SMESHGUI_ReorientFacesOp Class Reference
================================================================================ More...
#include <SMESHGUI_ReorientFacesDlg.h>
Inheritance diagram for SMESHGUI_ReorientFacesOp:
typedef QList< int > IdList
 SMESHGUI_ReorientFacesOp ()
virtual ~SMESHGUI_ReorientFacesOp ()
 Gets dialog of this operation. More...
static void extractIds (const QStringList &, IdList &, const QChar)
Protected Types
enum  EntityType { Object , MeshNode , MeshElement }
Protected Slots
virtual bool onApply ()
 perform it's intention action: reorient faces of myObject More...
virtual void onDeactivateObject (int)
 Removes filter corresponding to certain object selection widget. More...
virtual void onSelectionChanged (int)
 Empty default implementation. More...
virtual void onTextChanged (int, const QStringList &)
 Default implementation allowing user to edit selected ids "by hands". More...
virtual void onOk ()
virtual void onCancel ()
void onHelp ()
 This enumeration is used in typeById method to distinguish objects, mesh nodes and mesh elements, because node end element ids may overlap. More...
virtual void stopOperation ()
 Stops operation. More...
virtual SUIT_SelectionFilter * createFilter (const int) const
 Creates a filter corresponding to a pressed selection button. More...
virtual void selectionDone ()
 get data from selection More...
bool isValid (QString &)
 Check data validity. More...
void setRefFiltersByConstructor ()
 Switch between selection of faces and volumes according to the constructor. More...
int constructorID ()
 ID of a current constructor: CONSTRUCTOR_FACE, CONSTRUCTOR_POINT etc. More...
void extractIds (const QStringList &, IdList &) const
 Find in QStringList correct node or element ids representation and append integer(id) to IdList. More...
virtual void initDialog ()
void removeCustomFilters ()
 Remove only filters set by this operation (they are in map myFilters ) More...
Selection_Mode selectionMode () const
 Return what selection mode is set in VTK viewer. More...
void setSelectionMode (const Selection_Mode)
 Set selection mode in VTK viewer. More...
void highlight (const Handle(SALOME_InteractiveObject)&, const bool, const bool=true)
 Highlight object in VTK viewer. More...
void addOrRemoveIndex (const Handle(SALOME_InteractiveObject)&, const SVTK_TVtkIDsMap &, const bool isModeShift)
 Select some nodes or elements in VTK. More...
SVTK_ViewWindow * viewWindow () const
SVTK_Selector * selector () const
virtual void selected (QStringList &, SMESHGUI_Dialog::TypesList &, QStringList &) const
 Get names, types and ids of selected objects. More...
virtual int typeById (const QString &, const EntityType) const
 Find type by id. More...
virtual QChar idChar () const
 Char using to divide <entry> and <id> in string id representation. By default, '#'. More...
void selectedIds (const int, IdList &) const
 Try to find in certain object selection widget selected node or element ids and return it. More...
SMESH::SMESH_Mesh_var mesh () const
 Return selected mesh if selection mode isn't ActorSelection and only one object is selected. More...
SMESH_Actor * actor () const
 Return actor according to selected mesh if selection mode isn't ActorSelection. More...
virtual bool isValid (SUIT_Operation *) const
QString myHelpFileName
bool myIsApplyAndClose
Private Types
typedef QMap< int, SUIT_SelectionFilter * > Filters
Private Slots
virtual void onActivateObject (int)
 Set selection mode corresponding to a pressed selection button. More...
void redisplayPreview ()
 update preview More...
void onTextChange (const QString &)
 SLOT called when the face id is changed. More...
bool onlyOneObjAllowed ()
 Check if selection of multiple objects allowed. More...
