SMESHGUI_MeshOp Class Reference
Operation for mech creation or editing. More...
#include <SMESHGUI_MeshOp.h>
Inheritance diagram for SMESHGUI_MeshOp:
enum  HypType { Algo = 0 , MainHyp , AddHyp , NbHypTypes }
enum  MeshType {
  MT_ANY = 0 , MT_TRIANGULAR , MT_QUADRILATERAL , MT_TETRAHEDRAL ,
  MT_HEXAHEDRAL
typedef std::pair< SMESH::SMESH_Hypothesis_var, QString > THypItem
typedef QList< THypItem > THypList
typedef int THypType
typedef QMap< THypType, THypList > TType2HypList
typedef int THypDim
typedef QMap< THypDim, TType2HypList > TDim2Type2HypList
typedef QList< int > IdList
 SMESHGUI_MeshOp (const bool, const bool=true)
virtual ~SMESHGUI_MeshOp ()
 Gets dialog of this operation. More...
static void extractIds (const QStringList &, IdList &, const QChar)
Protected Types
enum  EntityType { Object , MeshNode , MeshElement }
Protected Slots
virtual bool onApply ()
 Creates or edits mesh. More...
void onCreateHyp (const int, const int)
 Create hypothesis. More...
void onEditHyp (const int, const int)
 Calls plugin methods for hypothesis editing. More...
void onHypoSet (const QString &)
 Creates and selects hypothesis of hypotheses set. More...
void onGeomSelectionByMesh (bool)
 SLOT. More...
void onPublishShapeByMeshDlg (SUIT_Operation *)
 SLOT. More...
void onCloseShapeByMeshDlg (SUIT_Operation *)
 SLOT. More...
void onAlgoSelected (const int, const int=-1)
 Set available algos and hypos according to the selected algorithm. More...
void onHypoCreated (int)
 Necessary steps after hypothesis creation. More...
void onHypoEdited (int)
 Necessary steps after hypothesis edition. More...
void onAlgoSetByMeshType (const int, const int)
 SLOT. More...
virtual void onActivateObject (int)
 Installs filter corresponding to certain object selection widget. More...
virtual void onDeactivateObject (int)
 Removes filter corresponding to certain object selection widget. More...
virtual void onSelectionChanged (int)
 Empty default implementation. More...
virtual void onTextChanged (int, const QStringList &)
 Default implementation allowing user to edit selected ids "by hands". More...
virtual void onOk ()
virtual void onCancel ()
void onHelp ()
 Creates dialog if necessary and shows it. More...
 Selects a recently created mesh or sub-mesh if necessary. More...
virtual void selectionDone ()
virtual SUIT_SelectionFilter * createFilter (const int) const
 Creates selection filter. More...
virtual bool isValid (SUIT_Operation *) const
void extractIds (const QStringList &, IdList &) const
 Find in QStringList correct node or element ids representation and append integer(id) to IdList. More...
virtual void initDialog ()
void removeCustomFilters ()
 Remove only filters set by this operation (they are in map myFilters ) More...
Selection_Mode selectionMode () const
 Return what selection mode is set in VTK viewer. More...
void setSelectionMode (const Selection_Mode)
 Set selection mode in VTK viewer. More...
void highlight (const Handle(SALOME_InteractiveObject)&, const bool, const bool=true)
 Highlight object in VTK viewer. More...
void addOrRemoveIndex (const Handle(SALOME_InteractiveObject)&, const SVTK_TVtkIDsMap &, const bool isModeShift)
 Select some nodes or elements in VTK. More...
SVTK_ViewWindow * viewWindow () const
SVTK_Selector * selector () const
virtual void selected (QStringList &, SMESHGUI_Dialog::TypesList &, QStringList &) const
 Get names, types and ids of selected objects. More...
virtual int typeById (const QString &, const EntityType) const
 Find type by id. More...
virtual QChar idChar () const
 Char using to divide <entry> and <id> in string id representation. By default, '#'. More...
void selectedIds (const int, IdList &) const
 Try to find in certain object selection widget selected node or element ids and return it. More...
SMESH::SMESH_Mesh_var mesh () const
 Return selected mesh if selection mode isn't ActorSelection and only one object is selected. More...
SMESH_Actor * actor () const
 Return actor according to selected mesh if selection mode isn't ActorSelection. More...
QString myHelpFileName
bool myIsApplyAndClose
Private Types
typedef QList< HypothesisData * > THypDataList
typedef QMap< QString, bool > THypLabelIsAppMap
typedef QMap< int, SUIT_SelectionFilter * > Filters
bool isValid (QString &) const
 Verifies validity of input data. More...
bool isCompatibleToGeometry (HypothesisData *, const int)
 check compatibility of the geometry More...
bool isCompatibleToMeshType (HypothesisData *, const int)
 check compatibility of the mesh type More...
void availableHyps (const int, const int, QStringList &, THypDataList &, HypothesisData *=0, HypothesisData *=0, const QString &="")
 Get available hypotheses or algorithms. More...
void existingHyps (const int, const int, _PTR(SObject), QStringList &, THypList &, HypothesisData *=0) const
 Gets existing hypotheses or algorithms. More...
