SMESHGUI_MakeNodeAtPointOp Class Reference
Operation to make a mesh pass through a point. More...
#include <SMESHGUI_MakeNodeAtPointDlg.h>
Inheritance diagram for SMESHGUI_MakeNodeAtPointOp:
typedef QList< int > IdList
 SMESHGUI_MakeNodeAtPointOp (int defaultConstructor=0)
virtual ~SMESHGUI_MakeNodeAtPointOp ()
 Gets dialog of this operation. More...
virtual void deactivateCurrentViewOperation ()
 Deactivate current operation in active VTK viewer. More...
static void extractIds (const QStringList &, IdList &, const QChar)
Protected Types
enum  EntityType { Object , MeshNode , MeshElement }
Protected Slots
virtual bool onApply ()
 perform it's intention action: move or create a node More...
virtual void onActivateObject (int)
 Installs filter corresponding to certain object selection widget. More...
virtual void onDeactivateObject (int)
 Removes filter corresponding to certain object selection widget. More...
virtual void onSelectionChanged (int)
 Empty default implementation. More...
virtual void onTextChanged (int, const QStringList &)
 Default implementation allowing user to edit selected ids "by hands". More...
virtual void onOk ()
virtual void onCancel ()
void onHelp ()
virtual void startOperation () override
 This enumeration is used in typeById method to distinguish objects, mesh nodes and mesh elements, because node end element ids may overlap. More...
virtual void stopOperation () override
 Stops operation. More...
virtual void activateSelection () override
 Activate Node selection. More...
bool isValid (QString &)
 Check selected node id validity. More...
virtual void processStyleEvents (unsigned long event, void *calldata) override
 Process interactor style events () Virtual method. More...
virtual void processInteractorEvents (unsigned long event, void *calldata) override
 Process Generic Render Window Interactor events. More...
virtual void addObserver ()
virtual void removeObserver ()
void extractIds (const QStringList &, IdList &) const
 Find in QStringList correct node or element ids representation and append integer(id) to IdList. More...
virtual void selectionDone ()
virtual void initDialog ()
virtual SUIT_SelectionFilter * createFilter (const int) const
 Creates filter being used when certain object selection widget is active If no filter must be used, then function must return 0 if id is negative, then function must return filter for common using independently of active widget. More...
void removeCustomFilters ()
 Remove only filters set by this operation (they are in map myFilters ) More...
Selection_Mode selectionMode () const
 Return what selection mode is set in VTK viewer. More...
void setSelectionMode (const Selection_Mode)
 Set selection mode in VTK viewer. More...
void highlight (const Handle(SALOME_InteractiveObject)&, const bool, const bool=true)
 Highlight object in VTK viewer. More...
void addOrRemoveIndex (const Handle(SALOME_InteractiveObject)&, const SVTK_TVtkIDsMap &, const bool isModeShift)
 Select some nodes or elements in VTK. More...
SVTK_ViewWindow * viewWindow () const
SVTK_Selector * selector () const
virtual void selected (QStringList &, SMESHGUI_Dialog::TypesList &, QStringList &) const
 Get names, types and ids of selected objects. More...
virtual int typeById (const QString &, const EntityType) const
 Find type by id. More...
virtual QChar idChar () const
 Char using to divide <entry> and <id> in string id representation. By default, '#'. More...
void selectedIds (const int, IdList &) const
 Try to find in certain object selection widget selected node or element ids and return it. More...
SMESH::SMESH_Mesh_var mesh () const
 Return selected mesh if selection mode isn't ActorSelection and only one object is selected. More...
