StdMeshersGUI_BlockRenumberCreator Class Reference
#include <StdMeshersGUI_BlockRenumberCreator.h>
Inheritance diagram for StdMeshersGUI_BlockRenumberCreator:
Signals
void finished (int)
 StdMeshersGUI_BlockRenumberCreator (const QString &aHypType)
 StdMeshersGUI_BlockRenumberCreator constructor. More...
 ~StdMeshersGUI_BlockRenumberCreator ()
 StdMeshersGUI_BlockRenumberCreator destructor. More...
virtual bool checkParams (QString &) const override
 Validate parameters. More...
virtual QString helpPage () const override
 Returns a name of help page. More...
virtual QString hypTypeName (const QString &) const override
 Type name. More...
void create (SMESH::SMESH_Hypothesis_ptr, const QString &, QWidget *, QObject *, const QString &)
void create (bool, const QString &, QWidget *, QObject *, const QString &)
void edit (SMESH::SMESH_Hypothesis_ptr, const QString &, QWidget *, QObject *, const QString &)
void setInitParamsHypothesis (SMESH::SMESH_Hypothesis_ptr)
QString hypType () const
QString hypName () const
bool isCreation () const
QString getShapeEntry () const
void setShapeEntry (const QString &theEntry)
QString getMainShapeEntry () const
void setMainShapeEntry (const QString &theEntry)
void setNoGeomMesh (const bool noGeom)
bool getNoGeomMesh () const
Protected Types
typedef QList< StdParam > ListOfStdParams
typedef QList< QWidget * > ListOfWidgets
Protected Slots
virtual void onValueChanged ()
virtual QFrame * buildFrame () override
 Create widgets. More...
virtual void retrieveParams () const override
 Transfer parameters from hypothesis to widgets. More...
virtual QString storeParams () const override
 Transfer parameters from widgets to hypothesis. More...
virtual bool stdParams (ListOfStdParams &) const
 Return parameter values as SMESHGUI_GenericHypothesisCreator::StdParam. More...
virtual void attuneStdWidget (QWidget *, const int) const
 tune "standard" control More...
virtual QString caption () const
 Return dlg title. More...
virtual QPixmap icon () const
 return pixmap for dlg icon More...
virtual QString type () const
 Return hypothesis type name to show in dlg. More...
virtual QWidget * getCustomWidget (const StdParam &, QWidget *, const int) const
virtual QWidget * getHelperWidget () const
 Returns a widget representing not a hypothesis parameter but some helper widget. More...
virtual bool getParamFromCustomWidget (StdParam &, QWidget *) const
 Set param value taken from a custom widget. More...
virtual QWidget * getWidgetForParam (int paramIndex) const
 Return widget for i-th hypothesis parameter (got from myParamWidgets) More...
virtual ListOfWidgets * customWidgets () const
 Allow modifying myCustomWidgets in const methods. More...
virtual void onReject ()
 called when operation cancelled More...
virtual void valueChanged (QWidget *)
 Update widgets dependent on paramWidget. More...
bool initVariableName (SMESH::SMESH_Hypothesis_var theHyp, StdParam &theParams, const char *theMethod) const
QWidget * makeReverseEdgesWdg (SMESH::long_array_var edgeIDs, CORBA::String_var shapeEntry) const
 Creates two widgets used to define reversed edges for some 1D hypotheses. More...
void removeOldGroup (const char *oldName, const char *newName, SMESH::ElementType type) const
 Remove a group, whose name is stored by hypothesis, upon group name modification. More...
template<class T >
T * widget (int i) const
SMESH::SMESH_Hypothesis_var hypothesis () const
SMESH::SMESH_Hypothesis_var initParamsHypothesis (const bool strict=false) const
 Return hypothesis containing initial parameters. More...
bool hasInitParamsHypothesis () const
const ListOfWidgets & widgets () const
ListOfWidgets & changeWidgets ()
QLabel * getLabel (int i) const
 Returns a QLabel of a specified parameter. More...