HypothesisData * hypData (const int, const int, const int)
 access to hypothesis data More...
void createHypothesis (const int, const int, const QString &)
 Create hypothesis and update dialog. More...
bool createMesh (QString &, QStringList &)
 Creates mesh. More...
bool createSubMesh (QString &, QStringList &)
 Create sub-mesh. More...
bool editMeshOrSubMesh (QString &, QStringList &)
 Edits mesh or sub-mesh. More...
void createSubMeshOnInternalEdges (SMESH::SMESH_Mesh_ptr mesh, GEOM::GEOM_Object_ptr mainShape)
 Create a sub-mesh on internal edges in the case where the global algorithm is of type 1D-2D[-3D] so that the internal edges would remain not meshed. More...
bool checkSubMeshConcurrency (SMESH::SMESH_Mesh_ptr mesh, SMESH::SMESH_subMesh_ptr submesh, bool askUser=false)
 Checks if a concurrent sub-meshes appear as result of sub-mesh creation/edition and, if (askUser) , proposes the uses to set up a desired order of sub-mesh computation. More...
int currentHyp (const int, const int) const
 Return index of current hypothesis or algorithm. More...
bool isSelectedHyp (int, int, int) const
 Checks if a hypothesis is selected. More...
int nbDlgHypTypes (const int) const
 Returns nb of HypType's taking into account possible several selected additional hypotheses which are coded as additional HypType's. More...
bool isAccessibleDim (const int) const
 Returns true if hypotheses of given dim can be assigned. More...
void setCurrentHyp (const int, const int, const int, const bool=false)
 Sets current hypothesis or algorithms. More...
void setDefaultName (const QString &prefix="") const
 Generates default and sets mesh/submesh name. More...
SMESH::SMESH_Hypothesis_var getAlgo (const int)
 Gets algorithm or creates it if necessary. More...
void readMesh ()
 Reads parameters of an edited mesh/sub-mesh and assigns them to the dialog. More...
QString name (_PTR(SObject)) const
 Gets name of object. More...
int find (const SMESH::SMESH_Hypothesis_var &, const THypList &) const
 Finds hypothesis in input list. More...
SMESH::SMESH_Hypothesis_var getInitParamsHypothesis (const QString &, const QString &, const SMESH::HypInitParams *prm=0) const
 If create or edit a submesh, return a hypothesis holding parameters used to mesh a sub-shape. More...
void initHypCreator (SMESHGUI_GenericHypothesisCreator *aCreator)
 initialize a hypothesis creator More...
bool getAverageSize (double &averageSize)
 Ask the user to enter an average size which will be used to create hypotheses of a hypo-set basing on this size. More...
bool isSubshapeOk () const
 check if selected shape is a sub-shape of the shape to mesh More...
char * isSubmeshIgnored () const
 Return name of the algorithm that does not support sub-meshes and makes sub-mesh creation useless. More...
 _PTR (SObject) getSubmeshByGeom() const
void selectObject (_PTR(SObject)) const
 Selects a SObject. More...
void updateMeshTypeList ()
 Update available list of mesh types. More...
void updateHypoSets ()
 Update available list of hypothesis sets. More...
void setFilteredAlgoData ()
 Update list of algorithms and hypotheses according to currently selected algorithm, geometry and mesh type. More...
QStringList getHypoNames ()
 Return names of all existing hypotheses. More...
void logSmeshParams ()
 Log meshers info. More...
SMESHGUI_MeshDlg * myDlg
SMESHGUI_ShapeByMeshOp * myShapeByMeshOp
bool myToCreate
bool myIsMesh
bool myIsOnGeometry
 TRUE if edited mesh is based on geometry. More...
bool myHasConcurrentSubBefore
bool myIsInvalidSubMesh
 "invalid sub-mesh" is edited More...
QString myGeomEntry
GEOM::GEOM_Object_var myGeom
TDim2Type2HypList myExistingHyps
 all hypothesis of SMESH module More...
TDim2Type2HypList myObjHyps
 hypothesis assigned to the current More...
THypDataList myAvailableHypData [4][NbHypTypes]
QString myLastGeomEntry
THypLabelIsAppMap myHypMapIsApplicable
bool myIgnoreAlgoSelection
int myDim
int myType
int myMaxShapeDim
HypothesesSet * myHypoSet
double myAverageSize
QString myObjectToSelect
Filters myFilters
Selection_Mode myDefSelectionMode
Selection_Mode myOldSelectionMode
This operation is used for mech creation or editing.