SMESH_Actor * actor () const
 Return actor according to selected mesh if selection mode isn't ActorSelection. More...
virtual bool isValid (SUIT_Operation *) const
static void ProcessStyleEvents (vtkObject *object, unsigned long event, void *clientdata, void *calldata)
 Process interactor style events Static method. More...
static void ProcessInteractorEvents (vtkObject *object, unsigned long event, void *clientdata, void *calldata)
vtkInteractorStyle * myInteractorStyle
SVTK_RenderWindowInteractor * myRWInteractor
double myInteractorStypePriority
double myInteractorPriority
vtkSmartPointer< vtkCallbackCommand > myStyleEventCallbackCommand
vtkSmartPointer< vtkCallbackCommand > myInteractorEventCallbackCommand
QString myHelpFileName
bool myIsApplyAndClose
Private Types
typedef QMap< int, SUIT_SelectionFilter * > Filters
Private Slots
void onSelectionDone ()
 SLOT called when selection changed. More...
void redisplayPreview ()
 update preview More...
void onTextChange (const QString &)
 SLOT called when the node id is manually changed. More...
void onUpdateDestination ()
 SLOT. More...
void onDestCoordChanged ()
 SLOT. More...
void onOpenView ()
 SLOT called when the viewer opened. More...
void onCloseView ()
 SLOT called when the viewer closed. More...
void constructorChanged ()
 SLOT called when the creation mode is changed. More...
int GetConstructorId ()
int myDefaultConstructor
SMESHGUI_MakeNodeAtPointDlg * myDlg
SUIT_SelectionFilter * myFilter
SMESHGUI * mySMESHGUI
SMESHGUI_MeshEditPreview * mySimulation
SMESH_Actor * myMeshActor
bool myNoPreview
bool myUpdateDestination
bool myDestCoordChanged
Filters myFilters
Selection_Mode myDefSelectionMode
Selection_Mode myOldSelectionMode
◆ Filters
typedef QMap<int, SUIT_SelectionFilter*> SMESHGUI_SelectionOp::Filters
privateinherited
◆ IdList
typedef QList<int> SMESHGUI_SelectionOp::IdList
◆ EntityType
enum SMESHGUI_SelectionOp::EntityType
Object
MeshNode
MeshElement
◆ SMESHGUI_MakeNodeAtPointOp()
◆ ~SMESHGUI_MakeNodeAtPointOp()
SMESHGUI_MakeNodeAtPointOp::~SMESHGUI_MakeNodeAtPointOp ( )
References myDlg, myFilter, and mySimulation.
◆ abortOperation()
void SMESHGUI_SelectionOp::abortOperation ( )
◆ activateSelection()
void SMESHGUI_MakeNodeAtPointOp::activateSelection ( )
overrideprotectedvirtual
◆ actor()
SMESH_Actor * SMESHGUI_SelectionOp::actor ( ) const
◆ addObserver()
◆ addOrRemoveIndex()
void SMESHGUI_SelectionOp::addOrRemoveIndex ( const Handle(SALOME_InteractiveObject)&  obj,
const SVTK_TVtkIDsMap &  indices,
◆ commitOperation()
◆ constructorChanged
void SMESHGUI_MakeNodeAtPointOp::constructorChanged ( )
privateslot
◆ createFilter()
SUIT_SelectionFilter * SMESHGUI_SelectionOp::createFilter ( const int  ) const
Reimplemented in SMESHGUI_Add0DElemsOnAllNodesOp, SMESHGUI_ConvToQuadOp, SMESHGUI_CreateDualMeshOp, SMESHGUI_GroupOnShapeOp, SMESHGUI_Make2DFrom3DOp, SMESHGUI_MakeFull2DFrom3DOp, SMESHGUI_MeshOp, SMESHGUI_ReorientFacesOp, and SMESHGUI_SplitBiQuadOp.
Referenced by SMESHGUI_SelectionOp::onActivateObject().
◆ deactivateCurrentViewOperation()
void SMESHGUI_InteractiveOp::deactivateCurrentViewOperation ( )
References SMESHGUI_Operation::getSMESHGUI(), and SMESH::GetViewWindow().
◆ dlg()
LightApp_Dialog * SMESHGUI_MakeNodeAtPointOp::dlg ( ) const
LightApp_Dialog*- pointer to dialog of this operation
References myDlg.
Referenced by onApply().
◆ extractIds() [1/2]
void SMESHGUI_SelectionOp::extractIds ( const QStringList &  ids,
IdList &  list
References SMESHGUI_SelectionOp::extractIds(), and SMESHGUI_SelectionOp::idChar().
