SMESHGUI_ShapeByMeshOp Class Reference
Operation to publish a sub-shape of the mesh main shape by selecting mesh elements. More...
#include <SMESHGUI_ShapeByMeshDlg.h>
Inheritance diagram for SMESHGUI_ShapeByMeshOp:
typedef QList< int > IdList
 SMESHGUI_ShapeByMeshOp (bool=false)
virtual ~SMESHGUI_ShapeByMeshOp ()
 Gets dialog of this operation. More...
void Init ()
void SetMesh (SMESH::SMESH_Mesh_ptr)
SMESH::SMESH_Mesh_ptr GetMesh ()
GEOM::GEOM_Object_ptr GetShape ()
static void extractIds (const QStringList &, IdList &, const QChar)
Protected Types
enum  EntityType { Object , MeshNode , MeshElement }
Protected Slots
virtual bool onApply ()
virtual void onActivateObject (int)
 Installs filter corresponding to certain object selection widget. More...
virtual void onDeactivateObject (int)
 Removes filter corresponding to certain object selection widget. More...
virtual void onSelectionChanged (int)
 Empty default implementation. More...
virtual void onTextChanged (int, const QStringList &)
 Default implementation allowing user to edit selected ids "by hands". More...
virtual void onOk ()
virtual void onCancel ()
void onHelp ()
 This enumeration is used in typeById method to distinguish objects, mesh nodes and mesh elements, because node end element ids may overlap. More...
void activateSelection ()
void setElementID (const QString &)
void extractIds (const QStringList &, IdList &) const
 Find in QStringList correct node or element ids representation and append integer(id) to IdList. More...
virtual void selectionDone ()
virtual void initDialog ()
virtual SUIT_SelectionFilter * createFilter (const int) const
 Creates filter being used when certain object selection widget is active If no filter must be used, then function must return 0 if id is negative, then function must return filter for common using independently of active widget. More...
void removeCustomFilters ()
 Remove only filters set by this operation (they are in map myFilters ) More...
Selection_Mode selectionMode () const
 Return what selection mode is set in VTK viewer. More...
void setSelectionMode (const Selection_Mode)
 Set selection mode in VTK viewer. More...
void highlight (const Handle(SALOME_InteractiveObject)&, const bool, const bool=true)
 Highlight object in VTK viewer. More...
void addOrRemoveIndex (const Handle(SALOME_InteractiveObject)&, const SVTK_TVtkIDsMap &, const bool isModeShift)
 Select some nodes or elements in VTK. More...
SVTK_ViewWindow * viewWindow () const
SVTK_Selector * selector () const
virtual void selected (QStringList &, SMESHGUI_Dialog::TypesList &, QStringList &) const
 Get names, types and ids of selected objects. More...
virtual int typeById (const QString &, const EntityType) const
 Find type by id. More...
virtual QChar idChar () const
 Char using to divide <entry> and <id> in string id representation. By default, '#'. More...
void selectedIds (const int, IdList &) const
 Try to find in certain object selection widget selected node or element ids and return it. More...
SMESH::SMESH_Mesh_var mesh () const
 Return selected mesh if selection mode isn't ActorSelection and only one object is selected. More...
SMESH_Actor * actor () const
 Return actor according to selected mesh if selection mode isn't ActorSelection. More...
