SMESHGUI_MeshTab Class Reference
Tab for tab widget containing controls for definition of algorithms and hypotheses. More...
#include <SMESHGUI_MeshDlg.h>
Inheritance diagram for SMESHGUI_MeshTab:
enum  HypType { Algo = 0 , MainHyp , AddHyp , MoreAddHyp }
 To differ main algorithms, hypotheses and additional ones. More...
Signals
void createHyp (const int, const int)
 Emitted when "Create hypothesis" button clicked. More...
void editHyp (const int, const int)
 Emitted when "Edit hypothesis" button clicked. More...
void selectAlgo (const int)
 Emitted when an algorithm is selected. More...
 SMESHGUI_MeshTab (QWidget *)
virtual ~SMESHGUI_MeshTab ()
void setAvailableHyps (const int, const QStringList &)
 Sets available hypothesis or algorithms. More...
void setExistingHyps (const int, const QStringList &, bool=false)
 Sets existing hypothesis. More...
void addHyp (const int, const QString &)
 Adds hypothesis in combo box of available ones. More...
void setCurrentHyp (const int, const int)
 Sets current hypothesis. More...
int currentHyp (const int) const
 Gets current hypothesis. More...
int nbAddHypTypes () const
 Returns nb of selected supplementary additional hypotheses. More...
void reset ()
 Resets all tab fields. More...
Private Slots
void onCreateHyp ()
 Emits createHyp( const int ) signal. More...
void onEditHyp ()
 Emits editHyp( const int ) signal. More...
void onHyp (int)
 Updates "Edit hypothesis" button state. More...
void onMoreAddHyp ()
 Adds a current additional hyp to myAddHypList. More...
void onLessAddHyp ()
 Removes a current additional hyp from myAddHypList. More...
void addItem (const QString &txt, const int type, const int index, const bool isGroup=false)
 Adds an item in a control corresponding to type. More...
int getCurrentIndex (const int type, const bool curByType=false) const
 Returns index of hyp of a given type. More...
QMap< int, QStringList > myAvailableHypTypes
QMap< int, QtxToolButton * > myHypCombo
QMap< int, QToolButton * > myCreateHypBtn
QMap< int, QToolButton * > myEditHypBtn
QToolButton * myMoreAddHypBtn
QToolButton * myLessAddHypBtn
QListWidget * myAddHypList
◆ HypType
Algo
algorithms
MainHyp
main hypothesis
AddHyp
additional hypothesis
MoreAddHyp
since several additional hypothesis are possible, the 2-nd, 3-d etc
◆ SMESHGUI_MeshTab()
SMESHGUI_MeshTab::SMESHGUI_MeshTab ( QWidget *  theParent)
Constructor
theParent- Parent widget for this tab
Makes tab's look and feel
References AddHyp, Algo, MainHyp, MARGIN, MoreAddHyp, myAddHypList, myCreateHypBtn, myEditHypBtn, myHypCombo, myLessAddHypBtn, myMoreAddHypBtn, onCreateHyp(), onEditHyp(), onHyp(), onLessAddHyp(), onMoreAddHyp(), setAvailableHyps(), and SPACING.
◆ ~SMESHGUI_MeshTab()
SMESHGUI_MeshTab::~SMESHGUI_MeshTab ( )
◆ addHyp()
void SMESHGUI_MeshTab::addHyp ( const int  theId,
const QString &  theHyp
theId- identifier of hypothesis (main or additional, see HypType enumeration)
theHyp- name of hypothesis to be added
Adds hypothesis in combo box of available ones. This method is called by operation after creation of new hypothesis.
References AddHyp, addItem(), myAddHypList, myEditHypBtn, myHypCombo, and myMoreAddHypBtn.
Referenced by SMESHGUI_MeshOp::onHypoCreated().
◆ addItem()
void SMESHGUI_MeshTab::addItem ( const QString &  txt,
const int  type,
const int  index,
const bool  isGroup = false
[in]txt- item text
[in]type- HypType
[in]index- index of item in a list of items
[in]isGroup- is the item a group title
References AddHyp, myAddHypList, and myHypCombo.
Referenced by addHyp(), onLessAddHyp(), onMoreAddHyp(), setAvailableHyps(), setCurrentHyp(), and setExistingHyps().
◆ createHyp
void SMESHGUI_MeshTab::createHyp ( const int  ,
const int
signal
Referenced by onCreateHyp().
◆ currentHyp()
int SMESHGUI_MeshTab::currentHyp ( const int  theId) const
int- index of current hypothesis
Gets current hypothesis Use theId > AddHyp to get more than selected addetional hyps (see nbAddHypTypes()).
References getCurrentIndex().
Referenced by SMESHGUI_MeshOp::currentHyp(), and onMoreAddHyp().
◆ editHyp
void SMESHGUI_MeshTab::editHyp ( const int  ,
const int
signal
Referenced by onEditHyp().
◆ getCurrentIndex()
int SMESHGUI_MeshTab::getCurrentIndex ( const int  type,
const bool  curByType = false
Referenced by currentHyp(), and onEditHyp().
