SMESHGUI_GroupOnShapeOp Class Reference
#include <SMESHGUI_GroupOnShapeDlg.h>
Inheritance diagram for SMESHGUI_GroupOnShapeOp:
typedef QList< int > IdList
 SMESHGUI_GroupOnShapeOp ()
 operation constructor More...
 ~SMESHGUI_GroupOnShapeOp ()
 Gets dialog of this operation. More...
static QString GetDefaultName (const QString &theOperation)
static SMESH::ElementType ElementType (GEOM::GEOM_Object_var geom)
 return type of mesh group by geom object More...
static void extractIds (const QStringList &, IdList &, const QChar)
Protected Types
enum  EntityType { Object , MeshNode , MeshElement }
Protected Slots
virtual void onActivateObject (int)
 Installs filter corresponding to certain object selection widget. More...
virtual void onDeactivateObject (int)
 Removes filter corresponding to certain object selection widget. More...
virtual void onSelectionChanged (int)
 Empty default implementation. More...
virtual void onTextChanged (int, const QStringList &)
 Default implementation allowing user to edit selected ids "by hands". More...
virtual void onOk ()
virtual void onCancel ()
void onHelp ()
 start operation More...
virtual void selectionDone ()
 Updates dialog's look and feel. More...
virtual SUIT_SelectionFilter * createFilter (const int) const
 Creates selection filter. More...
void extractIds (const QStringList &, IdList &) const
 Find in QStringList correct node or element ids representation and append integer(id) to IdList. More...
virtual void initDialog ()
void removeCustomFilters ()
 Remove only filters set by this operation (they are in map myFilters ) More...
Selection_Mode selectionMode () const
 Return what selection mode is set in VTK viewer. More...
void setSelectionMode (const Selection_Mode)
 Set selection mode in VTK viewer. More...
void highlight (const Handle(SALOME_InteractiveObject)&, const bool, const bool=true)
 Highlight object in VTK viewer. More...
void addOrRemoveIndex (const Handle(SALOME_InteractiveObject)&, const SVTK_TVtkIDsMap &, const bool isModeShift)
 Select some nodes or elements in VTK. More...
SVTK_ViewWindow * viewWindow () const
SVTK_Selector * selector () const
virtual void selected (QStringList &, SMESHGUI_Dialog::TypesList &, QStringList &) const
 Get names, types and ids of selected objects. More...
virtual int typeById (const QString &, const EntityType) const
 Find type by id. More...
virtual QChar idChar () const
 Char using to divide <entry> and <id> in string id representation. By default, '#'. More...
void selectedIds (const int, IdList &) const
 Try to find in certain object selection widget selected node or element ids and return it. More...
SMESH::SMESH_Mesh_var mesh () const
 Return selected mesh if selection mode isn't ActorSelection and only one object is selected. More...
SMESH_Actor * actor () const
 Return actor according to selected mesh if selection mode isn't ActorSelection. More...
virtual bool isValid (SUIT_Operation *) const
QString myHelpFileName
bool myIsApplyAndClose
Private Types
typedef QMap< int, SUIT_SelectionFilter * > Filters
Private Slots
bool onApply ()
 create groups More...
void onButtonClick ()
 slot connected to selection buttons More...
void init ()
 initialization More...
SMESHGUI_GroupOnShapeDlg * myDlg
QString myMeshID
QStringList myElemGeoIDs
QStringList myNodeGeoIDs
Filters myFilters
Selection_Mode myDefSelectionMode
Selection_Mode myOldSelectionMode
◆ Filters
typedef QMap<int, SUIT_SelectionFilter*> SMESHGUI_SelectionOp::Filters
privateinherited
◆ IdList
typedef QList<int> SMESHGUI_SelectionOp::IdList
◆ EntityType
enum SMESHGUI_SelectionOp::EntityType
Object
MeshNode
MeshElement
◆ SMESHGUI_GroupOnShapeOp()
SMESHGUI_GroupOnShapeOp::SMESHGUI_GroupOnShapeOp ( )
References SMESHGUI_Operation::myHelpFileName.
◆ ~SMESHGUI_GroupOnShapeOp()
SMESHGUI_GroupOnShapeOp::~SMESHGUI_GroupOnShapeOp ( )
References myDlg.
◆ abortOperation()
void SMESHGUI_SelectionOp::abortOperation ( )
◆ actor()
SMESH_Actor * SMESHGUI_SelectionOp::actor ( ) const
◆ addOrRemoveIndex()
void SMESHGUI_SelectionOp::addOrRemoveIndex ( const Handle(SALOME_InteractiveObject)&  obj,
const SVTK_TVtkIDsMap &  indices,
◆ commitOperation()
◆ createFilter()
SUIT_SelectionFilter * SMESHGUI_GroupOnShapeOp::createFilter ( const int  theId) const
theId- identifier of current selection widget
SUIT_SelectionFilter*- pointer to the created filter or null
Creates selection filter in accordance with identifier of current selection widget
Reimplemented from SMESHGUI_SelectionOp.