QtxDialog * dlg () const
QString getVariableName (const char *methodName) const
QFrame * buildStdFrame ()
bool getStdParamFromDlg (ListOfStdParams &) const
virtual QStringList getVariablesFromDlg () const
static QString stdParamValues (const ListOfStdParams &)
ListOfWidgets myCustomWidgets
QWidget * myHelperWidget
Private Slots
void onSelectionChange ()
 Take selected object. More...
void onTreeSelectionChange ()
 Display selected block CS in myLineEdit's. More...
void updateButtons ()
 Activate/deactivate buttons. More...
void onSelectBtnClick ()
 Install filter upon activation of another object selection. More...
void onAddBtnClick ()
 Add shapes to the tree. More...
void onModifBtnClick ()
 Modify a current block. More...
void onRemoveBtnClick ()
 Remove selected block from the tree. More...
virtual void onDialogFinished (int)
void setBlockToTree (QTreeWidgetItem *item=0)
 Set myGO's to the tree. More...
void editHypothesis (SMESH::SMESH_Hypothesis_ptr, const QString &, QWidget *, QObject *obj, const QString &)
QLineEdit * myName
QTreeWidget * myBlockTree
QPushButton * myShapeSelectBut [3]
QButtonGroup * myButGroup
QLineEdit * myLineEdit [3]
QPushButton * myAddBut
QPushButton * myModifBut
QPushButton * myRemoveBut
GEOM::GEOM_Object_var myGO [3]
SMESH_NumberFilter mySolidFilter
SMESH_NumberFilter myVertexFilter
SMESH::SMESH_Hypothesis_var myHypo
SMESH::SMESH_Hypothesis_var myInitParamsHypo
bool myToDeleteInitParamsHypo
QString myHypName
QString myHypType
ListOfWidgets myParamWidgets
ListOfWidgets myParamLabels
bool myIsCreate
bool myNoGeomMesh
 true for a mesh not based on geometry More...
QtxDialog * myDlg
QString myShapeEntry
QString myMainShapeEntry
◆ ListOfStdParams
◆ ListOfWidgets
typedef QList<QWidget*> SMESHGUI_GenericHypothesisCreator::ListOfWidgets
◆ StdMeshersGUI_BlockRenumberCreator()
StdMeshersGUI_BlockRenumberCreator::StdMeshersGUI_BlockRenumberCreator ( const QString &  aHypType)
◆ ~StdMeshersGUI_BlockRenumberCreator()
StdMeshersGUI_BlockRenumberCreator::~StdMeshersGUI_BlockRenumberCreator ( )
◆ attuneStdWidget()
void StdMeshersGUI_StdHypothesisCreator::attuneStdWidget ( QWidget *  w,
const int
w- control widget
int- parameter index
Reimplemented from SMESHGUI_GenericHypothesisCreator.
References SMESHGUI_GenericHypothesisCreator::hypType(), SMESHGUI_SpinBox::RangeStepAndValidator(), VALUE_MAX, VALUE_MAX_2, VALUE_MAX_3, VALUE_SMALL, VALUE_SMALL_2, and VALUE_SMALL_3.
◆ buildFrame()
◆ buildStdFrame()
◆ caption()
QString StdMeshersGUI_StdHypothesisCreator::caption ( ) const
Return dlg title.
QString- title string
References SMESHGUI_GenericHypothesisCreator::hypType(), and StdMeshersGUI_StdHypothesisCreator::hypTypeName().
◆ changeWidgets()
◆ checkParams()
bool StdMeshersGUI_BlockRenumberCreator::checkParams ( QString &  ) const
overridevirtual
Reimplemented from StdMeshersGUI_StdHypothesisCreator.
◆ create() [1/2]
void SMESHGUI_GenericHypothesisCreator::create ( bool  isAlgo,
const QString &  theHypName,
QWidget *  theParent,
QObject *  obj,
const QString &  slot
◆ create() [2/2]
void SMESHGUI_GenericHypothesisCreator::create ( SMESH::SMESH_Hypothesis_ptr  initParamsHyp,
QWidget *  parent,
QObject *  obj,
◆ customWidgets()
StdMeshersGUI_StdHypothesisCreator::ListOfWidgets * StdMeshersGUI_StdHypothesisCreator::customWidgets ( ) const
◆ dlg()
◆ edit()
void SMESHGUI_GenericHypothesisCreator::edit ( SMESH::SMESH_Hypothesis_ptr  theHypothesis,
QObject *  obj,
◆ editHypothesis()
◆ finished
void SMESHGUI_GenericHypothesisCreator::finished ( int  )
signalinherited
◆ getCustomWidget()
QWidget * StdMeshersGUI_StdHypothesisCreator::getCustomWidget ( const StdParam &  ,
QWidget *  parent,
const int  index
◆ getHelperWidget()
virtual QWidget * StdMeshersGUI_StdHypothesisCreator::getHelperWidget ( ) const
◆ getLabel()
QLabel * SMESHGUI_GenericHypothesisCreator::getLabel ( int  i) const
If isCreation(), the 1st label (supposed to be "Name") is not countered.