◆ Filters
typedef QMap<int, SUIT_SelectionFilter*> SMESHGUI_SelectionOp::Filters
privateinherited
◆ IdList
typedef QList<int> SMESHGUI_SelectionOp::IdList
◆ TDim2Type2HypList
◆ THypDataList
◆ THypDim
◆ THypItem
typedef std::pair<SMESH::SMESH_Hypothesis_var, QString> SMESHGUI_MeshOp::THypItem
◆ THypLabelIsAppMap
typedef QMap<QString, bool> SMESHGUI_MeshOp::THypLabelIsAppMap
◆ THypList
◆ THypType
◆ TType2HypList
◆ EntityType
enum SMESHGUI_SelectionOp::EntityType
Object
MeshNode
MeshElement
◆ HypType
Algo
MainHyp
AddHyp
NbHypTypes
◆ MeshType
MT_ANY
MT_TRIANGULAR
MT_QUADRILATERAL
MT_TETRAHEDRAL
MT_HEXAHEDRAL
◆ SMESHGUI_MeshOp()
SMESHGUI_MeshOp::SMESHGUI_MeshOp ( const bool  theToCreate,
const bool  theIsMesh = true
theToCreate- if this parameter is true then operation is used for creation, for editing otherwise
Initialize operation
References myIsOnGeometry, and myMaxShapeDim.
◆ ~SMESHGUI_MeshOp()
SMESHGUI_MeshOp::~SMESHGUI_MeshOp ( )
References myDlg.
◆ _PTR()
◆ abortOperation()
void SMESHGUI_SelectionOp::abortOperation ( )
◆ actor()
SMESH_Actor * SMESHGUI_SelectionOp::actor ( ) const
◆ addOrRemoveIndex()
void SMESHGUI_SelectionOp::addOrRemoveIndex ( const Handle(SALOME_InteractiveObject)&  obj,
const SVTK_TVtkIDsMap &  indices,
◆ availableHyps()
void SMESHGUI_MeshOp::availableHyps ( const int  theDim,
const int  theHypType,
QStringList &  theHyps,
THypDataList &  theDataList,
HypothesisData *  thePrevAlgoData = 0,
HypothesisData *  theNextAlgoData = 0,
const QString &  = ""
theDim- specifies dimension of returned hypotheses/algorifms
theHypType- specifies whether algorims or hypotheses or additional ones are retrieved (possible values are in HypType enumeration)
theHyps- output list of hypotheses' names
thePrevAlgoData- to select hypos able to be used by previously algo (optional)
theNextAlgoData- to select hypos able to be used by next algo (optional)
theMeshType- type of mesh for filtering algorithms (optional)
Get available hypotheses or algorithm in accordance with input parameters. Result (theHyps) optionally depends on the following:
  • selected algorithm(s)
  • selected geometry
  • selected mesh type
References AddHyp, Algo, SMESH::GetAvailableHypotheses(), SMESH::GetGroupTitle(), SMESH::GetHypothesisData(), HypothesisData::GroupID, isCompatible(), isCompatibleToGeometry(), isCompatibleToMeshType(), HypothesisData::Label, myIsMesh, myIsOnGeometry, and HypothesisData::Priority.
Referenced by onAlgoSelected(), readMesh(), setFilteredAlgoData(), and updateHypoSets().
◆ checkSubMeshConcurrency()
bool SMESHGUI_MeshOp::checkSubMeshConcurrency ( SMESH::SMESH_Mesh_ptr  mesh,
bool  askUser = false
Returns true if a sub-mesh concurrency detected.
References _PTR(), SMESHGUI_MeshDlg::getActiveObject(), SMESHGUI::GetSMESHGUI(), SMESHGUI_SelectionOp::mesh(), myDlg, myToCreate, SMESHGUI_SelectionOp::onActivateObject(), SMESHGUI::OnGUIEvent(), SMESHOp::OpMeshOrder, selectionDone(), and selectObject().
Referenced by createSubMesh(), editMeshOrSubMesh(), and readMesh().
◆ commitOperation()
void SMESHGUI_MeshOp::commitOperation ( )
Virtual method redefined from base class called when operation is committed selects a recently created mesh or sub-mesh if necessary. Allows to perform selection when the custom selection filters are removed.
Reimplemented from SMESHGUI_SelectionOp.
References SMESHGUI_SelectionOp::commitOperation(), and myObjectToSelect.
◆ createFilter()
SUIT_SelectionFilter * SMESHGUI_MeshOp::createFilter ( const int  theId) const
theId- identifier of current selection widget
SUIT_SelectionFilter*- pointer to the created filter or null
Creates selection filter in accordance with identifier of current selection widget
References SMESHGUI_MeshDlg::Geom, SMESH::MESH, SMESHGUI_MeshDlg::Mesh, SMESH::MESHorSUBMESH, myToCreate, and SMESHGUI_MeshDlg::Obj.
