SMESHGUI_GroupOpDlg Class Reference
#include <SMESHGUI_GroupOpDlg.h>
Inheritance diagram for SMESHGUI_GroupOpDlg:
 SMESHGUI_GroupOpDlg (SMESHGUI *)
 Class : SMESHGUI_GroupOpDlg Description : Perform boolean operations on groups. More...
virtual ~SMESHGUI_GroupOpDlg ()
void Init ()
 Init dialog fields, connect signals and slots, show dialog. More...
Protected Slots
virtual bool onApply ()
 This virtual slot does nothing and should be redefined in derived classes. More...
virtual void onSelectionDone ()
 SLOT, called when selection is changed. More...
virtual void setVisible (bool visible)
 Calls onSelectionDone() and setVisible() method of base class. More...
virtual void reject ()
 SLOT called when dialog is closed. More...
virtual void reset ()
 Resets state of the dialog, initializes its fields with default value, etc. More...
QString getName () const
 Gets name of group to be created. More...
void setName (const QString &theName)
 Sets name of group to be created. More...
QGroupBox * getArgGrp () const
 Gets pointer on arguments group box. More...
void setHelpFileName (const QString &theFName)
 Sets help file name. More...
 Gets pointer to the module instance. More...
bool isValid (const QList< SMESH::SMESH_GroupBase_var > &theListGrp)
 Validate list of groups used for operation. More...
bool getSelectedGroups (QList< SMESH::SMESH_GroupBase_var > &theOutList, QStringList &theOutNames)
 Gets list of currently selected groups from selection manager. More...
SMESH::ListOfGroups * convert (const QList< SMESH::SMESH_GroupBase_var > &)
 Converts QT-list of group to the list acceptable by IDL interface. More...
SALOMEDS::Color getColor () const
 Get color to be assigned to group. More...
void setDefaultGroupColor ()
 Set default color for group. More...
void setIsApplyAndClose (const bool theFlag)
 Set value of the flag indicating that the dialog is accepted by Apply & Close button. More...
bool isApplyAndClose () const
 Get value of the flag indicating that the dialog is accepted by Apply & Close button. More...
Private Slots
void onOk ()
 SLOT called when "Ok" button pressed performs operation and closes dialog box. More...
void onHelp ()
 SLOT called when "Help" button pressed shows "Help" page. More...
void onDeactivate ()
 SLOT called when dialog must be deactivated. More...
void onOpenView ()
void onCloseView ()
void enterEvent (QEvent *)
 Event filter updates selection mode and selection filter. More...
 Provides reaction on �F1� button pressing. More...
QWidget * createButtonFrame (QWidget *)
 Create frame containing buttons. More...
QWidget * createMainFrame (QWidget *)
 Creates frame containing dialog's input fields. More...
QPushButton * myOkBtn
QPushButton * myApplyBtn
QPushButton * myCloseBtn
QPushButton * myHelpBtn
QLineEdit * myNameEdit
QGroupBox * myArgGrp
QtxColorButton * myColorBtn
SMESHGUI * mySMESHGUI
LightApp_SelectionMgr * mySelectionMgr
SVTK_Selector * mySelector
QString myHelpFileName
bool myIsApplyAndClose
◆ SMESHGUI_GroupOpDlg()
SMESHGUI_GroupOpDlg::SMESHGUI_GroupOpDlg ( SMESHGUI *  theModule)
Constructor
theModulepointer on module instance
References createButtonFrame(), createMainFrame(), SMESH::GetSelector(), SMESH::GetViewWindow(), Init(), MARGIN, mySelector, mySMESHGUI, and SPACING.
◆ ~SMESHGUI_GroupOpDlg()
SMESHGUI_GroupOpDlg::~SMESHGUI_GroupOpDlg ( )
◆ convert()
SMESH::ListOfGroups * SMESHGUI_GroupOpDlg::convert ( const QList< SMESH::SMESH_GroupBase_var > &  theIn)
theIninput list
Referenced by SMESHGUI_UnionGroupsDlg::onApply(), SMESHGUI_IntersectGroupsDlg::onApply(), and SMESHGUI_CutGroupsDlg::onApply().
