SMESHGUI_UnionGroupsDlg Class Reference
#include <SMESHGUI_GroupOpDlg.h>
Inheritance diagram for SMESHGUI_UnionGroupsDlg:
 SMESHGUI_UnionGroupsDlg (SMESHGUI *)
virtual ~SMESHGUI_UnionGroupsDlg ()
void Init ()
 Init dialog fields, connect signals and slots, show dialog. More...
Protected Slots
virtual bool onApply ()
 SLOT called when apply button is pressed performs operation. More...
virtual void onSelectionDone ()
 SLOT, called when selection is changed, updates corresponding GUI controls. More...
virtual void setVisible (bool visible)
 Calls onSelectionDone() and setVisible() method of base class. More...
virtual void reject ()
 SLOT called when dialog is closed. More...
virtual void reset ()
 This virtual method redefined from the base class resets state of the dialog, initializes its fields with default value, etc. More...
QString getName () const
 Gets name of group to be created. More...
void setName (const QString &theName)
 Sets name of group to be created. More...
QGroupBox * getArgGrp () const
 Gets pointer on arguments group box. More...
void setHelpFileName (const QString &theFName)
 Sets help file name. More...
 Gets pointer to the module instance. More...
bool isValid (const QList< SMESH::SMESH_GroupBase_var > &theListGrp)
 Validate list of groups used for operation. More...
bool getSelectedGroups (QList< SMESH::SMESH_GroupBase_var > &theOutList, QStringList &theOutNames)
 Gets list of currently selected groups from selection manager. More...
SMESH::ListOfGroups * convert (const QList< SMESH::SMESH_GroupBase_var > &)
 Converts QT-list of group to the list acceptable by IDL interface. More...
SALOMEDS::Color getColor () const
 Get color to be assigned to group. More...
void setDefaultGroupColor ()
 Set default color for group. More...
void setIsApplyAndClose (const bool theFlag)
 Set value of the flag indicating that the dialog is accepted by Apply & Close button. More...
bool isApplyAndClose () const
 Get value of the flag indicating that the dialog is accepted by Apply & Close button. More...
Private Slots
void onOk ()
 SLOT called when "Ok" button pressed performs operation and closes dialog box. More...
void onHelp ()
 SLOT called when "Help" button pressed shows "Help" page. More...
void onDeactivate ()
 SLOT called when dialog must be deactivated. More...
void onOpenView ()
void onCloseView ()
void enterEvent (QEvent *)
 Event filter updates selection mode and selection filter. More...
 Provides reaction on �F1� button pressing. More...
QWidget * createButtonFrame (QWidget *)
 Create frame containing buttons. More...
QWidget * createMainFrame (QWidget *)
 Creates frame containing dialog's input fields. More...
QListWidget * myListWg
QList< SMESH::SMESH_GroupBase_var > myGroups
QPushButton * myOkBtn
QPushButton * myApplyBtn
QPushButton * myCloseBtn
QPushButton * myHelpBtn
QLineEdit * myNameEdit
QGroupBox * myArgGrp
QtxColorButton * myColorBtn
SMESHGUI * mySMESHGUI
LightApp_SelectionMgr * mySelectionMgr
SVTK_Selector * mySelector
QString myHelpFileName
bool myIsApplyAndClose
◆ SMESHGUI_UnionGroupsDlg()
SMESHGUI_UnionGroupsDlg::SMESHGUI_UnionGroupsDlg ( SMESHGUI *  theModule)
theModulemodule
References SMESHGUI_GroupOpDlg::getArgGrp(), myListWg, and SMESHGUI_GroupOpDlg::setHelpFileName().
◆ ~SMESHGUI_UnionGroupsDlg()
SMESHGUI_UnionGroupsDlg::~SMESHGUI_UnionGroupsDlg ( )
◆ convert()
SMESH::ListOfGroups * SMESHGUI_GroupOpDlg::convert ( const QList< SMESH::SMESH_GroupBase_var > &  theIn)
theIninput list
Referenced by onApply(), SMESHGUI_IntersectGroupsDlg::onApply(), and SMESHGUI_CutGroupsDlg::onApply().