◆ createHypothesis()
void SMESHGUI_MeshOp::createHypothesis ( const int  theDim,
const int  theType,
const QString &  theTypeName
theDim- dimension of hypothesis to be created
theType- hypothesis category (algorithm, hypothesis, additional hypothesis)
theTypeName- specifies hypothesis to be created
References HypothesisData::ClientLibName, SMESHGUI_GenericHypothesisCreator::create(), SMESH::CreateHypothesis(), getHypoNames(), SMESH::GetHypothesisCreator(), SMESH::GetHypothesisData(), getInitParamsHypothesis(), initHypCreator(), HypothesisData::Label, myDim, myDlg, myType, onHypoCreated(), SMESHGUI_SelectionOp::removeCustomFilters(), and HypothesisData::ServerLibName.
Referenced by onCreateHyp(), and onHypoSet().
◆ createMesh()
bool SMESHGUI_MeshOp::createMesh ( QString &  theMess,
QStringList &  theEntryList
◆ createSubMesh()
bool SMESHGUI_MeshOp::createSubMesh ( QString &  theMess,
Create sub-mesh.
theMess- Output parameter intended for returning error message
theEntryList- List of entries of published objects
bool- TRUE if sub-mesh is created, FALSE otherwise
References _PTR(), AddHyp, SMESH::AddHypothesisOnSubMesh(), checkSubMeshConcurrency(), currentHyp(), SMESH::DIM_0D, SMESH::DIM_3D, SMESHGUI_MeshDlg::Geom, getAlgo(), SMESHGUI::GetSMESHGen(), isAccessibleDim(), MainHyp, SMESHGUI_MeshDlg::Mesh, myDlg, myExistingHyps, myIsInvalidSubMesh, nbDlgHypTypes(), SMESHGUI_MeshDlg::Obj, selectionDone(), selectObject(), and SMESH::SetName().
Referenced by onApply().
◆ createSubMeshOnInternalEdges()
void SMESHGUI_MeshOp::createSubMeshOnInternalEdges ( SMESH::SMESH_Mesh_ptr  mesh,
◆ currentHyp()
int SMESHGUI_MeshOp::currentHyp ( const int  theDim,
theDim- dimension of hypothesis or algorithm
theHypType- Type of hypothesis (Algo, MainHyp, AddHyp)
int- index of current hypothesis or algorithm, -1 if None selected
References SMESHGUI_MeshTab::currentHyp(), myDlg, and SMESHGUI_MeshDlg::tab().
Referenced by createMesh(), createSubMesh(), editMeshOrSubMesh(), getAlgo(), isSelectedHyp(), logSmeshParams(), onAlgoSelected(), onHypoCreated(), readMesh(), and setFilteredAlgoData().
◆ dlg()
LightApp_Dialog * SMESHGUI_MeshOp::dlg ( ) const
LightApp_Dialog*- pointer to dialog of this operation
References myDlg.
Referenced by getAverageSize(), isValid(), onApply(), and onEditHyp().
◆ editMeshOrSubMesh()
bool SMESHGUI_MeshOp::editMeshOrSubMesh ( QString &  theMess,
bool- TRUE if mesh is edited successfully, FALSE otherwise
Assigns new name hypotheses and algorithms to the mesh or sub-mesh
References _PTR(), AddHyp, SMESH::AddHypothesisOnMesh(), SMESH::AddHypothesisOnSubMesh(), Algo, checkSubMeshConcurrency(), createSubMeshOnInternalEdges(), currentHyp(), SMESH::DIM_0D, SMESH::DIM_2D, SMESH::DIM_3D, existingHyps(), find(), getAlgo(), SMESHGUI::GetSMESHGen(), isSelectedHyp(), MainHyp, myDlg, myExistingHyps, myHasConcurrentSubBefore, myIsOnGeometry, myObjHyps, nbDlgHypTypes(), SMESHGUI_MeshDlg::Obj, SMESH::RemoveHypothesisOrAlgorithmOnMesh(), and SMESH::SetName().
◆ existingHyps()
void SMESHGUI_MeshOp::existingHyps ( const int  theDim,
_PTR(SObject)  theFather,
THypList &  theHypList,
HypothesisData *  theAlgoData = 0
theFather- start object for finding ( may be component, mesh, or sub-mesh )
theHyps- output list of names.
theHypVars- output list of variables.
theAlgoData- to select hypos able to be used by this algo (optional)
Gets existing (i.e. already created) hypotheses or algorithm in accordance with input parameters.
WARNING: when using this method to get hyps existing in Mesh component, call availableHyps() before in order to get only hyps of available types that was filtered by availableHyps()
References _PTR(), AddHyp, Algo, HypothesisData::Dim, SMESH::GetHypothesisData(), HypothesisData::IsAuxOrNeedHyp, isCompatible(), myAvailableHypData, SMESH::Tag_AlgorithmsRoot, SMESH::Tag_HypothesisRoot, SMESH::Tag_RefOnAppliedAlgorithms, and SMESH::Tag_RefOnAppliedHypothesis.