References SMESHGUI_GenericHypothesisCreator::isCreation(), and SMESHGUI_GenericHypothesisCreator::myParamLabels.
Referenced by StdMeshersGUI_StdHypothesisCreator::valueChanged().
◆ getMainShapeEntry()
◆ getNoGeomMesh()
bool SMESHGUI_GenericHypothesisCreator::getNoGeomMesh ( ) const
◆ getParamFromCustomWidget()
◆ getShapeEntry()
◆ getStdParamFromDlg()
◆ getVariableName()
QString SMESHGUI_GenericHypothesisCreator::getVariableName ( const char *  methodName) const
◆ getVariablesFromDlg()
QStringList SMESHGUI_GenericHypothesisCreator::getVariablesFromDlg ( ) const
◆ getWidgetForParam()
QWidget * StdMeshersGUI_StdHypothesisCreator::getWidgetForParam ( int  i) const
i- index of hypothesis parameter
QWidget*- found widget
References SMESHGUI_GenericHypothesisCreator::isCreation(), StdMeshersGUI_StdHypothesisCreator::myCustomWidgets, and SMESHGUI_GenericHypothesisCreator::widgets().
Referenced by StdMeshersGUI_StdHypothesisCreator::storeParams(), and StdMeshersGUI_StdHypothesisCreator::valueChanged().
◆ hasInitParamsHypothesis()
bool SMESHGUI_GenericHypothesisCreator::hasInitParamsHypothesis ( ) const
◆ helpPage()
QString StdMeshersGUI_BlockRenumberCreator::helpPage ( ) const
overridevirtual
◆ hypName()
◆ hypothesis()
◆ hypType()
◆ hypTypeName()
QString StdMeshersGUI_BlockRenumberCreator::hypTypeName ( const QString &  ) const
overridevirtual
Type name.
◆ icon()
QPixmap StdMeshersGUI_StdHypothesisCreator::icon ( ) const
QPixmap-
References SMESHGUI_GenericHypothesisCreator::hypType(), StdMeshersGUI_StdHypothesisCreator::hypTypeName(), and SMESHGUI::resourceMgr().
Referenced by buildFrame().
◆ initParamsHypothesis()
SMESH::SMESH_Hypothesis_var SMESHGUI_GenericHypothesisCreator::initParamsHypothesis ( const bool  strictly = false) const
◆ initVariableName()
bool StdMeshersGUI_StdHypothesisCreator::initVariableName ( SMESH::SMESH_Hypothesis_var  theHyp,
StdParam &  theParams,
const char *  theMethod
◆ isCreation()
◆ makeReverseEdgesWdg()
QWidget * StdMeshersGUI_StdHypothesisCreator::makeReverseEdgesWdg ( SMESH::long_array_var  edgeIDs,
[in]edgeIDs- ids of reversed edges to set to the widgets
[in]shapeEntry- entry of a sub-shape of a sub-mesh if any
QWidget* - new StdMeshersGUI_SubShapeSelectorWdg; new StdMeshersGUI_PropagationHelperWdg is stored in myHelperWidget field.
References SMESHGUI_GenericHypothesisCreator::getMainShapeEntry(), SMESHGUI_GenericHypothesisCreator::getShapeEntry(), StdMeshersGUI_StdHypothesisCreator::myHelperWidget, StdMeshersGUI_SubShapeSelectorWdg::SetGeomShapeEntry(), StdMeshersGUI_SubShapeSelectorWdg::SetListOfIDs(), and StdMeshersGUI_SubShapeSelectorWdg::ShowPreview().
Referenced by StdMeshersGUI_StdHypothesisCreator::stdParams().
◆ onAddBtnClick
void StdMeshersGUI_BlockRenumberCreator::onAddBtnClick ( )
privateslot
References setBlockToTree(), and updateButtons().
