SMESHGUI_SelectionOp Class Reference
#include <SMESHGUI_SelectionOp.h>
Inheritance diagram for SMESHGUI_SelectionOp:
typedef QList< int > IdList
 SMESHGUI_SelectionOp (const Selection_Mode=ActorSelection)
 List of node or element ids. More...
virtual ~SMESHGUI_SelectionOp ()
static void extractIds (const QStringList &, IdList &, const QChar)
Protected Types
enum  EntityType { Object , MeshNode , MeshElement }
Protected Slots
virtual void onActivateObject (int)
 Installs filter corresponding to certain object selection widget. More...
virtual void onDeactivateObject (int)
 Removes filter corresponding to certain object selection widget. More...
virtual void onSelectionChanged (int)
 Empty default implementation. More...
virtual void onTextChanged (int, const QStringList &)
 Default implementation allowing user to edit selected ids "by hands". More...
virtual void onOk ()
virtual bool onApply ()
virtual void onCancel ()
void onHelp ()
 This enumeration is used in typeById method to distinguish objects, mesh nodes and mesh elements, because node end element ids may overlap. More...
virtual void selectionDone ()
virtual void initDialog ()
virtual SUIT_SelectionFilter * createFilter (const int) const
 Creates filter being used when certain object selection widget is active If no filter must be used, then function must return 0 if id is negative, then function must return filter for common using independently of active widget. More...
void removeCustomFilters ()
 Remove only filters set by this operation (they are in map myFilters ) More...
Selection_Mode selectionMode () const
 Return what selection mode is set in VTK viewer. More...
void setSelectionMode (const Selection_Mode)
 Set selection mode in VTK viewer. More...
void highlight (const Handle(SALOME_InteractiveObject)&, const bool, const bool=true)
 Highlight object in VTK viewer. More...
void addOrRemoveIndex (const Handle(SALOME_InteractiveObject)&, const SVTK_TVtkIDsMap &, const bool isModeShift)
 Select some nodes or elements in VTK. More...
SVTK_ViewWindow * viewWindow () const
SVTK_Selector * selector () const
virtual void selected (QStringList &, SMESHGUI_Dialog::TypesList &, QStringList &) const
 Get names, types and ids of selected objects. More...
virtual int typeById (const QString &, const EntityType) const
 Find type by id. More...
virtual QChar idChar () const
 Char using to divide <entry> and <id> in string id representation. By default, '#'. More...
void selectedIds (const int, IdList &) const
 Try to find in certain object selection widget selected node or element ids and return it. More...
void extractIds (const QStringList &, IdList &) const
 Find in QStringList correct node or element ids representation and append integer(id) to IdList. More...
SMESH::SMESH_Mesh_var mesh () const
 Return selected mesh if selection mode isn't ActorSelection and only one object is selected. More...
SMESH_Actor * actor () const
 Return actor according to selected mesh if selection mode isn't ActorSelection. More...
virtual bool isValid (SUIT_Operation *) const
QString myHelpFileName
bool myIsApplyAndClose
Private Types
typedef QMap< int, SUIT_SelectionFilter * > Filters
Filters myFilters
Selection_Mode myDefSelectionMode
Selection_Mode myOldSelectionMode
◆ Filters
◆ IdList
typedef QList<int> SMESHGUI_SelectionOp::IdList
◆ EntityType
Object
MeshNode
MeshElement
◆ SMESHGUI_SelectionOp()
SMESHGUI_SelectionOp::SMESHGUI_SelectionOp ( const Selection_Mode  mode = ActorSelection)
◆ ~SMESHGUI_SelectionOp()
SMESHGUI_SelectionOp::~SMESHGUI_SelectionOp ( )
References removeCustomFilters().
◆ abortOperation()
void SMESHGUI_SelectionOp::abortOperation ( )
◆ actor()
SMESH_Actor * SMESHGUI_SelectionOp::actor ( ) const
References SMESH::FindActorByObject(), and mesh().
Referenced by SMESHGUI_Make2DFrom3DOp::compute2DMesh(), SMESHGUI_MakeFull2DFrom3DOp::compute2DMesh(), SMESHGUI_ShapeByMeshOp::onElemIdChanged(), and onTextChanged().
◆ addOrRemoveIndex()
void SMESHGUI_SelectionOp::addOrRemoveIndex ( const Handle(SALOME_InteractiveObject)&  obj,
const SVTK_TVtkIDsMap &  indices,
References selector().
Referenced by SMESHGUI_FindElemByPointOp::onElemSelected(), and SMESHGUI_ReorientFacesOp::onTextChange().
◆ commitOperation()
void SMESHGUI_SelectionOp::commitOperation ( )
◆ createFilter()
SUIT_SelectionFilter * SMESHGUI_SelectionOp::createFilter ( const int  ) const
Reimplemented in SMESHGUI_Add0DElemsOnAllNodesOp, SMESHGUI_ConvToQuadOp, SMESHGUI_CreateDualMeshOp, SMESHGUI_GroupOnShapeOp, SMESHGUI_Make2DFrom3DOp, SMESHGUI_MakeFull2DFrom3DOp, SMESHGUI_MeshOp, SMESHGUI_ReorientFacesOp, and SMESHGUI_SplitBiQuadOp.
Referenced by onActivateObject().
◆ extractIds() [1/2]
void SMESHGUI_SelectionOp::extractIds ( const QStringList &  ids,
IdList &  list
References extractIds(), and idChar().
◆ extractIds() [2/2]
IdList &  list,
const QChar  idchar
◆ getSMESHGUI()
◆ highlight()
void SMESHGUI_SelectionOp::highlight ( const Handle(SALOME_InteractiveObject)&  obj,
const bool  highlight,
const bool  immediately = true
References highlight(), and viewWindow().
