkingDir)
HOMARD_Boundary CreateBoundaryTorus(in string BoundaryName, in double Xcentre, in double Ycentre, in double Zcentre, in double Xaxis, in double Yaxis, in double Zaxis, in double RadiusRev, in double RadiusPri)
HOMARD_Boundary CreateBoundaryCylinder(in string BoundaryName, in double Xcentre, in double Ycentre, in double Zcentre, in double Xaxis, in double Yaxis, in double Zaxis, in double Radius)
void AddBoundaryGroup(in string BoundaryName, in string Group)
Definition: SMESH_Mesh.idl:338
Definition: SMESH_Gen.idl:39
sequence< double > extrema
Definition: SMESH_Homard.idl:31
sequence< double > double_array
Definition: SMESH_Homard.idl:30
sequence< string > ListBoundaryGroupType
Definition: SMESH_Homard.idl:33
sequence< string > listeBoundarys
Definition: SMESH_Homard.idl:34
sequence< string > ListGroupType
Definition: SMESH_Homard.idl:32
SMESH::SMESH_Group_var AddGroup(SMESH::SMESH_Mesh_ptr theMesh, SMESH::ElementType theType, const QString &theGroupName)
Definition: SMESHGUI_GroupUtils.cxx:38