References _ELEM_GEOM, _MESH, _NODE_GEOM, and SMESH::MESH.
◆ dlg()
LightApp_Dialog * SMESHGUI_GroupOnShapeOp::dlg ( ) const
LightApp_Dialog*- pointer to dialog of this operation
References myDlg.
◆ ElementType()
SMESH::ElementType SMESHGUI_GroupOnShapeOp::ElementType ( GEOM::GEOM_Object_var  geom)
◆ extractIds() [1/2]
void SMESHGUI_SelectionOp::extractIds ( const QStringList &  ids,
IdList &  list
References SMESHGUI_SelectionOp::extractIds(), and SMESHGUI_SelectionOp::idChar().
◆ extractIds() [2/2]
IdList &  list,
const QChar  idchar
◆ GetDefaultName()
static QString SMESHGUI_GroupOnShapeOp::GetDefaultName ( const QString &  theOperation)
◆ getSMESHGUI()
◆ highlight()
void SMESHGUI_SelectionOp::highlight ( const Handle(SALOME_InteractiveObject)&  obj,
const bool  highlight,
const bool  immediately = true
◆ idChar()
QChar SMESHGUI_SelectionOp::idChar ( ) const
Referenced by SMESHGUI_SelectionOp::extractIds(), SMESHGUI_SelectionOp::selected(), and SMESHGUI_SelectionOp::typeById().
◆ init()
◆ initDialog()
void SMESHGUI_SelectionOp::initDialog ( )
◆ isApplyAndClose()
bool SMESHGUI_Operation::isApplyAndClose ( ) const
◆ isReadyToStart()
◆ isValid()
bool SMESHGUI_Operation::isValid ( SUIT_Operation *  theOtherOp) const
theOtherOp- other operation
Returns TRUE if the given operator is valid for this one, FALSE otherwise
Virtual method redefined from base class verifies whether given operator is valid for this one (i.e. can be started "above" this operator). In current implementation method returns false if theOtherOp operation is not intended for deleting objects or mesh elements.
Reimplemented in SMESHGUI_MeshOp, and SMESHGUI_BaseComputeOp.
Referenced by SMESHGUI_MeshOp::isValid().
◆ mesh()
◆ onActivateObject
◆ onApply
◆ onButtonClick
◆ onCancel
protectedvirtualslotinherited
◆ onDeactivateObject
void SMESHGUI_SelectionOp::onDeactivateObject ( int  )
References SMESHGUI_SelectionOp::removeCustomFilters().
Referenced by SMESHGUI_SelectionOp::startOperation().
◆ onHelp
protectedslotinherited
◆ onOk
◆ onSelectionChanged
void SMESHGUI_SelectionOp::onSelectionChanged ( int  )
In successors it may be used for more advanced selection checking. This slot is connected to signal when the selection changed in some object selection widget
◆ onTextChanged
void SMESHGUI_SelectionOp::onTextChanged ( int  ,
const QStringList &  list
In order to run default mechanism, you must set for some object selection widget the "name indication" to "ListOfNames", "read only" state to false and connect the dialog's signal "objectChanged" to this slot Warning: this mechanism can process only integer ids, NOT MESH OR GROUP NAMES!!!
References SMESHGUI_SelectionOp::actor(), SMESHGUI_SelectionOp::extractIds(), SMDS_Mesh::FindElement(), SMDS_Mesh::FindNode(), SMESH_Actor::GetObject(), SMESHGUI_SelectionOp::highlight(), SMESHGUI_SelectionOp::selected(), SMESHGUI_SelectionOp::selectionMode(), and SMESHGUI_SelectionOp::selector().
Referenced by SMESHGUI_Add0DElemsOnAllNodesOp::onTextChanged().
◆ removeCustomFilters()
◆ selected()
◆ selectedIds()
void SMESHGUI_SelectionOp::selectedIds ( const int  id,
IdList &  list
References SMESHGUI_SelectionOp::extractIds().
◆ selectionDone()
◆ selectionMode()
◆ selector()
◆ setDialogActive()
References MESHCUT::d.
◆ setIsApplyAndClose()
◆ setSelectionMode()
◆ startOperation()
◆ typeById()
int SMESHGUI_SelectionOp::typeById ( const QString &  str,
const EntityType  objtype
◆ viewWindow()
◆ myDefSelectionMode
Selection_Mode SMESHGUI_SelectionOp::myDefSelectionMode
privateinherited
◆ myDlg
◆ myElemGeoIDs
QStringList SMESHGUI_GroupOnShapeOp::myElemGeoIDs
Referenced by init(), onApply(), and selectionDone().
◆ myFilters
Filters SMESHGUI_SelectionOp::myFilters
privateinherited
◆ myHelpFileName
◆ myIsApplyAndClose
◆ myMeshID
QString SMESHGUI_GroupOnShapeOp::myMeshID
◆ myNodeGeoIDs
QStringList SMESHGUI_GroupOnShapeOp::myNodeGeoIDs
◆ myOldSelectionMode
Selection_Mode SMESHGUI_SelectionOp::myOldSelectionMode
privateinherited
