StdMeshersGUI_ObjectReferenceParamWdg Class Reference
Widget controlling hypothesis parameter that is an object reference. More...
#include <StdMeshersGUI_ObjectReferenceParamWdg.h>
Inheritance diagram for StdMeshersGUI_ObjectReferenceParamWdg:
Public Slots
void activateSelection ()
 Activates selection (if not yet done), emits selectionActivated() More...
void deactivateSelection ()
 SLOT: stop treating selection changes. More...
Signals
void selectionActivated ()
 Emitted when selection is activated. More...
void contentModified ()
 StdMeshersGUI_ObjectReferenceParamWdg (SUIT_SelectionFilter *filter, QWidget *parent, bool multiSelection=false)
 Constructor initialized by filter. More...
 StdMeshersGUI_ObjectReferenceParamWdg (SMESH::MeshObjectType objType, QWidget *parent, bool multiSelection=false)
 Constructor initialized by object type. More...
 ~StdMeshersGUI_ObjectReferenceParamWdg ()
void SetObject (CORBA::Object_ptr obj)
 Initialize selected object name. More...
void SetObjects (SMESH::string_array_var &objEntries)
 Initialize selected objects. More...
template<class TInterface >
TInterface::_var_type GetObject (size_t i=0) const
size_t NbObjects () const
QString GetValue () const
bool IsObjectSelected (size_t i=0) const
bool IsSelectionActivated () const
 Get the selection status. More...
void AvoidSimultaneousSelection (StdMeshersGUI_ObjectReferenceParamWdg *other)
 Connect selection slots. More...
void SetDefaultText (QString defaultText="", QString styleSheet="")
Private Slots
void onSelectionDone ()
 Takes selected object. More...
void init ()
 Create a leayout, initialize fields. More...
bool myMultiSelection
std::vector< CORBA::Object_var > myObjects
SUIT_SelectionFilter * myFilter
bool mySelectionActivated
bool myStretchActivated
SMESHGUI * mySMESHGUI
LightApp_SelectionMgr * mySelectionMgr
QLineEdit * myObjNameLineEdit
QPushButton * mySelButton
QString myParamValue
QString myEmptyText
QString myEmptyStyleSheet
◆ StdMeshersGUI_ObjectReferenceParamWdg() [1/2]
StdMeshersGUI_ObjectReferenceParamWdg::StdMeshersGUI_ObjectReferenceParamWdg ( SUIT_SelectionFilter *  f,
QWidget *  parent,
bool  multiSelection = false
f- object filter
References init(), and myFilter.
◆ StdMeshersGUI_ObjectReferenceParamWdg() [2/2]
StdMeshersGUI_ObjectReferenceParamWdg::StdMeshersGUI_ObjectReferenceParamWdg ( SMESH::MeshObjectType  objType,
QWidget *  parent,
MeshObjectType- type of object to select
◆ ~StdMeshersGUI_ObjectReferenceParamWdg()
StdMeshersGUI_ObjectReferenceParamWdg::~StdMeshersGUI_ObjectReferenceParamWdg ( )
References myFilter, and mySelectionMgr.
◆ activateSelection
void StdMeshersGUI_ObjectReferenceParamWdg::activateSelection ( )
slot
SLOT: Installs selection filter that is not done automatically.
Useful to deactivate one Object Reference param widget when an other one is activated
References SMESH::GetViewWindow(), myFilter, mySelButton, mySelectionActivated, mySelectionMgr, mySMESHGUI, onSelectionDone(), and selectionActivated().
Referenced by init(), and StdMeshersGUI_StdHypothesisCreator::retrieveParams().
◆ AvoidSimultaneousSelection()
void StdMeshersGUI_ObjectReferenceParamWdg::AvoidSimultaneousSelection ( StdMeshersGUI_ObjectReferenceParamWdg *  other)
other- another StdMeshersGUI_ObjectReferenceParamWdg
References deactivateSelection(), and selectionActivated().
Referenced by StdMeshersGUI_StdHypothesisCreator::retrieveParams().
