StdMeshersGUI_StdHypothesisCreator Class Reference
Class for creation of standard hypotheses. More...
#include <StdMeshersGUI_StdHypothesisCreator.h>
Inheritance diagram for StdMeshersGUI_StdHypothesisCreator:
Signals
void finished (int)
 StdMeshersGUI_StdHypothesisCreator (const QString &)
virtual ~StdMeshersGUI_StdHypothesisCreator ()
virtual bool checkParams (QString &) const
 Check parameter values before accept() More...
void create (SMESH::SMESH_Hypothesis_ptr, const QString &, QWidget *, QObject *, const QString &)
void create (bool, const QString &, QWidget *, QObject *, const QString &)
void edit (SMESH::SMESH_Hypothesis_ptr, const QString &, QWidget *, QObject *, const QString &)
void setInitParamsHypothesis (SMESH::SMESH_Hypothesis_ptr)
virtual QString helpPage () const
QString hypType () const
QString hypName () const
bool isCreation () const
QString getShapeEntry () const
void setShapeEntry (const QString &theEntry)
QString getMainShapeEntry () const
void setMainShapeEntry (const QString &theEntry)
void setNoGeomMesh (const bool noGeom)
bool getNoGeomMesh () const
Protected Types
typedef QList< StdParam > ListOfStdParams
typedef QList< QWidget * > ListOfWidgets
Protected Slots
virtual void onValueChanged ()
virtual QFrame * buildFrame ()
 Builds dlg layout. More...
virtual void retrieveParams () const
 Initialise parameter values in controls. More...
virtual QString storeParams () const
 Store params from GUI controls to a hypothesis. More...
virtual bool stdParams (ListOfStdParams &) const
 Return parameter values as SMESHGUI_GenericHypothesisCreator::StdParam. More...
virtual void attuneStdWidget (QWidget *, const int) const
 tune "standard" control More...
virtual QString caption () const
 Return dlg title. More...
virtual QPixmap icon () const
 return pixmap for dlg icon More...
virtual QString type () const
 Return hypothesis type name to show in dlg. More...
virtual QWidget * getCustomWidget (const StdParam &, QWidget *, const int) const
virtual QWidget * getHelperWidget () const
 Returns a widget representing not a hypothesis parameter but some helper widget. More...
virtual bool getParamFromCustomWidget (StdParam &, QWidget *) const
 Set param value taken from a custom widget. More...
virtual QString hypTypeName (const QString &) const
 String to insert in "SMESH_%1_HYPOTHESIS" to get hypothesis type name from message resource file. More...
virtual QWidget * getWidgetForParam (int paramIndex) const
 Return widget for i-th hypothesis parameter (got from myParamWidgets) More...
virtual ListOfWidgets * customWidgets () const
 Allow modifying myCustomWidgets in const methods. More...
virtual void onReject ()
 called when operation cancelled More...
virtual void valueChanged (QWidget *)
 Update widgets dependent on paramWidget. More...
bool initVariableName (SMESH::SMESH_Hypothesis_var theHyp, StdParam &theParams, const char *theMethod) const
QWidget * makeReverseEdgesWdg (SMESH::long_array_var edgeIDs, CORBA::String_var shapeEntry) const
 Creates two widgets used to define reversed edges for some 1D hypotheses. More...
void removeOldGroup (const char *oldName, const char *newName, SMESH::ElementType type) const
 Remove a group, whose name is stored by hypothesis, upon group name modification. More...
template<class T >
T * widget (int i) const
SMESH::SMESH_Hypothesis_var hypothesis () const
SMESH::SMESH_Hypothesis_var initParamsHypothesis (const bool strict=false) const
 Return hypothesis containing initial parameters. More...
bool hasInitParamsHypothesis () const
const ListOfWidgets & widgets () const
ListOfWidgets & changeWidgets ()
QLabel * getLabel (int i) const
 Returns a QLabel of a specified parameter. More...