Referenced by editMeshOrSubMesh(), getAlgo(), isSubmeshIgnored(), onAlgoSelected(), onHypoCreated(), and readMesh().
◆ extractIds() [1/2]
void SMESHGUI_SelectionOp::extractIds ( const QStringList &  ids,
IdList &  list
References SMESHGUI_SelectionOp::extractIds(), and SMESHGUI_SelectionOp::idChar().
◆ extractIds() [2/2]
IdList &  list,
const QChar  idchar
◆ find()
int SMESHGUI_MeshOp::find ( const SMESH::SMESH_Hypothesis_var &  theHyp,
const THypList &  theHypList
theHyp- hypothesis to be found
theHypList- input list of hypotheses
int- index of hypothesis or -1 if it is not found
Finds position of hypothesis in input list
Referenced by editMeshOrSubMesh(), onAlgoSelected(), and readMesh().
◆ getAlgo()
SMESH::SMESH_Hypothesis_var SMESHGUI_MeshOp::getAlgo ( const int  theDim)
SMESH::SMESH_Hypothesis_var- algorithm
References _PTR(), Algo, HypothesisData::ClientLibName, SMESHGUI_GenericHypothesisCreator::create(), SMESH::CreateHypothesis(), currentHyp(), existingHyps(), SMESH::GetHypothesisCreator(), SMESH::GetHypothesisData(), HypothesisData::Label, myAvailableHypData, myDlg, and myExistingHyps.
Referenced by createMesh(), createSubMesh(), createSubMeshOnInternalEdges(), and editMeshOrSubMesh().
◆ getAverageSize()
bool SMESHGUI_MeshOp::getAverageSize ( double &  averageSize)
[out]averageSize- average element size
bool - false if the user canceled the dialog
References dlg(), SMESHGUI_GenericHypothesisCreator::edit(), HypothesesSet::getCommonHypoSetHypoType(), SMESH::GetHypothesisCreator(), SMESH::GetHypothesisData(), getInitParamsHypothesis(), hypData(), initHypCreator(), myDlg, onHypoEdited(), HypothesisData::ServerLibName, and HypothesisData::TypeName.
Referenced by onHypoSet().
◆ getHypoNames()
QStringList SMESHGUI_MeshOp::getHypoNames ( )
References myExistingHyps.
Referenced by createHypothesis(), createSubMeshOnInternalEdges(), and onHypoSet().
◆ getInitParamsHypothesis()
SMESH::SMESH_Hypothesis_var SMESHGUI_MeshOp::getInitParamsHypothesis ( const QString &  aHypType,
const QString &  aServerLib,
const SMESH::HypInitParams *  aParams = 0
aHypType- The hypothesis type name
aServerLib- Server library name
hypData- The structure holding the hypothesis type etc.
SMESH::SMESH_Hypothesis_var- the hypothesis holding parameter values
References _PTR(), SMESH::HypInitParams::averageLength, SMESHGUI_MeshDlg::Geom, SMESH::GetShapeOnMeshOrSubMesh(), SMESHGUI::GetSMESHGen(), SMESHGUI_MeshDlg::Mesh, myDlg, myIsMesh, myToCreate, SMESHGUI_MeshDlg::Obj, SMESH::HypInitParams::quadDominated, and SMESH::HypInitParams::way.
Referenced by createHypothesis(), createSubMeshOnInternalEdges(), getAverageSize(), onEditHyp(), and onHypoSet().
◆ getSMESHGUI()
◆ highlight()
void SMESHGUI_SelectionOp::highlight ( const Handle(SALOME_InteractiveObject)&  obj,
const bool  highlight,
const bool  immediately = true
◆ hypData()
HypothesisData * SMESHGUI_MeshOp::hypData ( const int  theDim,
const int  theIndex
theDim- hyp dimension
theHypType- hyp type (Algo,MainHyp or AddHyp)
theIndex- index in the list
HypothesisData*- result data, may be 0
References SMESH::DIM_3D, myAvailableHypData, and NbHypTypes.
Referenced by getAverageSize(), logSmeshParams(), onAlgoSelected(), onHypoCreated(), and setFilteredAlgoData().
◆ idChar()
QChar SMESHGUI_SelectionOp::idChar ( ) const
Referenced by SMESHGUI_SelectionOp::extractIds(), SMESHGUI_SelectionOp::selected(), and SMESHGUI_SelectionOp::typeById().
◆ initDialog()
void SMESHGUI_SelectionOp::initDialog ( )
◆ initHypCreator()
◆ isAccessibleDim()
bool SMESHGUI_MeshOp::isAccessibleDim ( const int  theDim) const
theDim- hypotheses dimension
bool- result
References SMESHGUI_MeshDlg::isTabEnabled(), and myDlg.
