SMESHGUI_PrecomputeOp Class Reference
Operation to preview and compute a mesh and show computation errors. More...
#include <SMESHGUI_ComputeDlg.h>
Inheritance diagram for SMESHGUI_PrecomputeOp:
 SMESHGUI_PrecomputeOp ()
virtual ~SMESHGUI_PrecomputeOp ()
 Gets current dialog of this operation. More...
SMESH::SMESH_Mesh_ptr getMesh ()
 Return a selected mesh. More...
static void getAssignedAlgos (_PTR(SObject) theMesh, QMap< int, int > &theModeMap)
 returns map of assigned algorithms modes More...
Protected Slots
virtual void onCancel ()
 perform it's intention action: compute mesh More...
virtual bool onApply ()
 returns from compute mesh result dialog More...
void onPreviewShape ()
 update preview More...
void onPublishShape ()
 publish selected sub-shape More...
void onShowBadMesh ()
 show mesh elements preventing computation of a submesh of current row More...
void onGroupOfBadMesh ()
 create groups of bad mesh elements preventing computation of a submesh of current row More...
void currentCellChanged ()
 SLOT called when a selected cell in table() changed. More...
virtual void onOk ()
void onHelp ()
 perform it's intention action: prepare data More...
virtual void stopOperation ()
 Stops operation. More...
virtual void resumeOperation ()
 reinitialize dialog after operation become active again More...
virtual void initDialog ()
 perform it's intention action: reinitialise dialog More...
SMESHGUI_ComputeDlg * computeDlg () const
 Gets dialog of compute operation. More...
void computeMesh ()
 computeMesh() More...
void showComputeResult (const bool, const bool, SMESH::compute_error_array_var &, const bool, const QString &)
SMESHGUI_ComputeDlg * evaluateDlg () const
 Gets dialog of evaluate operation. More...
void evaluateMesh ()
 evaluateMesh() More...
void showEvaluateResult (const SMESH::smIdType_array &theRes, const bool, const bool, SMESH::compute_error_array_var &, const bool, const QString &)
virtual bool isValid (SUIT_Operation *theOp) const
 check the same operations on the same mesh More...
void logMeshSize ()
 Handle (SALOME_InteractiveObject) myIObject
SMESH::SMESH_Mesh_var myMesh
GEOM::GEOM_Object_var myMainShape
GEOM::GEOM_Object_var myCurShape
SMESH::TShapeDisplayer * myTShapeDisplayer
SMESHGUI_MeshEditPreview * myBadMeshDisplayer
QString myHelpFileName
bool myIsApplyAndClose
Private Types
typedef QList< int > TListOfInt
 fields for mesh order More...
typedef QList< TListOfInt > TListOfListOfInt
Private Slots
void onPreview ()
 perform it's intention action: preview mesh More...
void onCompute ()
QTableWidget * table ()
 Return a table. More...
QMap< int, int > myMapShapeId
 private fields More...
QPointer< LightApp_Dialog > myActiveDlg
QPointer< SMESHGUI_PrecomputeDlg > myDlg
SMESHGUI_MeshEditPreview * myPreviewDisplayer
TListOfListOfInt myPrevOrder
SMESHGUI_MeshOrderMgr * myOrderMgr
QPointer< SMESHGUI_ComputeDlg > myCompDlg
◆ TListOfInt
typedef QList<int> SMESHGUI_PrecomputeOp::TListOfInt
◆ TListOfListOfInt
◆ SMESHGUI_PrecomputeOp()
SMESHGUI_PrecomputeOp::SMESHGUI_PrecomputeOp ( )
◆ ~SMESHGUI_PrecomputeOp()
SMESHGUI_PrecomputeOp::~SMESHGUI_PrecomputeOp ( )
References myActiveDlg, myDlg, myOrderMgr, and myPreviewDisplayer.
◆ computeDlg()
◆ computeMesh()
◆ currentCellChanged
◆ dlg()
LightApp_Dialog * SMESHGUI_PrecomputeOp::dlg ( ) const
LightApp_Dialog*- pointer to dialog of this operation
Reimplemented from SMESHGUI_BaseComputeOp.
References myActiveDlg.
◆ evaluateDlg()
◆ evaluateMesh()
◆ getAssignedAlgos()
void SMESHGUI_PrecomputeOp::getAssignedAlgos ( _PTR(SObject)  theMesh,
QMap< int, int > &  theModeMap
◆ getMesh()
SMESH::SMESH_Mesh_ptr SMESHGUI_BaseComputeOp::getMesh ( )
◆ getSMESHGUI()
◆ Handle()
SMESHGUI_BaseComputeOp::Handle ( SALOME_InteractiveObject  )
◆ initDialog()
void SMESHGUI_PrecomputeOp::initDialog ( )
◆ isApplyAndClose()
◆ isReadyToStart()
◆ isValid()
bool SMESHGUI_BaseComputeOp::isValid ( SUIT_Operation *  theOp) const
References SMESHGUI_BaseComputeOp::getMesh(), and SMESHGUI_BaseComputeOp::myMesh.
◆ logMeshSize()
◆ onApply
bool SMESHGUI_BaseComputeOp::onApply ( )
protectedvirtualslotinherited
Referenced by startOperation().
◆ onCancel
void SMESHGUI_PrecomputeOp::onCancel ( )
◆ onCompute
◆ onGroupOfBadMesh
void SMESHGUI_BaseComputeOp::onGroupOfBadMesh ( )
protectedslotinherited
◆ onHelp
◆ onOk
◆ onPreview
◆ onPreviewShape
◆ onPublishShape
◆ onShowBadMesh
◆ resumeOperation()
void SMESHGUI_PrecomputeOp::resumeOperation ( )
References initDialog(), myActiveDlg, and myDlg.
◆ setDialogActive()
References MESHCUT::d.
◆ setIsApplyAndClose()
◆ showComputeResult()
◆ showEvaluateResult()
◆ startOperation()
◆ stopOperation()
void SMESHGUI_PrecomputeOp::stopOperation ( )
◆ table()
◆ myActiveDlg
QPointer<LightApp_Dialog> SMESHGUI_PrecomputeOp::myActiveDlg
◆ myBadMeshDisplayer
◆ myCompDlg
◆ myCurShape
GEOM::GEOM_Object_var SMESHGUI_BaseComputeOp::myCurShape
◆ myDlg
◆ myHelpFileName
◆ myIsApplyAndClose
◆ myMainShape
◆ myMapShapeId
QMap< int, int > SMESHGUI_PrecomputeOp::myMapShapeId
private fields
Referenced by onCancel(), onCompute(), onPreview(), and stopOperation().
◆ myMesh
◆ myOrderMgr
SMESHGUI_MeshOrderMgr* SMESHGUI_PrecomputeOp::myOrderMgr
◆ myPreviewDisplayer
SMESHGUI_MeshEditPreview* SMESHGUI_PrecomputeOp::myPreviewDisplayer
◆ myPrevOrder
TListOfListOfInt SMESHGUI_PrecomputeOp::myPrevOrder
Referenced by initDialog(), and onCancel().
◆ myTShapeDisplayer