QtxDialog * dlg () const
QString getVariableName (const char *methodName) const
QFrame * buildStdFrame ()
bool getStdParamFromDlg (ListOfStdParams &) const
virtual QStringList getVariablesFromDlg () const
static QString stdParamValues (const ListOfStdParams &)
ListOfWidgets myCustomWidgets
QWidget * myHelperWidget
Private Slots
virtual void onDialogFinished (int)
void editHypothesis (SMESH::SMESH_Hypothesis_ptr, const QString &, QWidget *, QObject *obj, const QString &)
SMESH::SMESH_Hypothesis_var myHypo
SMESH::SMESH_Hypothesis_var myInitParamsHypo
bool myToDeleteInitParamsHypo
QString myHypName
QString myHypType
ListOfWidgets myParamWidgets
ListOfWidgets myParamLabels
bool myIsCreate
bool myNoGeomMesh
 true for a mesh not based on geometry More...
QtxDialog * myDlg
QString myShapeEntry
QString myMainShapeEntry
◆ ListOfStdParams
◆ ListOfWidgets
typedef QList<QWidget*> SMESHGUI_GenericHypothesisCreator::ListOfWidgets
◆ StdMeshersGUI_StdHypothesisCreator()
StdMeshersGUI_StdHypothesisCreator::StdMeshersGUI_StdHypothesisCreator ( const QString &  type)
type- hypothesis type
◆ ~StdMeshersGUI_StdHypothesisCreator()
StdMeshersGUI_StdHypothesisCreator::~StdMeshersGUI_StdHypothesisCreator ( )
◆ attuneStdWidget()
void StdMeshersGUI_StdHypothesisCreator::attuneStdWidget ( QWidget *  w,
const int
w- control widget
int- parameter index
Reimplemented from SMESHGUI_GenericHypothesisCreator.
References SMESHGUI_GenericHypothesisCreator::hypType(), SMESHGUI_SpinBox::RangeStepAndValidator(), VALUE_MAX, VALUE_MAX_2, VALUE_MAX_3, VALUE_SMALL, VALUE_SMALL_2, and VALUE_SMALL_3.
◆ buildFrame()
QFrame * StdMeshersGUI_StdHypothesisCreator::buildFrame ( )
◆ buildStdFrame()
◆ caption()
QString StdMeshersGUI_StdHypothesisCreator::caption ( ) const
Return dlg title.
QString- title string
References SMESHGUI_GenericHypothesisCreator::hypType(), and hypTypeName().
◆ changeWidgets()
◆ checkParams()
◆ create() [1/2]
void SMESHGUI_GenericHypothesisCreator::create ( bool  isAlgo,
const QString &  theHypName,
QWidget *  theParent,
QObject *  obj,
const QString &  slot
◆ create() [2/2]
void SMESHGUI_GenericHypothesisCreator::create ( SMESH::SMESH_Hypothesis_ptr  initParamsHyp,
QWidget *  parent,
QObject *  obj,
◆ customWidgets()
StdMeshersGUI_StdHypothesisCreator::ListOfWidgets * StdMeshersGUI_StdHypothesisCreator::customWidgets ( ) const
ListOfWidgets*- non-const pointer to myCustomWidgets
References myCustomWidgets.
Referenced by checkParams(), getCustomWidget(), onReject(), and stdParams().
◆ dlg()
◆ edit()
void SMESHGUI_GenericHypothesisCreator::edit ( SMESH::SMESH_Hypothesis_ptr  theHypothesis,
QObject *  obj,
◆ editHypothesis()
◆ finished
void SMESHGUI_GenericHypothesisCreator::finished ( int  )
signalinherited
◆ getCustomWidget()
QWidget * StdMeshersGUI_StdHypothesisCreator::getCustomWidget ( const StdParam &  ,
QWidget *  parent,
const int  index
References customWidgets().
◆ getHelperWidget()
virtual QWidget * StdMeshersGUI_StdHypothesisCreator::getHelperWidget ( ) const
◆ getLabel()
QLabel * SMESHGUI_GenericHypothesisCreator::getLabel ( int  i) const
If isCreation(), the 1st label (supposed to be "Name") is not countered.
References SMESHGUI_GenericHypothesisCreator::isCreation(), and SMESHGUI_GenericHypothesisCreator::myParamLabels.
Referenced by valueChanged().