Referenced by createMesh(), createSubMesh(), createSubMeshOnInternalEdges(), and onAlgoSelected().
◆ isApplyAndClose()
bool SMESHGUI_Operation::isApplyAndClose ( ) const
◆ isCompatibleToGeometry()
bool SMESHGUI_MeshOp::isCompatibleToGeometry ( HypothesisData *  theAlgoData,
const int  theDim
theDim- algo dimension
bool- check result
References SMESH::IsApplicable(), myGeom, myGeomEntry, myHypMapIsApplicable, myIsMesh, myLastGeomEntry, and HypothesisData::TypeName.
Referenced by availableHyps().
◆ isCompatibleToMeshType()
bool SMESHGUI_MeshOp::isCompatibleToMeshType ( HypothesisData *  theAlgoData,
const int  theDim
bool- check result
References SMESHGUI_MeshDlg::currentMeshType(), MT_ANY, MT_HEXAHEDRAL, MT_QUADRILATERAL, MT_TETRAHEDRAL, MT_TRIANGULAR, myDlg, and HypothesisData::OutputTypes.
◆ isReadyToStart()
◆ isSelectedHyp()
bool SMESHGUI_MeshOp::isSelectedHyp ( int  theDim,
int  theHypType,
int  theIndex
References AddHyp, currentHyp(), and nbDlgHypTypes().
Referenced by editMeshOrSubMesh().
◆ isSubmeshIgnored()
char * SMESHGUI_MeshOp::isSubmeshIgnored ( ) const
char*- string is to be deleted!!!
References _PTR(), Algo, existingHyps(), SMESHGUI_MeshDlg::Geom, SMESH::GetHypothesisData(), HypothesisData::InputTypes, HypothesisData::IsSupportSubmeshes, SMESHGUI_MeshDlg::Mesh, myDlg, myIsMesh, and myToCreate.
◆ isSubshapeOk()
bool SMESHGUI_MeshOp::isSubshapeOk ( ) const
bool- check result
References _PTR(), SMESH::ContainsSubShape(), SMESHGUI_MeshDlg::Geom, SMESHGUI_MeshDlg::Mesh, SMESHGUI_SelectionOp::mesh(), myDlg, myIsMesh, and myToCreate.
Referenced by isValid().
◆ isValid() [1/2]
bool SMESHGUI_MeshOp::isValid ( QString &  theMess) const
bool- TRUE if input data is valid, false otherwise
Verifies validity of input data. This method is called when "Apply" or "OK" button is pressed before mesh creation or editing.
References _PTR(), dlg(), SMESHGUI_MeshDlg::Geom, isSubshapeOk(), SMESHGUI_MeshDlg::Mesh, myDlg, myIsInvalidSubMesh, myIsMesh, myToCreate, and SMESHGUI_MeshDlg::Obj.
◆ isValid() [2/2]
bool SMESHGUI_MeshOp::isValid ( SUIT_Operation *  theOp) const
theOtherOp- other operation
Returns TRUE if the given operator is valid for this one, FALSE otherwise
method redefined from base class verifies whether given operator is valid for this one (i.e. can be started "above" this operator). In current implementation method returns false if theOtherOp operation is not intended for deleting objects or mesh elements.
References SMESHGUI_Operation::isValid().
◆ logSmeshParams()
void SMESHGUI_MeshOp::logSmeshParams ( )
◆ mesh()
QString SMESHGUI_MeshOp::name ( _PTR(SObject)  theSO) const
theSO- SObject
QString- name of object
Gets name of object
References _PTR().
Referenced by createMesh(), and readMesh().
◆ nbDlgHypTypes()
int SMESHGUI_MeshOp::nbDlgHypTypes ( const int  dim) const
References myDlg, SMESHGUI_MeshTab::nbAddHypTypes(), NbHypTypes, and SMESHGUI_MeshDlg::tab().
Referenced by createMesh(), createSubMesh(), editMeshOrSubMesh(), isSelectedHyp(), and onAlgoSelected().
◆ onActivateObject
◆ onAlgoSelected
◆ onAlgoSetByMeshType
void SMESHGUI_MeshOp::onAlgoSetByMeshType ( const int  ,
const int
protectedslot
SLOT.
Is called when the user select type of mesh
theTabIndex- Index of current active tab
theIndex- Index of current type of mesh
References setFilteredAlgoData().
Referenced by startOperation().
◆ onApply
bool SMESHGUI_MeshOp::onApply ( )
protectedvirtualslot
bool- TRUE if operation is performed successfully, FALSE otherwise
Virtual slot redefined from the base class called when "Apply" button is clicked creates or edits mesh
References createMesh(), createSubMesh(), dlg(), editMeshOrSubMesh(), SMESHGUI_Operation::isApplyAndClose(), SMESHGUI::isStudyLocked(), isValid(), logSmeshParams(), SMESHGUI::Modified(), myDlg, myHypoSet, myIsInvalidSubMesh, myIsMesh, myObjectToSelect, myToCreate, and setDefaultName().