virtual bool isValid (SUIT_Operation *) const
QString myHelpFileName
bool myIsApplyAndClose
Private Types
typedef QMap< int, SUIT_SelectionFilter * > Filters
Private Slots
void onSelectionDone ()
void onTypeChanged (int)
void onElemIdChanged (const QString &)
SMESHGUI_ShapeByMeshDlg * myDlg
SMESH::SMESH_Mesh_var myMesh
GEOM::GEOM_Object_var myGeomObj
bool myIsManualIdEnter
bool myHasSolids
bool myIsMultipleAllowed
Filters myFilters
Selection_Mode myDefSelectionMode
Selection_Mode myOldSelectionMode
◆ Filters
typedef QMap<int, SUIT_SelectionFilter*> SMESHGUI_SelectionOp::Filters
privateinherited
◆ IdList
typedef QList<int> SMESHGUI_SelectionOp::IdList
◆ EntityType
enum SMESHGUI_SelectionOp::EntityType
Object
MeshNode
MeshElement
◆ SMESHGUI_ShapeByMeshOp()
SMESHGUI_ShapeByMeshOp::SMESHGUI_ShapeByMeshOp ( bool  isMultipleAllowed = false)
◆ ~SMESHGUI_ShapeByMeshOp()
SMESHGUI_ShapeByMeshOp::~SMESHGUI_ShapeByMeshOp ( )
References myDlg.
◆ abortOperation()
void SMESHGUI_SelectionOp::abortOperation ( )
◆ activateSelection()
◆ actor()
SMESH_Actor * SMESHGUI_SelectionOp::actor ( ) const
◆ addOrRemoveIndex()
void SMESHGUI_SelectionOp::addOrRemoveIndex ( const Handle(SALOME_InteractiveObject)&  obj,
const SVTK_TVtkIDsMap &  indices,
◆ commitOperation()
◆ createFilter()
SUIT_SelectionFilter * SMESHGUI_SelectionOp::createFilter ( const int  ) const
Reimplemented in SMESHGUI_Add0DElemsOnAllNodesOp, SMESHGUI_ConvToQuadOp, SMESHGUI_CreateDualMeshOp, SMESHGUI_GroupOnShapeOp, SMESHGUI_Make2DFrom3DOp, SMESHGUI_MakeFull2DFrom3DOp, SMESHGUI_MeshOp, SMESHGUI_ReorientFacesOp, and SMESHGUI_SplitBiQuadOp.
Referenced by SMESHGUI_SelectionOp::onActivateObject().
◆ dlg()
LightApp_Dialog * SMESHGUI_ShapeByMeshOp::dlg ( ) const
LightApp_Dialog*- pointer to dialog of this operation
References myDlg.
◆ extractIds() [1/2]
void SMESHGUI_SelectionOp::extractIds ( const QStringList &  ids,
IdList &  list
References SMESHGUI_SelectionOp::extractIds(), and SMESHGUI_SelectionOp::idChar().
◆ extractIds() [2/2]
IdList &  list,
const QChar  idchar
◆ GetMesh()
SMESH::SMESH_Mesh_ptr SMESHGUI_ShapeByMeshOp::GetMesh ( )
References myMesh.
◆ GetShape()
GEOM::GEOM_Object_ptr SMESHGUI_ShapeByMeshOp::GetShape ( )
◆ getSMESHGUI()
◆ highlight()
void SMESHGUI_SelectionOp::highlight ( const Handle(SALOME_InteractiveObject)&  obj,
const bool  highlight,
const bool  immediately = true
◆ idChar()
QChar SMESHGUI_SelectionOp::idChar ( ) const
Referenced by SMESHGUI_SelectionOp::extractIds(), SMESHGUI_SelectionOp::selected(), and SMESHGUI_SelectionOp::typeById().
◆ Init()
void SMESHGUI_ShapeByMeshOp::Init ( )
◆ initDialog()
void SMESHGUI_SelectionOp::initDialog ( )
◆ isApplyAndClose()
◆ isReadyToStart()
◆ isValid()
bool SMESHGUI_Operation::isValid ( SUIT_Operation *  theOtherOp) const
theOtherOp- other operation
Returns TRUE if the given operator is valid for this one, FALSE otherwise
Virtual method redefined from base class verifies whether given operator is valid for this one (i.e. can be started "above" this operator). In current implementation method returns false if theOtherOp operation is not intended for deleting objects or mesh elements.
Reimplemented in SMESHGUI_MeshOp, and SMESHGUI_BaseComputeOp.
Referenced by SMESHGUI_MeshOp::isValid().