◆ getMainShapeEntry()
◆ getNoGeomMesh()
bool SMESHGUI_GenericHypothesisCreator::getNoGeomMesh ( ) const
◆ getParamFromCustomWidget()
bool StdMeshersGUI_StdHypothesisCreator::getParamFromCustomWidget ( StdParam &  param,
QWidget *  widget
◆ getShapeEntry()
QString SMESHGUI_GenericHypothesisCreator::getShapeEntry ( ) const
◆ getStdParamFromDlg()
◆ getVariableName()
QString SMESHGUI_GenericHypothesisCreator::getVariableName ( const char *  methodName) const
◆ getVariablesFromDlg()
QStringList SMESHGUI_GenericHypothesisCreator::getVariablesFromDlg ( ) const
◆ getWidgetForParam()
QWidget * StdMeshersGUI_StdHypothesisCreator::getWidgetForParam ( int  i) const
i- index of hypothesis parameter
QWidget*- found widget
References SMESHGUI_GenericHypothesisCreator::isCreation(), myCustomWidgets, and SMESHGUI_GenericHypothesisCreator::widgets().
Referenced by storeParams(), and valueChanged().
◆ hasInitParamsHypothesis()
bool SMESHGUI_GenericHypothesisCreator::hasInitParamsHypothesis ( ) const
◆ helpPage()
QString SMESHGUI_GenericHypothesisCreator::helpPage ( ) const
◆ hypName()
◆ hypothesis()
◆ hypType()
◆ hypTypeName()
QString StdMeshersGUI_StdHypothesisCreator::hypTypeName ( const QString &  t) const
t- hypothesis type
QString- result string
Reimplemented in StdMeshersGUI_BlockRenumberCreator.
Referenced by caption(), icon(), and type().
◆ icon()
QPixmap StdMeshersGUI_StdHypothesisCreator::icon ( ) const
QPixmap-
References SMESHGUI_GenericHypothesisCreator::hypType(), hypTypeName(), and SMESHGUI::resourceMgr().
Referenced by StdMeshersGUI_BlockRenumberCreator::buildFrame().
◆ initParamsHypothesis()
SMESH::SMESH_Hypothesis_var SMESHGUI_GenericHypothesisCreator::initParamsHypothesis ( const bool  strictly = false) const
◆ initVariableName()
bool StdMeshersGUI_StdHypothesisCreator::initVariableName ( SMESH::SMESH_Hypothesis_var  theHyp,
StdParam &  theParams,
const char *  theMethod
◆ isCreation()
◆ makeReverseEdgesWdg()
QWidget * StdMeshersGUI_StdHypothesisCreator::makeReverseEdgesWdg ( SMESH::long_array_var  edgeIDs,
[in]edgeIDs- ids of reversed edges to set to the widgets
[in]shapeEntry- entry of a sub-shape of a sub-mesh if any
QWidget* - new StdMeshersGUI_SubShapeSelectorWdg; new StdMeshersGUI_PropagationHelperWdg is stored in myHelperWidget field.
References SMESHGUI_GenericHypothesisCreator::getMainShapeEntry(), SMESHGUI_GenericHypothesisCreator::getShapeEntry(), myHelperWidget, StdMeshersGUI_SubShapeSelectorWdg::SetGeomShapeEntry(), StdMeshersGUI_SubShapeSelectorWdg::SetListOfIDs(), and StdMeshersGUI_SubShapeSelectorWdg::ShowPreview().
Referenced by stdParams().
◆ onDialogFinished
◆ onReject()
void StdMeshersGUI_StdHypothesisCreator::onReject ( )
References customWidgets(), and SMESHGUI_GenericHypothesisCreator::hypType().
◆ onValueChanged
void SMESHGUI_GenericHypothesisCreator::onValueChanged ( )
protectedvirtualslotinherited
◆ removeOldGroup()
void StdMeshersGUI_StdHypothesisCreator::removeOldGroup ( const char *  oldName,
const char *  newName,
[in]oldName- old group name
[in]newName- new group name
[in]type- group type
References SMESH::_PTR(), SMESH::GetMeshesUsingAlgoOrHypothesis(), SMESHGUI_GenericHypothesisCreator::hypothesis(), and type().
Referenced by storeParams().