◆ createButtonFrame()
QWidget * SMESHGUI_GroupOpDlg::createButtonFrame ( QWidget *  theParent)
privateinherited
◆ createMainFrame()
QWidget * SMESHGUI_GroupOpDlg::createMainFrame ( QWidget *  theParent)
privateinherited
theParentparent widget
pointer on created widget
References MARGIN, SMESHGUI_GroupOpDlg::myArgGrp, SMESHGUI_GroupOpDlg::myColorBtn, SMESHGUI_GroupOpDlg::myNameEdit, and SPACING.
Referenced by SMESHGUI_GroupOpDlg::SMESHGUI_GroupOpDlg().
◆ enterEvent()
void SMESHGUI_GroupOpDlg::enterEvent ( QEvent *  )
privateinherited
This virtual method is redefined from the base class it is called when dialog obtains input focus
References SMESHGUI::EmitSignalDeactivateDialog(), SMESH::GetViewWindow(), SMESH::GROUP, SMESHGUI_GroupOpDlg::mySelectionMgr, SMESHGUI_GroupOpDlg::mySelector, and SMESHGUI_GroupOpDlg::mySMESHGUI.
◆ getArgGrp()
QGroupBox * SMESHGUI_GroupOpDlg::getArgGrp ( ) const
◆ getColor()
SALOMEDS::Color SMESHGUI_GroupOpDlg::getColor ( ) const
References SMESHGUI_GroupOpDlg::myColorBtn.
Referenced by onApply(), SMESHGUI_IntersectGroupsDlg::onApply(), SMESHGUI_CutGroupsDlg::onApply(), and SMESHGUI_DimGroupDlg::onApply().
◆ getName()
QString SMESHGUI_GroupOpDlg::getName ( ) const
See also
setName()
References SMESHGUI_GroupOpDlg::myNameEdit.
◆ getSelectedGroups()
bool SMESHGUI_GroupOpDlg::getSelectedGroups ( QList< SMESH::SMESH_GroupBase_var > &  theOutList,
QStringList &  theOutNames
theOutListout list of groups
theOutNamesout list of group of group names
TRUE if operation theOutList is not empty, FALSE otherwise
References SMESHGUI_GroupOpDlg::mySelectionMgr.
Referenced by onSelectionDone(), SMESHGUI_IntersectGroupsDlg::onSelectionDone(), SMESHGUI_CutGroupsDlg::onSelectionDone(), and SMESHGUI_DimGroupDlg::onSelectionDone().
◆ getSMESHGUI()
SMESHGUI * SMESHGUI_GroupOpDlg::getSMESHGUI ( ) const
◆ Init()
◆ isApplyAndClose()
bool SMESHGUI_GroupOpDlg::isApplyAndClose ( ) const
value of the flag
See also
setApplyAndClose()
References SMESHGUI_GroupOpDlg::myIsApplyAndClose.
◆ isValid()
bool SMESHGUI_GroupOpDlg::isValid ( const QList< SMESH::SMESH_GroupBase_var > &  theListGrp)
Checks whether they corresponds to the same face and have one type
theListGrpinput list of groups
TRUE if groups are valid, FALSE otherwise
◆ keyPressEvent()
void SMESHGUI_GroupOpDlg::keyPressEvent ( QKeyEvent *  e)
privateinherited
ekey press event
References SMESHGUI_GroupOpDlg::onHelp().
◆ onApply
bool SMESHGUI_UnionGroupsDlg::onApply ( )
protectedvirtualslot
◆ onCloseView
void SMESHGUI_GroupOpDlg::onCloseView ( )
privateslotinherited
◆ onDeactivate
void SMESHGUI_GroupOpDlg::onDeactivate ( )
Referenced by SMESHGUI_GroupOpDlg::Init(), and SMESHGUI_GroupOpDlg::onCloseView().
