SMESHGUI_Selection Class Reference
#include <SMESHGUI_Selection.h>
Inheritance diagram for SMESHGUI_Selection:
 SMESHGUI_Selection ()
virtual ~SMESHGUI_Selection ()
virtual void init (const QString &, LightApp_SelectionMgr *)
virtual QVariant parameter (const int, const QString &) const
virtual QVariant parameter (const QString &) const
virtual bool processOwner (const LightApp_DataOwner *)
virtual bool isAutoColor (int) const
virtual int numberOfNodes (int) const
virtual int dim (int) const
 return dimension of elements of the selected object More...
virtual bool isComputable (int) const
virtual bool hasAlgo (int) const
virtual bool hasErrors (int) const
virtual bool isPreComputable (int) const
virtual bool hasGeomReference (int) const
virtual bool isEditableHyp (int) const
virtual bool isVisible (int) const
virtual bool canBreakLink (int) const
virtual bool isQuadratic (int) const
virtual QString quadratic2DMode (int) const
virtual bool isDistributionVisible (int) const
virtual bool isScalarBarVisible (int) const
virtual bool hasChildren (int) const
virtual int nbChildren (int) const
virtual bool isContainer (int) const
virtual QList< QVariant > elemTypes (int, bool) const
virtual QList< QVariant > labeledTypes (int) const
virtual QString displayMode (int) const
virtual QString shrinkMode (int) const
virtual QList< QVariant > entityMode (int) const
virtual QString controlMode (int) const
virtual QString controlMode () const
virtual bool isNumFunctor (int) const
virtual QString facesOrientationMode (int) const
virtual QString groupType (int) const
SMESH_Actor * getActor (int) const
bool isImported (const int) const
static int type (const QString &)
static QString typeName (const int)
static int guiState ()
QStringList myTypes
QStringList myControls
QList< SMESH_Actor * > myActors
◆ SMESHGUI_Selection()
SMESHGUI_Selection::SMESHGUI_Selection ( )
◆ ~SMESHGUI_Selection()
SMESHGUI_Selection::~SMESHGUI_Selection ( )
◆ canBreakLink()
bool SMESHGUI_Selection::canBreakLink ( int  ind) const
References SMESH::_PTR().
Referenced by parameter().
◆ controlMode() [1/2]
QString SMESHGUI_Selection::controlMode ( ) const
References myControls.
Referenced by init(), and parameter().
◆ controlMode() [2/2]
◆ dim()
int SMESHGUI_Selection::dim ( int  ind) const
int- 0 for 0D elements, -1 for an empty object (the rest as usual)
References SMESH::_PTR(), SMESH::BALL, dim(), SMESH::EDGE, SMESH::ELEM0D, SMESH::FACE, myTypes, SMESH::SObjectToObject(), and SMESH::VOLUME.
Referenced by dim(), isPreComputable(), and parameter().
◆ displayMode()
QString SMESHGUI_Selection::displayMode ( int  ind) const
◆ elemTypes()
◆ entityMode()
QList< QVariant > SMESHGUI_Selection::entityMode ( int  ind) const
◆ facesOrientationMode()
QString SMESHGUI_Selection::facesOrientationMode ( int  ind) const
References getActor(), and SMESH_Actor::GetFacesOriented().
◆ getActor()
◆ groupType()
QString SMESHGUI_Selection::groupType ( int  ind) const
◆ guiState()
int SMESHGUI_Selection::guiState ( )
References SMESHGUI::GetSMESHGUI(), and SMESHGUI::GetState().
◆ hasAlgo()
bool SMESHGUI_Selection::hasAlgo ( int  ind) const
◆ hasChildren()
bool SMESHGUI_Selection::hasChildren ( int  ind) const
◆ hasErrors()
bool SMESHGUI_Selection::hasErrors ( int  ind) const
◆ hasGeomReference()
bool SMESHGUI_Selection::hasGeomReference ( int  ind) const
◆ init()
void SMESHGUI_Selection::init ( const QString &  client,
LightApp_SelectionMgr *  mgr
◆ isAutoColor()
bool SMESHGUI_Selection::isAutoColor ( int  ind) const
References SMESH::_PTR(), myTypes, and SMESH::SObjectToObject().
◆ isComputable()
bool SMESHGUI_Selection::isComputable ( int  ind) const
References SMESH::_PTR(), and myTypes.
◆ isContainer()
bool SMESHGUI_Selection::isContainer ( int  ind) const
References myTypes.
◆ isDistributionVisible()
bool SMESHGUI_Selection::isDistributionVisible ( int  ind) const
◆ isEditableHyp()
bool SMESHGUI_Selection::isEditableHyp ( int  ind) const
◆ isImported()
bool SMESHGUI_Selection::isImported ( const int  ind) const
References SMESH::_PTR(), and SMESH::SObjectToObject().
◆ isNumFunctor()
◆ isPreComputable()
bool SMESHGUI_Selection::isPreComputable ( int  ind) const
◆ isQuadratic()
bool SMESHGUI_Selection::isQuadratic ( int  ind) const
◆ isScalarBarVisible()
bool SMESHGUI_Selection::isScalarBarVisible ( int  ind) const
References getActor(), and SMESH_Actor::GetScalarBarActor().
◆ isVisible()
bool SMESHGUI_Selection::isVisible ( int  ind) const
◆ labeledTypes()
QList< QVariant > SMESHGUI_Selection::labeledTypes ( int  ind) const
◆ nbChildren()
int SMESHGUI_Selection::nbChildren ( int  ind) const
◆ numberOfNodes()
int SMESHGUI_Selection::numberOfNodes ( int  ind) const
◆ parameter() [1/2]
◆ parameter() [2/2]
QVariant SMESHGUI_Selection::parameter ( const QString &  p) const
References controlMode().
◆ processOwner()
bool SMESHGUI_Selection::processOwner ( const LightApp_DataOwner *  ow)
◆ quadratic2DMode()
QString SMESHGUI_Selection::quadratic2DMode ( int  ind) const
◆ shrinkMode()
QString SMESHGUI_Selection::shrinkMode ( int  ind) const
References getActor().
◆ type()
◆ typeName()
◆ myActors
QList<SMESH_Actor*> SMESHGUI_Selection::myActors
Referenced by getActor(), and processOwner().
◆ myControls
QStringList SMESHGUI_Selection::myControls
Referenced by controlMode(), and init().
◆ myTypes