◆ retrieveParams()
◆ setInitParamsHypothesis()
◆ setMainShapeEntry()
void SMESHGUI_GenericHypothesisCreator::setMainShapeEntry ( const QString &  theEntry)
◆ setNoGeomMesh()
void SMESHGUI_GenericHypothesisCreator::setNoGeomMesh ( const bool  noGeom)
◆ setShapeEntry()
void SMESHGUI_GenericHypothesisCreator::setShapeEntry ( const QString &  theEntry)
◆ stdParams()
bool StdMeshersGUI_StdHypothesisCreator::stdParams ( ListOfStdParams &  p) const
p- list of parameters
bool- success flag
Is called from SMESHGUI_GenericHypothesisCreator::buildStdFrame(). Parameters will be shown using "standard" controls: Int by QtxIntSpinBox Double by SMESHGUI_SpinBox String by QLineEdit getCustomWidget() allows to redefine control for a parameter
References customWidgets(), SMESHGUI_GenericHypothesisCreator::dlg(), StdMeshersGUI_RadioButtonsGrpWdg::getButtonGroup(), SMESH::GetHypothesisData(), SMESHGUI_GenericHypothesisCreator::getMainShapeEntry(), StdMeshersGUI_NameCheckableGrpWdg::getName(), SMESHGUI_GenericHypothesisCreator::getShapeEntry(), SMESH::GROUP_EDGE, SMESH::GROUP_FACE, SMESHGUI_GenericHypothesisCreator::hypName(), SMESHGUI_GenericHypothesisCreator::hypType(), SMESHGUI_GenericHypothesisCreator::initParamsHypothesis(), initVariableName(), SMESHGUI_GenericHypothesisCreator::isCreation(), makeReverseEdgesWdg(), SMESH::MESH, SMESHGUI_GenericHypothesisCreator::StdParam::myName, SMESHGUI_GenericHypothesisCreator::StdParam::myValue, SMESHGUI_GenericHypothesisCreator::onValueChanged(), SMESHGUI_SpinBox::RangeStepAndValidator(), StdMeshersGUI_RadioButtonsGrpWdg::setButtonLabels(), StdMeshersGUI_RadioButtonsGrpWdg::setChecked(), StdMeshersGUI_NameCheckableGrpWdg::setDefaultName(), StdMeshersGUI_SubShapeSelectorWdg::SetGeomShapeEntry(), StdMeshersGUI_SubShapeSelectorWdg::SetListOfIDs(), StdMeshersGUI_FixedPointsParamWdg::SetListOfPoints(), StdMeshersGUI_FixedPointsParamWdg::SetListOfSegments(), StdMeshersGUI_NameCheckableGrpWdg::setName(), SMESHGUI_GenericHypothesisCreator::StdParam::setNoName(), SMESHGUI_SpinBox::SetValue(), StdMeshersGUI_SubShapeSelectorWdg::ShowPreview(), and type().
◆ stdParamValues()
QString SMESHGUI_GenericHypothesisCreator::stdParamValues ( const ListOfStdParams &  params)
staticprotectedinherited
◆ storeParams()
◆ type()
QString StdMeshersGUI_StdHypothesisCreator::type ( ) const
QString-
Referenced by StdMeshersGUI_QuadrangleParamCreator::onTypeChanged(), removeOldGroup(), and stdParams().
◆ valueChanged()
◆ widget()
template<class T >
T * StdMeshersGUI_StdHypothesisCreator::widget ( int  i) const
◆ widgets()
◆ myCustomWidgets
ListOfWidgets StdMeshersGUI_StdHypothesisCreator::myCustomWidgets
◆ myDlg
◆ myHelperWidget
QWidget* StdMeshersGUI_StdHypothesisCreator::myHelperWidget
Referenced by makeReverseEdgesWdg().
◆ myHypName
QString SMESHGUI_GenericHypothesisCreator::myHypName
privateinherited
◆ myHypo
◆ myHypType
QString SMESHGUI_GenericHypothesisCreator::myHypType
privateinherited
◆ myInitParamsHypo
◆ myIsCreate
◆ myMainShapeEntry
QString SMESHGUI_GenericHypothesisCreator::myMainShapeEntry
privateinherited
◆ myNoGeomMesh
bool SMESHGUI_GenericHypothesisCreator::myNoGeomMesh
privateinherited
◆ myParamLabels
ListOfWidgets SMESHGUI_GenericHypothesisCreator::myParamLabels
privateinherited
◆ myParamWidgets
ListOfWidgets SMESHGUI_GenericHypothesisCreator::myParamWidgets
privateinherited
◆ myShapeEntry
QString SMESHGUI_GenericHypothesisCreator::myShapeEntry
privateinherited
◆ myToDeleteInitParamsHypo
bool SMESHGUI_GenericHypothesisCreator::myToDeleteInitParamsHypo
privateinherited