◆ onDialogFinished
◆ onModifBtnClick
void StdMeshersGUI_BlockRenumberCreator::onModifBtnClick ( )
privateslot
References myBlockTree, myGO, setBlockToTree(), and updateButtons().
◆ onReject()
void StdMeshersGUI_StdHypothesisCreator::onReject ( )
◆ onRemoveBtnClick
void StdMeshersGUI_BlockRenumberCreator::onRemoveBtnClick ( )
privateslot
References myBlockTree, and updateButtons().
◆ onSelectBtnClick
void StdMeshersGUI_BlockRenumberCreator::onSelectBtnClick ( )
privateslot
References myButGroup, mySolidFilter, myVertexFilter, and SMESHGUI::selectionMgr().
◆ onSelectionChange
void StdMeshersGUI_BlockRenumberCreator::onSelectionChange ( )
privateslot
◆ onTreeSelectionChange
void StdMeshersGUI_BlockRenumberCreator::onTreeSelectionChange ( )
privateslot
References myBlockTree, myGO, myLineEdit, SMESH::toString(), and updateButtons().
◆ onValueChanged
void SMESHGUI_GenericHypothesisCreator::onValueChanged ( )
protectedvirtualslotinherited
◆ removeOldGroup()
void StdMeshersGUI_StdHypothesisCreator::removeOldGroup ( const char *  oldName,
const char *  newName,
[in]oldName- old group name
[in]newName- new group name
[in]type- group type
References SMESH::_PTR(), SMESH::GetMeshesUsingAlgoOrHypothesis(), SMESHGUI_GenericHypothesisCreator::hypothesis(), and StdMeshersGUI_StdHypothesisCreator::type().
Referenced by StdMeshersGUI_StdHypothesisCreator::storeParams().
◆ retrieveParams()
void StdMeshersGUI_BlockRenumberCreator::retrieveParams ( ) const
overrideprotectedvirtual
◆ setBlockToTree()
void StdMeshersGUI_BlockRenumberCreator::setBlockToTree ( QTreeWidgetItem *  item = 0)
References myBlockTree, myGO, and myLineEdit.
Referenced by onAddBtnClick(), onModifBtnClick(), and retrieveParams().
◆ setInitParamsHypothesis()
◆ setMainShapeEntry()
void SMESHGUI_GenericHypothesisCreator::setMainShapeEntry ( const QString &  theEntry)
◆ setNoGeomMesh()
void SMESHGUI_GenericHypothesisCreator::setNoGeomMesh ( const bool  noGeom)
◆ setShapeEntry()
void SMESHGUI_GenericHypothesisCreator::setShapeEntry ( const QString &  theEntry)
◆ stdParams()
bool StdMeshersGUI_StdHypothesisCreator::stdParams ( ListOfStdParams &  p) const
p- list of parameters
bool- success flag
Is called from SMESHGUI_GenericHypothesisCreator::buildStdFrame(). Parameters will be shown using "standard" controls: Int by QtxIntSpinBox Double by SMESHGUI_SpinBox String by QLineEdit getCustomWidget() allows to redefine control for a parameter
References StdMeshersGUI_StdHypothesisCreator::customWidgets(), SMESHGUI_GenericHypothesisCreator::dlg(), StdMeshersGUI_RadioButtonsGrpWdg::getButtonGroup(), SMESH::GetHypothesisData(), SMESHGUI_GenericHypothesisCreator::getMainShapeEntry(), StdMeshersGUI_NameCheckableGrpWdg::getName(), SMESHGUI_GenericHypothesisCreator::getShapeEntry(), SMESH::GROUP_EDGE, SMESH::GROUP_FACE, SMESHGUI_GenericHypothesisCreator::hypName(), SMESHGUI_GenericHypothesisCreator::hypType(), SMESHGUI_GenericHypothesisCreator::initParamsHypothesis(), StdMeshersGUI_StdHypothesisCreator::initVariableName(), SMESHGUI_GenericHypothesisCreator::isCreation(), StdMeshersGUI_StdHypothesisCreator::makeReverseEdgesWdg(), SMESH::MESH, SMESHGUI_GenericHypothesisCreator::StdParam::myName, SMESHGUI_GenericHypothesisCreator::StdParam::myValue, SMESHGUI_GenericHypothesisCreator::onValueChanged(), SMESHGUI_SpinBox::RangeStepAndValidator(), StdMeshersGUI_RadioButtonsGrpWdg::setButtonLabels(), StdMeshersGUI_RadioButtonsGrpWdg::setChecked(), StdMeshersGUI_NameCheckableGrpWdg::setDefaultName(), StdMeshersGUI_SubShapeSelectorWdg::SetGeomShapeEntry(), StdMeshersGUI_SubShapeSelectorWdg::SetListOfIDs(), StdMeshersGUI_FixedPointsParamWdg::SetListOfPoints(), StdMeshersGUI_FixedPointsParamWdg::SetListOfSegments(), StdMeshersGUI_NameCheckableGrpWdg::setName(), SMESHGUI_GenericHypothesisCreator::StdParam::setNoName(), SMESHGUI_SpinBox::SetValue(), StdMeshersGUI_SubShapeSelectorWdg::ShowPreview(), and StdMeshersGUI_StdHypothesisCreator::type().