SMESHGUI_ReorientFacesDlg * myDlg
SMESH_Actor * myObjectActor
int mySelectionMode
SMESH_TypeFilter * myRefGroupFilter
SMESH_TypeFilter * myRefSubMeshFilter
SMESH_TypeFilter * myRefMeshFilter
SMESH::ListOfIDSources_var myObjects
SMESH::ListOfIDSources_var myRefGroups
Filters myFilters
Selection_Mode myDefSelectionMode
Selection_Mode myOldSelectionMode
Operation to reorient faces according to some criterion
◆ Filters
typedef QMap<int, SUIT_SelectionFilter*> SMESHGUI_SelectionOp::Filters
privateinherited
◆ IdList
typedef QList<int> SMESHGUI_SelectionOp::IdList
◆ EntityType
enum SMESHGUI_SelectionOp::EntityType
Object
MeshNode
MeshElement
◆ SMESHGUI_ReorientFacesOp()
◆ ~SMESHGUI_ReorientFacesOp()
SMESHGUI_ReorientFacesOp::~SMESHGUI_ReorientFacesOp ( )
References myDlg.
◆ abortOperation()
void SMESHGUI_SelectionOp::abortOperation ( )
◆ actor()
SMESH_Actor * SMESHGUI_SelectionOp::actor ( ) const
◆ addOrRemoveIndex()
void SMESHGUI_SelectionOp::addOrRemoveIndex ( const Handle(SALOME_InteractiveObject)&  obj,
const SVTK_TVtkIDsMap &  indices,
References SMESHGUI_SelectionOp::selector().
Referenced by SMESHGUI_FindElemByPointOp::onElemSelected(), and onTextChange().
◆ commitOperation()
◆ constructorID()
int SMESHGUI_ReorientFacesOp::constructorID ( )
References SMESHGUI_ReorientFacesDlg::myConstructorGrp, and myDlg.
Referenced by isValid(), onApply(), onlyOneObjAllowed(), and setRefFiltersByConstructor().
◆ createFilter()
SUIT_SelectionFilter * SMESHGUI_ReorientFacesOp::createFilter ( const int  what) const
◆ dlg()
LightApp_Dialog * SMESHGUI_ReorientFacesOp::dlg ( ) const
LightApp_Dialog*- pointer to dialog of this operation
References myDlg.
Referenced by onApply().
◆ extractIds() [1/2]
void SMESHGUI_SelectionOp::extractIds ( const QStringList &  ids,
IdList &  list
References SMESHGUI_SelectionOp::extractIds(), and SMESHGUI_SelectionOp::idChar().
◆ extractIds() [2/2]
IdList &  list,
const QChar  idchar
◆ getSMESHGUI()
◆ highlight()
void SMESHGUI_SelectionOp::highlight ( const Handle(SALOME_InteractiveObject)&  obj,
const bool  highlight,
const bool  immediately = true
◆ idChar()
QChar SMESHGUI_SelectionOp::idChar ( ) const
Referenced by SMESHGUI_SelectionOp::extractIds(), SMESHGUI_SelectionOp::selected(), and SMESHGUI_SelectionOp::typeById().
◆ initDialog()
void SMESHGUI_SelectionOp::initDialog ( )
◆ isApplyAndClose()
◆ isReadyToStart()
◆ isValid() [1/2]
◆ isValid() [2/2]
bool SMESHGUI_Operation::isValid ( SUIT_Operation *  theOtherOp) const
theOtherOp- other operation
Returns TRUE if the given operator is valid for this one, FALSE otherwise
Virtual method redefined from base class verifies whether given operator is valid for this one (i.e. can be started "above" this operator). In current implementation method returns false if theOtherOp operation is not intended for deleting objects or mesh elements.
Reimplemented in SMESHGUI_MeshOp, and SMESHGUI_BaseComputeOp.
Referenced by SMESHGUI_MeshOp::isValid().
◆ mesh()
◆ onActivateObject
void SMESHGUI_ReorientFacesOp::onActivateObject ( int  what)
privatevirtualslot
◆ onApply
◆ onCancel
protectedvirtualslotinherited
◆ onDeactivateObject
void SMESHGUI_SelectionOp::onDeactivateObject ( int  )
References SMESHGUI_SelectionOp::removeCustomFilters().
Referenced by SMESHGUI_SelectionOp::startOperation().