◆ extractIds() [2/2]
IdList &  list,
const QChar  idchar
◆ GetConstructorId()
int SMESHGUI_MakeNodeAtPointOp::GetConstructorId ( )
◆ getSMESHGUI()
◆ highlight()
void SMESHGUI_SelectionOp::highlight ( const Handle(SALOME_InteractiveObject)&  obj,
const bool  highlight,
const bool  immediately = true
◆ idChar()
QChar SMESHGUI_SelectionOp::idChar ( ) const
Referenced by SMESHGUI_SelectionOp::extractIds(), SMESHGUI_SelectionOp::selected(), and SMESHGUI_SelectionOp::typeById().
◆ initDialog()
void SMESHGUI_SelectionOp::initDialog ( )
◆ isApplyAndClose()
◆ isReadyToStart()
◆ isValid() [1/2]
◆ isValid() [2/2]
bool SMESHGUI_Operation::isValid ( SUIT_Operation *  theOtherOp) const
theOtherOp- other operation
Returns TRUE if the given operator is valid for this one, FALSE otherwise
Virtual method redefined from base class verifies whether given operator is valid for this one (i.e. can be started "above" this operator). In current implementation method returns false if theOtherOp operation is not intended for deleting objects or mesh elements.
Reimplemented in SMESHGUI_MeshOp, and SMESHGUI_BaseComputeOp.
Referenced by SMESHGUI_MeshOp::isValid().
◆ mesh()
◆ onActivateObject
◆ onApply
◆ onCancel
protectedvirtualslotinherited
◆ onCloseView
void SMESHGUI_MakeNodeAtPointOp::onCloseView ( )
privateslot
References mySimulation.
Referenced by startOperation(), and stopOperation().
◆ onDeactivateObject
void SMESHGUI_SelectionOp::onDeactivateObject ( int  )
References SMESHGUI_SelectionOp::removeCustomFilters().
Referenced by SMESHGUI_SelectionOp::startOperation().
◆ onDestCoordChanged
void SMESHGUI_MakeNodeAtPointOp::onDestCoordChanged ( )
privateslot
SLOT.
Update preview upon Destination coordinates change
References myDestCoordChanged, and redisplayPreview().
Referenced by SMESHGUI_MakeNodeAtPointOp().
◆ onHelp
protectedslotinherited
◆ onOk
◆ onOpenView
void SMESHGUI_MakeNodeAtPointOp::onOpenView ( )
privateslot
◆ onSelectionChanged
void SMESHGUI_SelectionOp::onSelectionChanged ( int  )
In successors it may be used for more advanced selection checking. This slot is connected to signal when the selection changed in some object selection widget
◆ onSelectionDone
◆ onTextChange
void SMESHGUI_MakeNodeAtPointOp::onTextChange ( const QString &  theText)
privateslot
◆ onTextChanged
void SMESHGUI_SelectionOp::onTextChanged ( int  ,
const QStringList &  list
In order to run default mechanism, you must set for some object selection widget the "name indication" to "ListOfNames", "read only" state to false and connect the dialog's signal "objectChanged" to this slot Warning: this mechanism can process only integer ids, NOT MESH OR GROUP NAMES!!!
References SMESHGUI_SelectionOp::actor(), SMESHGUI_SelectionOp::extractIds(), SMDS_Mesh::FindElement(), SMDS_Mesh::FindNode(), SMESH_Actor::GetObject(), SMESHGUI_SelectionOp::highlight(), SMESHGUI_SelectionOp::selected(), SMESHGUI_SelectionOp::selectionMode(), and SMESHGUI_SelectionOp::selector().
Referenced by SMESHGUI_Add0DElemsOnAllNodesOp::onTextChanged().
◆ onUpdateDestination
void SMESHGUI_MakeNodeAtPointOp::onUpdateDestination ( )
privateslot
SLOT.
Update preview upon [Update destination] clicked
References myUpdateDestination, and redisplayPreview().