◆ onCancel
protectedvirtualslotinherited
◆ onCloseShapeByMeshDlg
void SMESHGUI_MeshOp::onCloseShapeByMeshDlg ( SUIT_Operation *  op)
protectedslot
SLOT.
Is called when Close is pressed in SMESHGUI_ShapeByMeshDlg
References myDlg, myShapeByMeshOp, and SMESHGUI_Dialog::show().
Referenced by onGeomSelectionByMesh().
◆ onCreateHyp
void SMESHGUI_MeshOp::onCreateHyp ( const int  theHypType,
const int  theIndex
protectedslot
Create hypothesis.
theHypType- hypothesis category (main or additional)
theIndex- index of type of hypothesis to be created
Specifies dimension of hypothesis to be created (using sender() method), specifies its type and calls method for hypothesis creation
References createHypothesis(), getTabDim(), myAvailableHypData, and myDlg.
◆ onDeactivateObject
void SMESHGUI_SelectionOp::onDeactivateObject ( int  )
References SMESHGUI_SelectionOp::removeCustomFilters().
Referenced by SMESHGUI_SelectionOp::startOperation().
◆ onEditHyp
void SMESHGUI_MeshOp::onEditHyp ( const int  theHypType,
const int  theIndex
protectedslot
theHypType- specifies whether main hypothesis or additional one is edited
theIndex- index of existing hypothesis
References dlg(), SMESHGUI_GenericHypothesisCreator::edit(), SMESH::GetHypothesisCreator(), getInitParamsHypothesis(), getTabDim(), initHypCreator(), myDlg, myExistingHyps, onHypoEdited(), SMESHGUI_SelectionOp::removeCustomFilters(), and SMESHGUI_GenericHypothesisCreator::setInitParamsHypothesis().
◆ onGeomSelectionByMesh
void SMESHGUI_MeshOp::onGeomSelectionByMesh ( bool  theByMesh)
protectedslot
SLOT.
Is called when the user selects a way of geometry selection
theByMesh- true if the user wants to find geometry by mesh element
References _PTR(), SMESHGUI_Operation::getSMESHGUI(), SMESHGUI_MeshDlg::Mesh, myDlg, myShapeByMeshOp, onCloseShapeByMeshDlg(), onPublishShapeByMeshDlg(), and SMESHGUI_ShapeByMeshOp::SetMesh().
◆ onHelp
protectedslotinherited
◆ onHypoCreated
void SMESHGUI_MeshOp::onHypoCreated ( int  result)
protectedslot
result- creation result: 0 = rejected 1 = accepted 2 = additional value meaning that slot is called not from dialog box
References _PTR(), SMESHGUI_MeshTab::addHyp(), Algo, currentHyp(), existingHyps(), SMESHGUI_MeshDlg::getActiveObject(), hypData(), myDim, myDlg, myExistingHyps, myType, SMESHGUI_SelectionOp::onActivateObject(), SMESHGUI_Dialog::show(), and SMESHGUI_MeshDlg::tab().
Referenced by createHypothesis(), and onHypoSet().
◆ onHypoEdited
void SMESHGUI_MeshOp::onHypoEdited ( int  )
protectedslot
References SMESHGUI_MeshDlg::getActiveObject(), myDlg, SMESHGUI_SelectionOp::onActivateObject(), and SMESHGUI_Dialog::show().
Referenced by getAverageSize(), and onEditHyp().
◆ onHypoSet
◆ onOk
◆ onPublishShapeByMeshDlg
void SMESHGUI_MeshOp::onPublishShapeByMeshDlg ( SUIT_Operation *  op)
protectedslot
◆ onSelectionChanged
void SMESHGUI_SelectionOp::onSelectionChanged ( int  )
In successors it may be used for more advanced selection checking. This slot is connected to signal when the selection changed in some object selection widget
◆ onTextChanged
void SMESHGUI_SelectionOp::onTextChanged ( int  ,
const QStringList &  list
In order to run default mechanism, you must set for some object selection widget the "name indication" to "ListOfNames", "read only" state to false and connect the dialog's signal "objectChanged" to this slot Warning: this mechanism can process only integer ids, NOT MESH OR GROUP NAMES!!!
References SMESHGUI_SelectionOp::actor(), SMESHGUI_SelectionOp::extractIds(), SMDS_Mesh::FindElement(), SMDS_Mesh::FindNode(), SMESH_Actor::GetObject(), SMESHGUI_SelectionOp::highlight(), SMESHGUI_SelectionOp::selected(), SMESHGUI_SelectionOp::selectionMode(), and SMESHGUI_SelectionOp::selector().
Referenced by SMESHGUI_Add0DElemsOnAllNodesOp::onTextChanged().
