SMESHGUI_GenericHypothesisCreator Class Referenceabstract
Auxiliary class for creation of hypotheses. More...
#include <SMESHGUI_Hypotheses.h>
Inheritance diagram for SMESHGUI_GenericHypothesisCreator:
struct  StdParam
Signals
void finished (int)
 SMESHGUI_GenericHypothesisCreator (const QString &)
virtual ~SMESHGUI_GenericHypothesisCreator ()
void create (SMESH::SMESH_Hypothesis_ptr, const QString &, QWidget *, QObject *, const QString &)
void create (bool, const QString &, QWidget *, QObject *, const QString &)
void edit (SMESH::SMESH_Hypothesis_ptr, const QString &, QWidget *, QObject *, const QString &)
void setInitParamsHypothesis (SMESH::SMESH_Hypothesis_ptr)
virtual bool checkParams (QString &) const
virtual void onReject ()
virtual QString helpPage () const
QString hypType () const
QString hypName () const
bool isCreation () const
QString getShapeEntry () const
void setShapeEntry (const QString &theEntry)
QString getMainShapeEntry () const
void setMainShapeEntry (const QString &theEntry)
void setNoGeomMesh (const bool noGeom)
bool getNoGeomMesh () const
Protected Types
typedef QList< StdParam > ListOfStdParams
typedef QList< QWidget * > ListOfWidgets
Protected Slots
virtual void onValueChanged ()
SMESH::SMESH_Hypothesis_var hypothesis () const
SMESH::SMESH_Hypothesis_var initParamsHypothesis (const bool strict=false) const
 Return hypothesis containing initial parameters. More...
bool hasInitParamsHypothesis () const
const ListOfWidgets & widgets () const
ListOfWidgets & changeWidgets ()
QLabel * getLabel (int i) const
 Returns a QLabel of a specified parameter. More...
QtxDialog * dlg () const
QString getVariableName (const char *methodName) const
virtual QFrame * buildFrame ()=0
QFrame * buildStdFrame ()
virtual void retrieveParams () const =0
virtual QString storeParams () const =0
virtual bool stdParams (ListOfStdParams &) const
bool getStdParamFromDlg (ListOfStdParams &) const
virtual QStringList getVariablesFromDlg () const
virtual void attuneStdWidget (QWidget *, const int) const
virtual QWidget * getCustomWidget (const StdParam &, QWidget *, const int) const
virtual QWidget * getHelperWidget () const
 Returns a widget representing not a hypothesis parameter but some helper widget. More...
virtual bool getParamFromCustomWidget (StdParam &, QWidget *) const
virtual void valueChanged (QWidget *)
virtual QString caption () const
virtual QPixmap icon () const
virtual QString type () const
static QString stdParamValues (const ListOfStdParams &)
Private Slots
virtual void onDialogFinished (int)
void editHypothesis (SMESH::SMESH_Hypothesis_ptr, const QString &, QWidget *, QObject *obj, const QString &)
SMESH::SMESH_Hypothesis_var myHypo
SMESH::SMESH_Hypothesis_var myInitParamsHypo
bool myToDeleteInitParamsHypo
QString myHypName
QString myHypType
ListOfWidgets myParamWidgets
ListOfWidgets myParamLabels
bool myIsCreate
bool myNoGeomMesh
 true for a mesh not based on geometry More...
QtxDialog * myDlg
QString myShapeEntry
QString myMainShapeEntry
◆ ListOfStdParams
◆ ListOfWidgets
◆ SMESHGUI_GenericHypothesisCreator()
SMESHGUI_GenericHypothesisCreator::SMESHGUI_GenericHypothesisCreator ( const QString &  theHypType)
◆ ~SMESHGUI_GenericHypothesisCreator()
SMESHGUI_GenericHypothesisCreator::~SMESHGUI_GenericHypothesisCreator ( )
◆ attuneStdWidget()
void SMESHGUI_GenericHypothesisCreator::attuneStdWidget ( QWidget *  ,
const int
Reimplemented in StdMeshersGUI_StdHypothesisCreator.
Referenced by buildStdFrame().
◆ buildFrame()
virtual QFrame * SMESHGUI_GenericHypothesisCreator::buildFrame ( )
protectedpure virtual
◆ buildStdFrame()
◆ caption()
QString SMESHGUI_GenericHypothesisCreator::caption ( ) const
Referenced by editHypothesis().
◆ changeWidgets()
SMESHGUI_GenericHypothesisCreator::ListOfWidgets & SMESHGUI_GenericHypothesisCreator::changeWidgets ( )
References myParamWidgets.
Referenced by buildStdFrame(), and onDialogFinished().
◆ checkParams()
◆ create() [1/2]
void SMESHGUI_GenericHypothesisCreator::create ( bool  isAlgo,
const QString &  theHypName,
QWidget *  theParent,
QObject *  obj,
const QString &  slot
◆ create() [2/2]
void SMESHGUI_GenericHypothesisCreator::create ( SMESH::SMESH_Hypothesis_ptr  initParamsHyp,
QWidget *  parent,
QObject *  obj,
◆ dlg()
◆ edit()
void SMESHGUI_GenericHypothesisCreator::edit ( SMESH::SMESH_Hypothesis_ptr  theHypothesis,
QObject *  obj,
◆ editHypothesis()
void SMESHGUI_GenericHypothesisCreator::editHypothesis ( SMESH::SMESH_Hypothesis_ptr  h,
QObject *  obj,
◆ finished
void SMESHGUI_GenericHypothesisCreator::finished ( int  )
signal
Referenced by editHypothesis(), and onDialogFinished().
