SMESHGUI_BaseComputeOp Class Reference
Base operation to compute a mesh and show computation errors. More...
#include <SMESHGUI_ComputeDlg.h>
Inheritance diagram for SMESHGUI_BaseComputeOp:
 SMESHGUI_BaseComputeOp ()
virtual ~SMESHGUI_BaseComputeOp ()
SMESH::SMESH_Mesh_ptr getMesh ()
 Return a selected mesh. More...
 Gets dialog of this operation. More...
Protected Slots
virtual bool onApply ()
 returns from compute mesh result dialog More...
void onPreviewShape ()
 update preview More...
void onPublishShape ()
 publish selected sub-shape More...
void onShowBadMesh ()
 show mesh elements preventing computation of a submesh of current row More...
void onGroupOfBadMesh ()
 create groups of bad mesh elements preventing computation of a submesh of current row More...
void currentCellChanged ()
 SLOT called when a selected cell in table() changed. More...
virtual void onOk ()
virtual void onCancel ()
void onHelp ()
 Start operation \purpose Init dialog fields, connect signals and slots, show dialog. More...
virtual void stopOperation ()
 Stops operation. More...
SMESHGUI_ComputeDlg * computeDlg () const
 Gets dialog of compute operation. More...
void computeMesh ()
 computeMesh() More...
void showComputeResult (const bool, const bool, SMESH::compute_error_array_var &, const bool, const QString &)
SMESHGUI_ComputeDlg * evaluateDlg () const
 Gets dialog of evaluate operation. More...
void evaluateMesh ()
 evaluateMesh() More...
void showEvaluateResult (const SMESH::smIdType_array &theRes, const bool, const bool, SMESH::compute_error_array_var &, const bool, const QString &)
virtual bool isValid (SUIT_Operation *theOp) const
 check the same operations on the same mesh More...
void logMeshSize ()
 Handle (SALOME_InteractiveObject) myIObject
virtual void initDialog ()
SMESH::SMESH_Mesh_var myMesh
GEOM::GEOM_Object_var myMainShape
GEOM::GEOM_Object_var myCurShape
SMESH::TShapeDisplayer * myTShapeDisplayer
SMESHGUI_MeshEditPreview * myBadMeshDisplayer
QString myHelpFileName
bool myIsApplyAndClose
QTableWidget * table ()
 Return a table. More...
QPointer< SMESHGUI_ComputeDlg > myCompDlg
◆ SMESHGUI_BaseComputeOp()
SMESHGUI_BaseComputeOp::SMESHGUI_BaseComputeOp ( )
◆ ~SMESHGUI_BaseComputeOp()
SMESHGUI_BaseComputeOp::~SMESHGUI_BaseComputeOp ( )
References myBadMeshDisplayer, myCompDlg, and myTShapeDisplayer.
◆ computeDlg()
◆ computeMesh()
◆ currentCellChanged
◆ dlg()
LightApp_Dialog * SMESHGUI_BaseComputeOp::dlg ( ) const
LightApp_Dialog*- pointer to dialog of this operation
Reimplemented in SMESHGUI_ComputeOp, SMESHGUI_PrecomputeOp, and SMESHGUI_EvaluateOp.
References myCompDlg.
◆ evaluateDlg()
SMESHGUI_ComputeDlg * SMESHGUI_BaseComputeOp::evaluateDlg ( ) const
SMESHGUI_ComputeDlg*- pointer to dialog of this operation
References currentCellChanged(), myCompDlg, onPreviewShape(), onPublishShape(), onShowBadMesh(), and table().
Referenced by SMESHGUI_EvaluateOp::dlg(), showEvaluateResult(), and SMESHGUI_EvaluateOp::startOperation().
◆ evaluateMesh()
◆ getMesh()
SMESH::SMESH_Mesh_ptr SMESHGUI_BaseComputeOp::getMesh ( )
References SMESH::GetMeshByIO(), Handle(), and myMesh.
Referenced by isValid().
◆ getSMESHGUI()
◆ Handle()
SMESHGUI_BaseComputeOp::Handle ( SALOME_InteractiveObject  )
Referenced by getMesh().
◆ initDialog()
void SMESHGUI_Operation::initDialog ( )
Reimplemented in SMESHGUI_PrecomputeOp, SMESHGUI_MeshOrderOp, and SMESHGUI_SelectionOp.
Referenced by SMESHGUI_Operation::startOperation().
◆ isApplyAndClose()
◆ isReadyToStart()
◆ isValid()
bool SMESHGUI_BaseComputeOp::isValid ( SUIT_Operation *  theOp) const
References getMesh(), and myMesh.
◆ logMeshSize()
◆ onApply
bool SMESHGUI_BaseComputeOp::onApply ( )
protectedvirtualslot
Referenced by SMESHGUI_PrecomputeOp::startOperation().
◆ onCancel
protectedvirtualslotinherited
◆ onGroupOfBadMesh
void SMESHGUI_BaseComputeOp::onGroupOfBadMesh ( )
protectedslot
References SMESH::_PTR(), COL_BAD_MESH, COL_SHAPE, COL_SHAPEID, SMESH::getSelectedRows(), SMESHGUI::GetSMESHGen(), SMESHGUI_Operation::getSMESHGUI(), myMesh, and table().
Referenced by computeDlg().
◆ onHelp
protectedslotinherited
◆ onOk
◆ onPreviewShape
void SMESHGUI_BaseComputeOp::onPreviewShape ( )
protectedslot
◆ onPublishShape
◆ onShowBadMesh
◆ setDialogActive()
References MESHCUT::d.
◆ setIsApplyAndClose()
◆ showComputeResult()
◆ showEvaluateResult()
◆ startOperation()
◆ stopOperation()
void SMESHGUI_BaseComputeOp::stopOperation ( )
◆ table()
QTableWidget * SMESHGUI_BaseComputeOp::table ( )
◆ myBadMeshDisplayer
SMESHGUI_MeshEditPreview* SMESHGUI_BaseComputeOp::myBadMeshDisplayer
◆ myCompDlg
◆ myCurShape
GEOM::GEOM_Object_var SMESHGUI_BaseComputeOp::myCurShape
Referenced by computeMesh(), and startOperation().
◆ myHelpFileName
◆ myIsApplyAndClose
◆ myMainShape
◆ myMesh
◆ myTShapeDisplayer