◆ nbAddHypTypes()
int SMESHGUI_MeshTab::nbAddHypTypes ( ) const
Access to their indices is via currentHyp( AddHyp + i ) where i is within the range 0 <= i < this->nbAddHypTypes()
References myAddHypList.
Referenced by SMESHGUI_MeshOp::nbDlgHypTypes().
◆ onCreateHyp
void SMESHGUI_MeshTab::onCreateHyp ( )
privateslot
SLOT called when "Create hypothesis" button clicked specifies sender and emits createHyp( const int ) signal
References AddHyp, createHyp(), MainHyp, myAvailableHypTypes, and myCreateHypBtn.
Referenced by SMESHGUI_MeshTab().
◆ onEditHyp
void SMESHGUI_MeshTab::onEditHyp ( )
privateslot
SLOT called when "Edit hypothesis" button clicked specifies sender and emits editHyp( const int ) signal
References AddHyp, editHyp(), getCurrentIndex(), MainHyp, MoreAddHyp, and myEditHypBtn.
◆ onHyp
void SMESHGUI_MeshTab::onHyp ( int  theIndex)
privateslot
SLOT called when current hypothesis changed. Disables "Edit hypothesis" button if current hypothesis is <None>, enables otherwise. If an algorithm changed, emits selectAlgo( theIndex ) signal
References AddHyp, Algo, MainHyp, MoreAddHyp, myAddHypList, myEditHypBtn, myHypCombo, myLessAddHypBtn, myMoreAddHypBtn, and selectAlgo().
◆ onLessAddHyp
void SMESHGUI_MeshTab::onLessAddHyp ( )
privateslot
SLOT called when myLessAddHypBtn ("minus") clicked
References AddHyp, addItem(), and myAddHypList.
◆ onMoreAddHyp
void SMESHGUI_MeshTab::onMoreAddHyp ( )
privateslot
SLOT called when myMoreAddHypBtn ("plus") clicked
References AddHyp, addItem(), currentHyp(), MoreAddHyp, myEditHypBtn, myHypCombo, and myMoreAddHypBtn.
◆ reset()
void SMESHGUI_MeshTab::reset ( )
References AddHyp, Algo, myEditHypBtn, and myHypCombo.
◆ selectAlgo
void SMESHGUI_MeshTab::selectAlgo ( const int  )
signal
Referenced by onHyp().
◆ setAvailableHyps()
void SMESHGUI_MeshTab::setAvailableHyps ( const int  theId,
const QStringList &  theHyps
theHyps- list of available hypothesis names
Sets available main or additional hypothesis for this tab
References addItem(), Algo, myAvailableHypTypes, myCreateHypBtn, myEditHypBtn, and myHypCombo.
Referenced by SMESHGUI_MeshOp::createSubMeshOnInternalEdges(), SMESHGUI_MeshOp::onAlgoSelected(), SMESHGUI_MeshOp::readMesh(), SMESHGUI_MeshOp::setCurrentHyp(), SMESHGUI_MeshOp::setFilteredAlgoData(), SMESHGUI_MeshTab(), and SMESHGUI_MeshOp::startOperation().
◆ setCurrentHyp()
void SMESHGUI_MeshTab::setCurrentHyp ( const int  theId,
const int  theIndex
theIndex- index of hypothesis to be set as current
Referenced by SMESHGUI_MeshOp::setCurrentHyp().
◆ setExistingHyps()
void SMESHGUI_MeshTab::setExistingHyps ( const int  theId,
const QStringList &  theHyps,
bool  theDefaultAvlbl = false
theDefaultAvlbl- true means that the algorithm can work w/o hypothesis with some default parameters
Sets existing main or additional hypothesis for this tab
References AddHyp, addItem(), Algo, MoreAddHyp, myAddHypList, myAvailableHypTypes, myEditHypBtn, myHypCombo, myLessAddHypBtn, and myMoreAddHypBtn.
Referenced by SMESHGUI_MeshOp::onAlgoSelected(), SMESHGUI_MeshOp::readMesh(), SMESHGUI_MeshOp::setCurrentHyp(), and SMESHGUI_MeshOp::startOperation().
◆ myAddHypList
QListWidget* SMESHGUI_MeshTab::myAddHypList
◆ myAvailableHypTypes
QMap<int, QStringList> SMESHGUI_MeshTab::myAvailableHypTypes
◆ myCreateHypBtn
QMap<int, QToolButton*> SMESHGUI_MeshTab::myCreateHypBtn
◆ myEditHypBtn
QMap<int, QToolButton*> SMESHGUI_MeshTab::myEditHypBtn
◆ myHypCombo
QMap<int, QtxToolButton*> SMESHGUI_MeshTab::myHypCombo
◆ myLessAddHypBtn
QToolButton* SMESHGUI_MeshTab::myLessAddHypBtn
◆ myMoreAddHypBtn
QToolButton* SMESHGUI_MeshTab::myMoreAddHypBtn