◆ getCustomWidget()
QWidget * SMESHGUI_GenericHypothesisCreator::getCustomWidget ( const StdParam &  ,
QWidget *  ,
const int
◆ getHelperWidget()
QWidget * SMESHGUI_GenericHypothesisCreator::getHelperWidget ( ) const
◆ getLabel()
QLabel * SMESHGUI_GenericHypothesisCreator::getLabel ( int  i) const
If isCreation(), the 1st label (supposed to be "Name") is not countered.
References isCreation(), and myParamLabels.
Referenced by StdMeshersGUI_StdHypothesisCreator::valueChanged().
◆ getMainShapeEntry()
◆ getNoGeomMesh()
bool SMESHGUI_GenericHypothesisCreator::getNoGeomMesh ( ) const
◆ getParamFromCustomWidget()
bool SMESHGUI_GenericHypothesisCreator::getParamFromCustomWidget ( StdParam &  ,
QWidget *
Referenced by getStdParamFromDlg().
◆ getShapeEntry()
◆ getStdParamFromDlg()
◆ getVariableName()
QString SMESHGUI_GenericHypothesisCreator::getVariableName ( const char *  methodName) const
◆ getVariablesFromDlg()
QStringList SMESHGUI_GenericHypothesisCreator::getVariablesFromDlg ( ) const
References widgets().
◆ hasInitParamsHypothesis()
bool SMESHGUI_GenericHypothesisCreator::hasInitParamsHypothesis ( ) const
References myInitParamsHypo.
◆ helpPage()
QString SMESHGUI_GenericHypothesisCreator::helpPage ( ) const
◆ hypName()
◆ hypothesis()
◆ hypType()
◆ icon()
QPixmap SMESHGUI_GenericHypothesisCreator::icon ( ) const
◆ initParamsHypothesis()
SMESH::SMESH_Hypothesis_var SMESHGUI_GenericHypothesisCreator::initParamsHypothesis ( const bool  strictly = false) const
◆ isCreation()
◆ onDialogFinished
◆ onReject()
void SMESHGUI_GenericHypothesisCreator::onReject ( )
◆ onValueChanged
void SMESHGUI_GenericHypothesisCreator::onValueChanged ( )
protectedvirtualslot
◆ retrieveParams()
virtual void SMESHGUI_GenericHypothesisCreator::retrieveParams ( ) const
◆ setInitParamsHypothesis()
void SMESHGUI_GenericHypothesisCreator::setInitParamsHypothesis ( SMESH::SMESH_Hypothesis_ptr  hyp)
◆ setMainShapeEntry()
void SMESHGUI_GenericHypothesisCreator::setMainShapeEntry ( const QString &  theEntry)
◆ setNoGeomMesh()
void SMESHGUI_GenericHypothesisCreator::setNoGeomMesh ( const bool  noGeom)
◆ setShapeEntry()
void SMESHGUI_GenericHypothesisCreator::setShapeEntry ( const QString &  theEntry)
◆ stdParams()
bool SMESHGUI_GenericHypothesisCreator::stdParams ( ListOfStdParams &  ) const
◆ stdParamValues()
QString SMESHGUI_GenericHypothesisCreator::stdParamValues ( const ListOfStdParams &  params)
staticprotected
◆ storeParams()
virtual QString SMESHGUI_GenericHypothesisCreator::storeParams ( ) const
◆ type()
QString SMESHGUI_GenericHypothesisCreator::type ( ) const
◆ valueChanged()
void SMESHGUI_GenericHypothesisCreator::valueChanged ( QWidget *  )
◆ widgets()
◆ myDlg
QtxDialog* SMESHGUI_GenericHypothesisCreator::myDlg
◆ myHypName
QString SMESHGUI_GenericHypothesisCreator::myHypName
Referenced by editHypothesis(), and hypName().
◆ myHypo
SMESH::SMESH_Hypothesis_var SMESHGUI_GenericHypothesisCreator::myHypo
◆ myHypType
QString SMESHGUI_GenericHypothesisCreator::myHypType
Referenced by hypType().
◆ myInitParamsHypo
SMESH::SMESH_Hypothesis_var SMESHGUI_GenericHypothesisCreator::myInitParamsHypo
◆ myIsCreate
bool SMESHGUI_GenericHypothesisCreator::myIsCreate
◆ myMainShapeEntry
QString SMESHGUI_GenericHypothesisCreator::myMainShapeEntry
◆ myNoGeomMesh
bool SMESHGUI_GenericHypothesisCreator::myNoGeomMesh
◆ myParamLabels
ListOfWidgets SMESHGUI_GenericHypothesisCreator::myParamLabels
Referenced by buildStdFrame(), and getLabel().
◆ myParamWidgets
ListOfWidgets SMESHGUI_GenericHypothesisCreator::myParamWidgets
Referenced by changeWidgets(), and widgets().
◆ myShapeEntry
QString SMESHGUI_GenericHypothesisCreator::myShapeEntry
Referenced by setShapeEntry().
◆ myToDeleteInitParamsHypo
bool SMESHGUI_GenericHypothesisCreator::myToDeleteInitParamsHypo