◆ onHelp
void SMESHGUI_GroupOpDlg::onHelp ( )
References SMESHGUI_GroupOpDlg::myHelpFileName, and SMESHGUI_GroupOpDlg::mySMESHGUI.
Referenced by SMESHGUI_GroupOpDlg::createButtonFrame(), and SMESHGUI_GroupOpDlg::keyPressEvent().
◆ onOk
void SMESHGUI_GroupOpDlg::onOk ( )
References SMESHGUI_GroupOpDlg::onApply(), SMESHGUI_GroupOpDlg::reject(), and SMESHGUI_GroupOpDlg::setIsApplyAndClose().
Referenced by SMESHGUI_GroupOpDlg::createButtonFrame().
◆ onOpenView
◆ onSelectionDone
void SMESHGUI_UnionGroupsDlg::onSelectionDone ( )
References SMESHGUI_GroupOpDlg::getSelectedGroups(), myGroups, and myListWg.
◆ reject
◆ reset()
void SMESHGUI_UnionGroupsDlg::reset ( )
Reimplemented from SMESHGUI_GroupOpDlg.
References myGroups, myListWg, and SMESHGUI_GroupOpDlg::reset().
Referenced by onApply().
◆ setDefaultGroupColor()
void SMESHGUI_GroupOpDlg::setDefaultGroupColor ( )
References SMESH::GetColor(), and SMESHGUI_GroupOpDlg::myColorBtn.
Referenced by SMESHGUI_GroupOpDlg::Init(), and SMESHGUI_GroupOpDlg::reset().
◆ setHelpFileName()
void SMESHGUI_GroupOpDlg::setHelpFileName ( const QString &  theFName)
◆ setIsApplyAndClose()
void SMESHGUI_GroupOpDlg::setIsApplyAndClose ( const bool  theFlag)
theFlagvalue of the flag
See also
isApplyAndClose()
Referenced by SMESHGUI_GroupOpDlg::onOk().
◆ setName()
void SMESHGUI_GroupOpDlg::setName ( const QString &  theName)
theNamename of group to be created
See also
getName()
◆ setVisible
void SMESHGUI_GroupOpDlg::setVisible ( bool  visible)
protectedvirtualslotinherited
visiblethe visible state of the dialog
References SMESHGUI_GroupOpDlg::onSelectionDone().
◆ myApplyBtn
QPushButton* SMESHGUI_GroupOpDlg::myApplyBtn
privateinherited
◆ myArgGrp
QGroupBox* SMESHGUI_GroupOpDlg::myArgGrp
privateinherited
◆ myCloseBtn
QPushButton* SMESHGUI_GroupOpDlg::myCloseBtn
privateinherited
◆ myColorBtn
QtxColorButton* SMESHGUI_GroupOpDlg::myColorBtn
privateinherited
◆ myGroups
QList<SMESH::SMESH_GroupBase_var> SMESHGUI_UnionGroupsDlg::myGroups
Referenced by onApply(), onSelectionDone(), and reset().
◆ myHelpBtn
QPushButton* SMESHGUI_GroupOpDlg::myHelpBtn
privateinherited
◆ myHelpFileName
QString SMESHGUI_GroupOpDlg::myHelpFileName
privateinherited
◆ myIsApplyAndClose
bool SMESHGUI_GroupOpDlg::myIsApplyAndClose
privateinherited
◆ myListWg
QListWidget* SMESHGUI_UnionGroupsDlg::myListWg
◆ myNameEdit
QLineEdit* SMESHGUI_GroupOpDlg::myNameEdit
privateinherited
◆ myOkBtn
QPushButton* SMESHGUI_GroupOpDlg::myOkBtn
privateinherited
◆ mySelectionMgr
◆ mySelector
◆ mySMESHGUI