◆ createButtonFrame()
QWidget * SMESHGUI_GroupOpDlg::createButtonFrame ( QWidget *  theParent)
theParentparent widget
pointer to the created frame
References MARGIN, myApplyBtn, myCloseBtn, myHelpBtn, myOkBtn, onApply(), onHelp(), onOk(), reject(), and SPACING.
Referenced by SMESHGUI_GroupOpDlg().
◆ createMainFrame()
QWidget * SMESHGUI_GroupOpDlg::createMainFrame ( QWidget *  theParent)
pointer on created widget
References MARGIN, myArgGrp, myColorBtn, myNameEdit, and SPACING.
◆ enterEvent()
void SMESHGUI_GroupOpDlg::enterEvent ( QEvent *  )
This virtual method is redefined from the base class it is called when dialog obtains input focus
References SMESHGUI::EmitSignalDeactivateDialog(), SMESH::GetViewWindow(), SMESH::GROUP, mySelectionMgr, mySelector, and mySMESHGUI.
◆ getArgGrp()
QGroupBox * SMESHGUI_GroupOpDlg::getArgGrp ( ) const
◆ getColor()
SALOMEDS::Color SMESHGUI_GroupOpDlg::getColor ( ) const
References myColorBtn.
Referenced by SMESHGUI_UnionGroupsDlg::onApply(), SMESHGUI_IntersectGroupsDlg::onApply(), SMESHGUI_CutGroupsDlg::onApply(), and SMESHGUI_DimGroupDlg::onApply().
◆ getName()
QString SMESHGUI_GroupOpDlg::getName ( ) const
See also
setName()
References myNameEdit.
◆ getSelectedGroups()
bool SMESHGUI_GroupOpDlg::getSelectedGroups ( QList< SMESH::SMESH_GroupBase_var > &  theOutList,
QStringList &  theOutNames
theOutListout list of groups
theOutNamesout list of group of group names
TRUE if operation theOutList is not empty, FALSE otherwise
References mySelectionMgr.
Referenced by SMESHGUI_UnionGroupsDlg::onSelectionDone(), SMESHGUI_IntersectGroupsDlg::onSelectionDone(), SMESHGUI_CutGroupsDlg::onSelectionDone(), and SMESHGUI_DimGroupDlg::onSelectionDone().
◆ getSMESHGUI()
SMESHGUI * SMESHGUI_GroupOpDlg::getSMESHGUI ( ) const
◆ Init()
void SMESHGUI_GroupOpDlg::Init ( )
◆ isApplyAndClose()
bool SMESHGUI_GroupOpDlg::isApplyAndClose ( ) const
value of the flag
See also
setApplyAndClose()
References myIsApplyAndClose.
◆ isValid()
bool SMESHGUI_GroupOpDlg::isValid ( const QList< SMESH::SMESH_GroupBase_var > &  theListGrp)
Checks whether they corresponds to the same face and have one type
theListGrpinput list of groups
TRUE if groups are valid, FALSE otherwise
◆ keyPressEvent()
void SMESHGUI_GroupOpDlg::keyPressEvent ( QKeyEvent *  e)
ekey press event
References onHelp().
◆ onApply
bool SMESHGUI_GroupOpDlg::onApply ( )
protectedvirtualslot
return false;
Referenced by createButtonFrame(), and onOk().
◆ onCloseView
void SMESHGUI_GroupOpDlg::onCloseView ( )
privateslot
References mySelector, and onDeactivate().
Referenced by Init().
◆ onDeactivate
void SMESHGUI_GroupOpDlg::onDeactivate ( )
privateslot
Referenced by Init(), and onCloseView().