◆ stdParamValues()
QString SMESHGUI_GenericHypothesisCreator::stdParamValues ( const ListOfStdParams &  params)
staticprotectedinherited
◆ storeParams()
QString StdMeshersGUI_BlockRenumberCreator::storeParams ( ) const
◆ type()
QString StdMeshersGUI_StdHypothesisCreator::type ( ) const
◆ updateButtons
void StdMeshersGUI_BlockRenumberCreator::updateButtons ( )
privateslot
◆ valueChanged()
◆ widget()
template<class T >
T * StdMeshersGUI_StdHypothesisCreator::widget ( int  i) const
◆ widgets()
◆ myAddBut
QPushButton* StdMeshersGUI_BlockRenumberCreator::myAddBut
Referenced by buildFrame(), and updateButtons().
◆ myBlockTree
◆ myButGroup
QButtonGroup* StdMeshersGUI_BlockRenumberCreator::myButGroup
◆ myCustomWidgets
◆ myDlg
◆ myGO
GEOM::GEOM_Object_var StdMeshersGUI_BlockRenumberCreator::myGO[3]
◆ myHelperWidget
QWidget* StdMeshersGUI_StdHypothesisCreator::myHelperWidget
◆ myHypName
QString SMESHGUI_GenericHypothesisCreator::myHypName
privateinherited
◆ myHypo
◆ myHypType
QString SMESHGUI_GenericHypothesisCreator::myHypType
privateinherited
◆ myInitParamsHypo
◆ myIsCreate
◆ myLineEdit
QLineEdit* StdMeshersGUI_BlockRenumberCreator::myLineEdit[3]
◆ myMainShapeEntry
QString SMESHGUI_GenericHypothesisCreator::myMainShapeEntry
privateinherited
◆ myModifBut
QPushButton* StdMeshersGUI_BlockRenumberCreator::myModifBut
◆ myName
QLineEdit* StdMeshersGUI_BlockRenumberCreator::myName
◆ myNoGeomMesh
bool SMESHGUI_GenericHypothesisCreator::myNoGeomMesh
privateinherited
◆ myParamLabels
ListOfWidgets SMESHGUI_GenericHypothesisCreator::myParamLabels
privateinherited
◆ myParamWidgets
ListOfWidgets SMESHGUI_GenericHypothesisCreator::myParamWidgets
privateinherited
◆ myRemoveBut
QPushButton* StdMeshersGUI_BlockRenumberCreator::myRemoveBut
◆ myShapeEntry
QString SMESHGUI_GenericHypothesisCreator::myShapeEntry
privateinherited
◆ myShapeSelectBut
QPushButton* StdMeshersGUI_BlockRenumberCreator::myShapeSelectBut[3]
Referenced by buildFrame(), and retrieveParams().
◆ mySolidFilter
SMESH_NumberFilter StdMeshersGUI_BlockRenumberCreator::mySolidFilter
Referenced by onSelectBtnClick().
◆ myToDeleteInitParamsHypo
bool SMESHGUI_GenericHypothesisCreator::myToDeleteInitParamsHypo
privateinherited
◆ myVertexFilter
SMESH_NumberFilter StdMeshersGUI_BlockRenumberCreator::myVertexFilter