◆ onHelp
protectedslotinherited
◆ onlyOneObjAllowed
bool SMESHGUI_ReorientFacesOp::onlyOneObjAllowed ( )
privateslot
References CONSTRUCTOR_FACE, CONSTRUCTOR_VOLUME, constructorID(), ERefGroups, and mySelectionMode.
Referenced by onActivateObject(), and selectionDone().
◆ onOk
◆ onSelectionChanged
void SMESHGUI_SelectionOp::onSelectionChanged ( int  )
In successors it may be used for more advanced selection checking. This slot is connected to signal when the selection changed in some object selection widget
◆ onTextChange
void SMESHGUI_ReorientFacesOp::onTextChange ( const QString &  theText)
privateslot
◆ onTextChanged
void SMESHGUI_SelectionOp::onTextChanged ( int  ,
const QStringList &  list
In order to run default mechanism, you must set for some object selection widget the "name indication" to "ListOfNames", "read only" state to false and connect the dialog's signal "objectChanged" to this slot Warning: this mechanism can process only integer ids, NOT MESH OR GROUP NAMES!!!
References SMESHGUI_SelectionOp::actor(), SMESHGUI_SelectionOp::extractIds(), SMDS_Mesh::FindElement(), SMDS_Mesh::FindNode(), SMESH_Actor::GetObject(), SMESHGUI_SelectionOp::highlight(), SMESHGUI_SelectionOp::selected(), SMESHGUI_SelectionOp::selectionMode(), and SMESHGUI_SelectionOp::selector().
Referenced by SMESHGUI_Add0DElemsOnAllNodesOp::onTextChanged().
◆ redisplayPreview
void SMESHGUI_ReorientFacesOp::redisplayPreview ( )
privateslot
update preview
Referenced by selectionDone().
◆ removeCustomFilters()
◆ selected()
◆ selectedIds()
void SMESHGUI_SelectionOp::selectedIds ( const int  id,
IdList &  list
References SMESHGUI_SelectionOp::extractIds().
◆ selectionDone()
◆ selectionMode()
◆ selector()
◆ setDialogActive()
References MESHCUT::d.
◆ setIsApplyAndClose()
◆ setRefFiltersByConstructor()
void SMESHGUI_ReorientFacesOp::setRefFiltersByConstructor ( )
◆ setSelectionMode()
◆ startOperation()
void SMESHGUI_ReorientFacesOp::startOperation ( )
Reimplemented from SMESHGUI_SelectionOp.
References EObject, myDlg, myObjectActor, mySelectionMode, selectionDone(), SMESHGUI_Dialog::show(), and SMESHGUI_SelectionOp::startOperation().
◆ stopOperation()
void SMESHGUI_ReorientFacesOp::stopOperation ( )
◆ typeById()
int SMESHGUI_SelectionOp::typeById ( const QString &  str,
const EntityType  objtype
◆ viewWindow()
◆ myDefSelectionMode
Selection_Mode SMESHGUI_SelectionOp::myDefSelectionMode
privateinherited
◆ myDlg
◆ myFilters
Filters SMESHGUI_SelectionOp::myFilters
privateinherited
◆ myHelpFileName
◆ myIsApplyAndClose
◆ myObjectActor
SMESH_Actor* SMESHGUI_ReorientFacesOp::myObjectActor
◆ myObjects
SMESH::ListOfIDSources_var SMESHGUI_ReorientFacesOp::myObjects
◆ myOldSelectionMode
Selection_Mode SMESHGUI_SelectionOp::myOldSelectionMode
privateinherited
◆ myRefGroupFilter
SMESH_TypeFilter* SMESHGUI_ReorientFacesOp::myRefGroupFilter
◆ myRefGroups
SMESH::ListOfIDSources_var SMESHGUI_ReorientFacesOp::myRefGroups
◆ myRefMeshFilter
SMESH_TypeFilter* SMESHGUI_ReorientFacesOp::myRefMeshFilter
◆ myRefSubMeshFilter
SMESH_TypeFilter* SMESHGUI_ReorientFacesOp::myRefSubMeshFilter
◆ mySelectionMode
int SMESHGUI_ReorientFacesOp::mySelectionMode