Referenced by highlight(), SMESHGUI_ReorientFacesOp::onTextChange(), and onTextChanged().
◆ idChar()
QChar SMESHGUI_SelectionOp::idChar ( ) const
Referenced by extractIds(), selected(), and typeById().
◆ initDialog()
void SMESHGUI_SelectionOp::initDialog ( )
◆ isApplyAndClose()
◆ isReadyToStart()
◆ isValid()
bool SMESHGUI_Operation::isValid ( SUIT_Operation *  theOtherOp) const
theOtherOp- other operation
Returns TRUE if the given operator is valid for this one, FALSE otherwise
Virtual method redefined from base class verifies whether given operator is valid for this one (i.e. can be started "above" this operator). In current implementation method returns false if theOtherOp operation is not intended for deleting objects or mesh elements.
Reimplemented in SMESHGUI_MeshOp, and SMESHGUI_BaseComputeOp.
Referenced by SMESHGUI_MeshOp::isValid().
◆ mesh()
◆ onActivateObject
void SMESHGUI_SelectionOp::onActivateObject ( int  id)
protectedvirtualslot
◆ onApply
bool SMESHGUI_Operation::onApply ( )
protectedvirtualslotinherited
◆ onCancel
◆ onDeactivateObject
void SMESHGUI_SelectionOp::onDeactivateObject ( int  )
Referenced by startOperation().
◆ onHelp
protectedslotinherited
◆ onOk
◆ onSelectionChanged
void SMESHGUI_SelectionOp::onSelectionChanged ( int  )
In successors it may be used for more advanced selection checking. This slot is connected to signal when the selection changed in some object selection widget
◆ onTextChanged
void SMESHGUI_SelectionOp::onTextChanged ( int  ,
const QStringList &  list
In order to run default mechanism, you must set for some object selection widget the "name indication" to "ListOfNames", "read only" state to false and connect the dialog's signal "objectChanged" to this slot Warning: this mechanism can process only integer ids, NOT MESH OR GROUP NAMES!!!
References actor(), extractIds(), SMDS_Mesh::FindElement(), SMDS_Mesh::FindNode(), SMESH_Actor::GetObject(), highlight(), selected(), selectionMode(), and selector().
Referenced by SMESHGUI_Add0DElemsOnAllNodesOp::onTextChanged().
◆ removeCustomFilters()
void SMESHGUI_SelectionOp::removeCustomFilters ( )
◆ selected()
void SMESHGUI_SelectionOp::selected ( QStringList &  ,
SMESHGUI_Dialog::TypesList &  ,
QStringList &
◆ selectedIds()
void SMESHGUI_SelectionOp::selectedIds ( const int  id,
IdList &  list
References extractIds().
◆ selectionDone()
◆ selectionMode()
Selection_Mode SMESHGUI_SelectionOp::selectionMode ( ) const
◆ selector()
◆ setDialogActive()
References MESHCUT::d.
◆ setIsApplyAndClose()
◆ setSelectionMode()
◆ startOperation()
void SMESHGUI_SelectionOp::startOperation ( )
Reimplemented in SMESHGUI_Add0DElemsOnAllNodesOp, SMESHGUI_ConvToQuadOp, SMESHGUI_CreateDualMeshOp, SMESHGUI_FindElemByPointOp, SMESHGUI_GroupOnShapeOp, SMESHGUI_Make2DFrom3DOp, SMESHGUI_MakeFull2DFrom3DOp, SMESHGUI_MeshOp, SMESHGUI_RemoveNodeReconnectionOp, SMESHGUI_ReorientFacesOp, SMESHGUI_ShapeByMeshOp, SMESHGUI_SplitBiQuadOp, SMESHGUI_AddNodeOnFaceOp, SMESHGUI_AddNodeOnSegmentOp, SMESHGUI_InteractiveOp, and SMESHGUI_MakeNodeAtPointOp.
References myDefSelectionMode, myOldSelectionMode, onActivateObject(), onDeactivateObject(), onSelectionChanged(), selectionMode(), setSelectionMode(), and SMESHGUI_Operation::startOperation().
Referenced by SMESHGUI_Add0DElemsOnAllNodesOp::startOperation(), SMESHGUI_ConvToQuadOp::startOperation(), SMESHGUI_CreateDualMeshOp::startOperation(), SMESHGUI_FindElemByPointOp::startOperation(), SMESHGUI_GroupOnShapeOp::startOperation(), SMESHGUI_Make2DFrom3DOp::startOperation(), SMESHGUI_MakeFull2DFrom3DOp::startOperation(), SMESHGUI_MeshOp::startOperation(), SMESHGUI_RemoveNodeReconnectionOp::startOperation(), SMESHGUI_ReorientFacesOp::startOperation(), SMESHGUI_ShapeByMeshOp::startOperation(), SMESHGUI_SplitBiQuadOp::startOperation(), SMESHGUI_AddNodeOnFaceOp::startOperation(), SMESHGUI_AddNodeOnSegmentOp::startOperation(), and SMESHGUI_MakeNodeAtPointOp::startOperation().
◆ typeById()
int SMESHGUI_SelectionOp::typeById ( const QString &  str,
const EntityType  objtype
◆ viewWindow()
◆ myDefSelectionMode
Selection_Mode SMESHGUI_SelectionOp::myDefSelectionMode
◆ myFilters
Filters SMESHGUI_SelectionOp::myFilters
◆ myHelpFileName
◆ myIsApplyAndClose
◆ myOldSelectionMode
Selection_Mode SMESHGUI_SelectionOp::myOldSelectionMode