◆ readMesh()
◆ removeCustomFilters()
◆ selected()
◆ selectedIds()
void SMESHGUI_SelectionOp::selectedIds ( const int  id,
IdList &  list
References SMESHGUI_SelectionOp::extractIds().
◆ selectionDone()
virtual void SMESHGUI_MeshOp::selectionDone ( )
◆ selectionMode()
◆ selectObject()
void SMESHGUI_MeshOp::selectObject ( _PTR(SObject)  theSObj) const
Selects a SObject.
theSObj- the SObject to select
References Handle().
Referenced by checkSubMeshConcurrency(), createSubMesh(), and onPublishShapeByMeshDlg().
◆ selector()
◆ setCurrentHyp()
void SMESHGUI_MeshOp::setCurrentHyp ( const int  theDim,
const int  theIndex,
const bool  updateHypsOnAlgoDeselection = false
theIndex- Index of hypothesis
updateHypsOnAlgoDeselection- to clear and disable hyps if algo deselected
Gets current hypothesis or algorithms
References AddHyp, Algo, MainHyp, myDlg, myIgnoreAlgoSelection, SMESHGUI_MeshTab::setAvailableHyps(), SMESHGUI_MeshTab::setCurrentHyp(), SMESHGUI_MeshTab::setExistingHyps(), and SMESHGUI_MeshDlg::tab().
Referenced by createSubMeshOnInternalEdges(), onAlgoSelected(), onHypoSet(), readMesh(), and setFilteredAlgoData().
◆ setDefaultName()
void SMESHGUI_MeshOp::setDefaultName ( const QString &  thePrefix = "") const
Generates and sets default mesh/submesh name(Mesh_1, Mesh_2, etc.)
References _PTR(), myDlg, myIsMesh, and SMESHGUI_MeshDlg::Obj.
Referenced by createMesh(), onApply(), and startOperation().
◆ setDialogActive()
References MESHCUT::d.
◆ setFilteredAlgoData()
◆ setIsApplyAndClose()
◆ setSelectionMode()
◆ startOperation()
◆ typeById()
int SMESHGUI_SelectionOp::typeById ( const QString &  str,
const EntityType  objtype
◆ updateHypoSets()
◆ updateMeshTypeList()
void SMESHGUI_MeshOp::updateMeshTypeList ( )
References myDlg, myMaxShapeDim, and SMESHGUI_MeshDlg::setAvailableMeshType().
Referenced by setFilteredAlgoData(), and startOperation().
◆ viewWindow()
◆ myAvailableHypData
◆ myAverageSize
double SMESHGUI_MeshOp::myAverageSize
◆ myDefSelectionMode
Selection_Mode SMESHGUI_SelectionOp::myDefSelectionMode
privateinherited
◆ myDim
int SMESHGUI_MeshOp::myDim
◆ myDlg
◆ myExistingHyps
TDim2Type2HypList SMESHGUI_MeshOp::myExistingHyps
◆ myFilters
Filters SMESHGUI_SelectionOp::myFilters
privateinherited
◆ myGeom
GEOM::GEOM_Object_var SMESHGUI_MeshOp::myGeom
◆ myGeomEntry
QString SMESHGUI_MeshOp::myGeomEntry
◆ myHasConcurrentSubBefore
bool SMESHGUI_MeshOp::myHasConcurrentSubBefore
◆ myHelpFileName
◆ myHypMapIsApplicable
THypLabelIsAppMap SMESHGUI_MeshOp::myHypMapIsApplicable
◆ myHypoSet
HypothesesSet* SMESHGUI_MeshOp::myHypoSet
◆ myIgnoreAlgoSelection
bool SMESHGUI_MeshOp::myIgnoreAlgoSelection
◆ myIsApplyAndClose
◆ myIsInvalidSubMesh
bool SMESHGUI_MeshOp::myIsInvalidSubMesh
Referenced by createSubMesh(), isValid(), onApply(), and readMesh().
◆ myIsMesh
◆ myIsOnGeometry
bool SMESHGUI_MeshOp::myIsOnGeometry
Referenced by availableHyps(), editMeshOrSubMesh(), initHypCreator(), readMesh(), and SMESHGUI_MeshOp().
◆ myLastGeomEntry
QString SMESHGUI_MeshOp::myLastGeomEntry
◆ myMaxShapeDim
int SMESHGUI_MeshOp::myMaxShapeDim
◆ myObjectToSelect
QString SMESHGUI_MeshOp::myObjectToSelect
◆ myObjHyps
TDim2Type2HypList SMESHGUI_MeshOp::myObjHyps
◆ myOldSelectionMode
Selection_Mode SMESHGUI_SelectionOp::myOldSelectionMode
privateinherited
◆ myShapeByMeshOp
SMESHGUI_ShapeByMeshOp* SMESHGUI_MeshOp::myShapeByMeshOp
◆ myToCreate
◆ myType
int SMESHGUI_MeshOp::myType