◆ onHelp
void SMESHGUI_GroupOpDlg::onHelp ( )
privateslot
References myHelpFileName, and mySMESHGUI.
Referenced by createButtonFrame(), and keyPressEvent().
◆ onOk
void SMESHGUI_GroupOpDlg::onOk ( )
privateslot
References onApply(), reject(), and setIsApplyAndClose().
Referenced by createButtonFrame().
◆ onOpenView
void SMESHGUI_GroupOpDlg::onOpenView ( )
privateslot
◆ onSelectionDone
void SMESHGUI_GroupOpDlg::onSelectionDone ( )
Current implementation does nothing. The method should be redefined in derived classes to update corresponding GUI controls
Referenced by Init(), and setVisible().
◆ reject
void SMESHGUI_GroupOpDlg::reject ( )
References SMESH::GetViewWindow(), mySelectionMgr, mySMESHGUI, reset(), and SMESHGUI::ResetState().
Referenced by createButtonFrame(), Init(), and onOk().
◆ reset()
void SMESHGUI_GroupOpDlg::reset ( )
Usually called by onApply() slot to reinitialize dialog fields. This virtual method should be redefined in derived class to update its own fields
Reimplemented in SMESHGUI_UnionGroupsDlg, SMESHGUI_IntersectGroupsDlg, SMESHGUI_CutGroupsDlg, and SMESHGUI_DimGroupDlg.
References myNameEdit, and setDefaultGroupColor().
Referenced by reject(), SMESHGUI_UnionGroupsDlg::reset(), SMESHGUI_IntersectGroupsDlg::reset(), SMESHGUI_CutGroupsDlg::reset(), and SMESHGUI_DimGroupDlg::reset().
◆ setDefaultGroupColor()
void SMESHGUI_GroupOpDlg::setDefaultGroupColor ( )
References SMESH::GetColor(), and myColorBtn.
Referenced by Init(), and reset().
◆ setHelpFileName()
void SMESHGUI_GroupOpDlg::setHelpFileName ( const QString &  theFName)
◆ setIsApplyAndClose()
void SMESHGUI_GroupOpDlg::setIsApplyAndClose ( const bool  theFlag)
theFlagvalue of the flag
See also
isApplyAndClose()
Referenced by onOk().
◆ setName()
void SMESHGUI_GroupOpDlg::setName ( const QString &  theName)
theNamename of group to be created
See also
getName()
◆ setVisible
void SMESHGUI_GroupOpDlg::setVisible ( bool  visible)
visiblethe visible state of the dialog
References onSelectionDone().
◆ myApplyBtn
QPushButton* SMESHGUI_GroupOpDlg::myApplyBtn
◆ myArgGrp
QGroupBox* SMESHGUI_GroupOpDlg::myArgGrp
Referenced by createMainFrame(), and getArgGrp().
◆ myCloseBtn
QPushButton* SMESHGUI_GroupOpDlg::myCloseBtn
◆ myColorBtn
QtxColorButton* SMESHGUI_GroupOpDlg::myColorBtn
◆ myHelpBtn
QPushButton* SMESHGUI_GroupOpDlg::myHelpBtn
◆ myHelpFileName
QString SMESHGUI_GroupOpDlg::myHelpFileName
Referenced by onHelp(), and setHelpFileName().
◆ myIsApplyAndClose
bool SMESHGUI_GroupOpDlg::myIsApplyAndClose
◆ myNameEdit
QLineEdit* SMESHGUI_GroupOpDlg::myNameEdit
◆ myOkBtn
QPushButton* SMESHGUI_GroupOpDlg::myOkBtn
◆ mySelectionMgr
LightApp_SelectionMgr* SMESHGUI_GroupOpDlg::mySelectionMgr
◆ mySelector
SVTK_Selector* SMESHGUI_GroupOpDlg::mySelector
◆ mySMESHGUI
SMESHGUI* SMESHGUI_GroupOpDlg::mySMESHGUI