◆ contentModified
void StdMeshersGUI_ObjectReferenceParamWdg::contentModified ( )
signal
Referenced by SetObject(), and SetObjects().
◆ deactivateSelection
void StdMeshersGUI_ObjectReferenceParamWdg::deactivateSelection ( )
slot
References myFilter, mySelButton, mySelectionActivated, and mySelectionMgr.
Referenced by AvoidSimultaneousSelection().
◆ GetObject()
TInterface::_var_type StdMeshersGUI_ObjectReferenceParamWdg::GetObject ( size_t  i = 0) const
◆ GetValue()
QString StdMeshersGUI_ObjectReferenceParamWdg::GetValue ( ) const
◆ init()
◆ IsObjectSelected()
bool StdMeshersGUI_ObjectReferenceParamWdg::IsObjectSelected ( size_t  i = 0) const
◆ IsSelectionActivated()
bool StdMeshersGUI_ObjectReferenceParamWdg::IsSelectionActivated ( ) const
Useful to know which Object Reference param widget is activated to be able to activate the next one when the content of this one has been modified
◆ NbObjects()
size_t StdMeshersGUI_ObjectReferenceParamWdg::NbObjects ( ) const
◆ onSelectionDone
void StdMeshersGUI_ObjectReferenceParamWdg::onSelectionDone ( )
privateslot
◆ selectionActivated
void StdMeshersGUI_ObjectReferenceParamWdg::selectionActivated ( )
signal
Referenced by activateSelection(), and AvoidSimultaneousSelection().
◆ SetDefaultText()
void StdMeshersGUI_ObjectReferenceParamWdg::SetDefaultText ( QString  defaultText = "",
QString  styleSheet = ""
◆ SetObject()
void StdMeshersGUI_ObjectReferenceParamWdg::SetObject ( CORBA::Object_ptr  obj)
obj- the current object
References SMESH::_PTR(), contentModified(), myEmptyStyleSheet, myEmptyText, myObjects, myObjNameLineEdit, and myParamValue.
Referenced by StdMeshersGUI_StdHypothesisCreator::checkParams(), and onSelectionDone().
◆ SetObjects()
void StdMeshersGUI_ObjectReferenceParamWdg::SetObjects ( SMESH::string_array_var &  objects)
objects- entries of objects
References SMESH::_PTR(), contentModified(), myEmptyStyleSheet, myEmptyText, myObjects, myObjNameLineEdit, myParamValue, and SMESH::SObjectToObject().
Referenced by onSelectionDone().
◆ myEmptyStyleSheet
QString StdMeshersGUI_ObjectReferenceParamWdg::myEmptyStyleSheet
◆ myEmptyText
QString StdMeshersGUI_ObjectReferenceParamWdg::myEmptyText
◆ myFilter
◆ myMultiSelection
bool StdMeshersGUI_ObjectReferenceParamWdg::myMultiSelection
◆ myObjects
std::vector<CORBA::Object_var> StdMeshersGUI_ObjectReferenceParamWdg::myObjects
◆ myObjNameLineEdit
QLineEdit* StdMeshersGUI_ObjectReferenceParamWdg::myObjNameLineEdit
◆ myParamValue
QString StdMeshersGUI_ObjectReferenceParamWdg::myParamValue
Referenced by init(), SetObject(), and SetObjects().
◆ mySelButton
QPushButton* StdMeshersGUI_ObjectReferenceParamWdg::mySelButton
◆ mySelectionActivated
bool StdMeshersGUI_ObjectReferenceParamWdg::mySelectionActivated
◆ mySelectionMgr
LightApp_SelectionMgr* StdMeshersGUI_ObjectReferenceParamWdg::mySelectionMgr
◆ mySMESHGUI
SMESHGUI* StdMeshersGUI_ObjectReferenceParamWdg::mySMESHGUI
Referenced by activateSelection(), and init().
◆ myStretchActivated
bool StdMeshersGUI_ObjectReferenceParamWdg::myStretchActivated