◆ mesh()
◆ onActivateObject
◆ onApply
bool SMESHGUI_ShapeByMeshOp::onApply ( )
protectedvirtualslot
◆ onCancel
protectedvirtualslotinherited
◆ onDeactivateObject
void SMESHGUI_SelectionOp::onDeactivateObject ( int  )
References SMESHGUI_SelectionOp::removeCustomFilters().
Referenced by SMESHGUI_SelectionOp::startOperation().
◆ onElemIdChanged
◆ onHelp
protectedslotinherited
◆ onOk
◆ onSelectionChanged
void SMESHGUI_SelectionOp::onSelectionChanged ( int  )
In successors it may be used for more advanced selection checking. This slot is connected to signal when the selection changed in some object selection widget
◆ onSelectionDone
void SMESHGUI_ShapeByMeshOp::onSelectionDone ( )
privateslot
◆ onTextChanged
void SMESHGUI_SelectionOp::onTextChanged ( int  ,
const QStringList &  list
In order to run default mechanism, you must set for some object selection widget the "name indication" to "ListOfNames", "read only" state to false and connect the dialog's signal "objectChanged" to this slot Warning: this mechanism can process only integer ids, NOT MESH OR GROUP NAMES!!!
References SMESHGUI_SelectionOp::actor(), SMESHGUI_SelectionOp::extractIds(), SMDS_Mesh::FindElement(), SMDS_Mesh::FindNode(), SMESH_Actor::GetObject(), SMESHGUI_SelectionOp::highlight(), SMESHGUI_SelectionOp::selected(), SMESHGUI_SelectionOp::selectionMode(), and SMESHGUI_SelectionOp::selector().
Referenced by SMESHGUI_Add0DElemsOnAllNodesOp::onTextChanged().
◆ onTypeChanged
void SMESHGUI_ShapeByMeshOp::onTypeChanged ( int  )
privateslot
◆ removeCustomFilters()
◆ selected()
◆ selectedIds()
void SMESHGUI_SelectionOp::selectedIds ( const int  id,
IdList &  list
References SMESHGUI_SelectionOp::extractIds().
◆ selectionDone()
◆ selectionMode()
◆ selector()
◆ setDialogActive()
References MESHCUT::d.
◆ setElementID()
void SMESHGUI_ShapeByMeshOp::setElementID ( const QString &  theText)
◆ setIsApplyAndClose()
◆ SetMesh()
◆ setSelectionMode()
◆ startOperation()
void SMESHGUI_ShapeByMeshOp::startOperation ( )
Reimplemented from SMESHGUI_SelectionOp.
References myDlg, myIsManualIdEnter, onSelectionDone(), SMESHGUI_Dialog::show(), and SMESHGUI_SelectionOp::startOperation().
◆ typeById()
int SMESHGUI_SelectionOp::typeById ( const QString &  str,
const EntityType  objtype
◆ viewWindow()
◆ myDefSelectionMode
Selection_Mode SMESHGUI_SelectionOp::myDefSelectionMode
privateinherited
◆ myDlg
◆ myFilters
Filters SMESHGUI_SelectionOp::myFilters
privateinherited
◆ myGeomObj
GEOM::GEOM_Object_var SMESHGUI_ShapeByMeshOp::myGeomObj
Referenced by commitOperation(), GetShape(), and SetMesh().
◆ myHasSolids
bool SMESHGUI_ShapeByMeshOp::myHasSolids
Referenced by activateSelection(), and SetMesh().
◆ myHelpFileName
◆ myIsApplyAndClose
◆ myIsManualIdEnter
bool SMESHGUI_ShapeByMeshOp::myIsManualIdEnter
◆ myIsMultipleAllowed
bool SMESHGUI_ShapeByMeshOp::myIsMultipleAllowed
◆ myMesh
SMESH::SMESH_Mesh_var SMESHGUI_ShapeByMeshOp::myMesh
◆ myOldSelectionMode
Selection_Mode SMESHGUI_SelectionOp::myOldSelectionMode
privateinherited
