StdMeshers_ViscousLayers2D_i.hxx
23// File : StdMeshers_ViscousLayers2D_i.hxx
24// Module : SMESH
25//
26#ifndef _SMESH_ViscousLayers2D_I_HXX_
27#define _SMESH_ViscousLayers2D_I_HXX_
28
30
31#include <SALOMEconfig.h>
32#include CORBA_SERVER_HEADER(SMESH_BasicHypothesis)
33
36
37class SMESH_Gen;
38
40 public virtual POA_StdMeshers::StdMeshers_ViscousLayers2D,
41 public virtual SMESH_Hypothesis_i
42{
43 public:
44 // Constructor
45 StdMeshers_ViscousLayers2D_i( PortableServer::POA_ptr thePOA,
46 ::SMESH_Gen* theGenImpl );
47 // Destructor
49
50 void SetIgnoreEdges(const SMESH::long_array& edgeIDs);
51 SMESH::long_array* GetIgnoreEdges();
52
53 void SetEdges(const SMESH::long_array& edgeIDs,
54 CORBA::Boolean toIgnore);
55 SMESH::long_array* GetEdges();
56 CORBA::Boolean GetIsToIgnoreEdges();
57
58 void SetTotalThickness(::CORBA::Double thickness);
59 ::CORBA::Double GetTotalThickness();
60
61 void SetNumberLayers(::CORBA::Short nb);
62 ::CORBA::Short GetNumberLayers();
63
64 void SetStretchFactor(::CORBA::Double factor);
65 ::CORBA::Double GetStretchFactor();
66
67 void SetGroupName(const char* name);
68 char* GetGroupName();
69
70
71 // Get implementation
73
74 // Verify whether hypothesis supports given entity type
75 CORBA::Boolean IsDimSupported( SMESH::Dimension type );
76
77 // Sets sub-mesh event listeners to clear sub-meshes of edges
78 // shrunk by viscous layers
79 virtual void UpdateAsMeshesRestored();
80
81
82 // Methods for copying mesh definition to other geometry
83
84 // Return geometry this hypothesis depends on. Return false if there is no geometry parameter
85 virtual bool getObjectsDependOn( std::vector< std::string > & entryArray,
86 std::vector< int > & subIDArray ) const;
87
88 // Set new geometry instead of that returned by getObjectsDependOn()
89 virtual bool setObjectsDependOn( std::vector< std::string > & entryArray,
90 std::vector< int > & subIDArray );
91};
92
93#endif
#define STDMESHERS_I_EXPORT
Definition: SMESH_StdMeshers_I.hxx:38
Definition: SMESH_Gen.hxx:68
virtual bool setObjectsDependOn(std::vector< std::string > &entryArray, std::vector< int > &subIDArray)=0
Definition: SMESH_Hypothesis_i.cxx:327
::SMESH_Hypothesis * GetImpl()
SMESH_Hypothesis_i::GetImpl.
Definition: SMESH_Hypothesis_i.cxx:236
virtual bool getObjectsDependOn(std::vector< std::string > &entryArray, std::vector< int > &subIDArray) const =0
Definition: StdMeshers_ViscousLayers2D_i.hxx:42
Hypothesis defining parameters of viscous layers.
Definition: StdMeshers_ViscousLayers2D.hxx:36
Dimension
sequence< long > long_array
Definition: SMESH_Mesh.idl:44