◆ processInteractorEvents()
void SMESHGUI_MakeNodeAtPointOp::processInteractorEvents ( unsigned long  theEvent,
void *  theCallData
Virtual method. Should be overridden in inherited classes.
Reimplemented from SMESHGUI_InteractiveOp.
References GetConstructorId(), SMESHGUI::GetSMESHGUI(), SMESH::GetViewWindow(), SMESHGUI_MakeNodeAtPointDlg::myDestBtn, myDlg, and SMESHGUI_InteractiveOp::myRWInteractor.
◆ ProcessInteractorEvents()
void SMESHGUI_InteractiveOp::ProcessInteractorEvents ( vtkObject *  object,
void *  clientdata,
void *  calldata
staticprotectedinherited
Static method. Used by vtkCallbackCommand->SetCallback method.
References SMESHGUI_InteractiveOp::processInteractorEvents().
Referenced by SMESHGUI_InteractiveOp::SMESHGUI_InteractiveOp().
◆ processStyleEvents()
void SMESHGUI_MakeNodeAtPointOp::processStyleEvents ( unsigned long  theEvent,
void *  theCallData
References SMESHGUI_MakeNodeAtPointDlg::myDestinationX, SMESHGUI_MakeNodeAtPointDlg::myDestinationY, SMESHGUI_MakeNodeAtPointDlg::myDestinationZ, myDlg, redisplayPreview(), and SMESHGUI_SpinBox::SetValue().
◆ ProcessStyleEvents()
void SMESHGUI_InteractiveOp::ProcessStyleEvents ( vtkObject *  object,
void *  clientdata,
void *  calldata
References SMESHGUI_InteractiveOp::processStyleEvents().
◆ redisplayPreview
◆ removeCustomFilters()
◆ removeObserver()
◆ selected()
◆ selectedIds()
void SMESHGUI_SelectionOp::selectedIds ( const int  id,
IdList &  list
References SMESHGUI_SelectionOp::extractIds().
◆ selectionDone()
◆ selectionMode()
◆ selector()
◆ setDialogActive()
References MESHCUT::d.
◆ setIsApplyAndClose()
◆ setSelectionMode()
◆ startOperation()
◆ stopOperation()
◆ typeById()
int SMESHGUI_SelectionOp::typeById ( const QString &  str,
const EntityType  objtype
◆ viewWindow()
◆ myDefaultConstructor
int SMESHGUI_MakeNodeAtPointOp::myDefaultConstructor
◆ myDefSelectionMode
Selection_Mode SMESHGUI_SelectionOp::myDefSelectionMode
privateinherited
◆ myDestCoordChanged
bool SMESHGUI_MakeNodeAtPointOp::myDestCoordChanged
◆ myDlg
◆ myFilter
◆ myFilters
Filters SMESHGUI_SelectionOp::myFilters
privateinherited
◆ myHelpFileName
◆ myInteractorEventCallbackCommand
vtkSmartPointer<vtkCallbackCommand> SMESHGUI_InteractiveOp::myInteractorEventCallbackCommand
◆ myInteractorPriority
double SMESHGUI_InteractiveOp::myInteractorPriority
◆ myInteractorStyle
◆ myInteractorStypePriority
double SMESHGUI_InteractiveOp::myInteractorStypePriority
◆ myIsApplyAndClose
◆ myMeshActor
SMESH_Actor* SMESHGUI_MakeNodeAtPointOp::myMeshActor
◆ myNoPreview
bool SMESHGUI_MakeNodeAtPointOp::myNoPreview
◆ myOldSelectionMode
Selection_Mode SMESHGUI_SelectionOp::myOldSelectionMode
privateinherited
◆ myRWInteractor
◆ mySimulation
◆ mySMESHGUI
SMESHGUI* SMESHGUI_MakeNodeAtPointOp::mySMESHGUI
◆ myStyleEventCallbackCommand
vtkSmartPointer<vtkCallbackCommand> SMESHGUI_InteractiveOp::myStyleEventCallbackCommand
◆ myUpdateDestination
bool SMESHGUI_MakeNodeAtPointOp::myUpdateDestination
