StdMeshersGUI_NbSegmentsCreator Class Reference
#include <StdMeshersGUI_NbSegmentsCreator.h>
Inheritance diagram for StdMeshersGUI_NbSegmentsCreator:
Signals
void finished (int)
 StdMeshersGUI_NbSegmentsCreator ()
virtual ~StdMeshersGUI_NbSegmentsCreator ()
virtual bool checkParams (QString &) const
 Check parameter values before accept() More...
void create (SMESH::SMESH_Hypothesis_ptr, const QString &, QWidget *, QObject *, const QString &)
void create (bool, const QString &, QWidget *, QObject *, const QString &)
void edit (SMESH::SMESH_Hypothesis_ptr, const QString &, QWidget *, QObject *, const QString &)
void setInitParamsHypothesis (SMESH::SMESH_Hypothesis_ptr)
virtual QString helpPage () const
QString hypType () const
QString hypName () const
bool isCreation () const
QString getShapeEntry () const
void setShapeEntry (const QString &theEntry)
QString getMainShapeEntry () const
void setMainShapeEntry (const QString &theEntry)
void setNoGeomMesh (const bool noGeom)
bool getNoGeomMesh () const
Protected Types
typedef QList< StdParam > ListOfStdParams
typedef QList< QWidget * > ListOfWidgets
Protected Slots
virtual void onValueChanged ()
virtual QFrame * buildFrame ()
 Builds dlg layout. More...
virtual void retrieveParams () const
 Initialise parameter values in controls. More...
virtual QString storeParams () const
 Store params from GUI controls to a hypothesis. More...
virtual bool stdParams (ListOfStdParams &) const
 Return parameter values as SMESHGUI_GenericHypothesisCreator::StdParam. More...
virtual void attuneStdWidget (QWidget *, const int) const
 tune "standard" control More...
virtual QString caption () const
 Return dlg title. More...
virtual QPixmap icon () const
 return pixmap for dlg icon More...
virtual QString type () const
 Return hypothesis type name to show in dlg. More...
virtual QWidget * getCustomWidget (const StdParam &, QWidget *, const int) const
virtual QWidget * getHelperWidget () const
 Returns a widget representing not a hypothesis parameter but some helper widget. More...
virtual bool getParamFromCustomWidget (StdParam &, QWidget *) const
 Set param value taken from a custom widget. More...
virtual QString hypTypeName (const QString &) const
 String to insert in "SMESH_%1_HYPOTHESIS" to get hypothesis type name from message resource file. More...
virtual QWidget * getWidgetForParam (int paramIndex) const
 Return widget for i-th hypothesis parameter (got from myParamWidgets) More...
virtual ListOfWidgets * customWidgets () const
 Allow modifying myCustomWidgets in const methods. More...
virtual void onReject ()
 called when operation cancelled More...
virtual void valueChanged (QWidget *)
 Update widgets dependent on paramWidget. More...
bool initVariableName (SMESH::SMESH_Hypothesis_var theHyp, StdParam &theParams, const char *theMethod) const
QWidget * makeReverseEdgesWdg (SMESH::long_array_var edgeIDs, CORBA::String_var shapeEntry) const
 Creates two widgets used to define reversed edges for some 1D hypotheses. More...
void removeOldGroup (const char *oldName, const char *newName, SMESH::ElementType type) const
 Remove a group, whose name is stored by hypothesis, upon group name modification. More...
template<class T >
T * widget (int i) const
SMESH::SMESH_Hypothesis_var hypothesis () const
SMESH::SMESH_Hypothesis_var initParamsHypothesis (const bool strict=false) const
 Return hypothesis containing initial parameters. More...
bool hasInitParamsHypothesis () const
const ListOfWidgets & widgets () const
ListOfWidgets & changeWidgets ()
QLabel * getLabel (int i) const
 Returns a QLabel of a specified parameter. More...
QtxDialog * dlg () const
QString getVariableName (const char *methodName) const
QFrame * buildStdFrame ()
bool getStdParamFromDlg (ListOfStdParams &) const
virtual QStringList getVariablesFromDlg () const
static QString stdParamValues (const ListOfStdParams &)
ListOfWidgets myCustomWidgets
QWidget * myHelperWidget
Private Slots
virtual void onDialogFinished (int)
bool readParamsFromHypo (NbSegmentsHypothesisData &) const
bool readParamsFromWidgets (NbSegmentsHypothesisData &) const
bool storeParamsToHypo (const NbSegmentsHypothesisData &) const
void editHypothesis (SMESH::SMESH_Hypothesis_ptr, const QString &, QWidget *, QObject *obj, const QString &)
SalomeApp_IntSpinBox * myNbSeg
QtxComboBox * myDistr
SMESHGUI_SpinBox * myScale
SMESHGUI_SpinBoxForbiddendRange * myBeta
StdMeshersGUI_DistrTableFrame * myTable
StdMeshersGUI_DistrPreview * myPreview
QLineEdit * myName
QLineEdit * myExpr
QGroupBox * myConvBox
QButtonGroup * myConv
QLabel * myLScale
QLabel * myLTable
QLabel * myLExpr
QLabel * myInfo
QLabel * myLBeta
QGridLayout * myGroupLayout
int myTableRow
int myPreviewRow
QGroupBox * myReversedEdgesBox
StdMeshersGUI_SubShapeSelectorWdg * myDirectionWidget
StdMeshersGUI_PropagationHelperWdg * myReversedEdgesHelper
SMESH::SMESH_Hypothesis_var myHypo
SMESH::SMESH_Hypothesis_var myInitParamsHypo
bool myToDeleteInitParamsHypo
QString myHypName
QString myHypType
ListOfWidgets myParamWidgets
ListOfWidgets myParamLabels
bool myIsCreate
bool myNoGeomMesh
 true for a mesh not based on geometry More...
QtxDialog * myDlg
QString myShapeEntry
QString myMainShapeEntry
◆ ListOfStdParams
◆ ListOfWidgets
typedef QList<QWidget*> SMESHGUI_GenericHypothesisCreator::ListOfWidgets
◆ StdMeshersGUI_NbSegmentsCreator()
StdMeshersGUI_NbSegmentsCreator::StdMeshersGUI_NbSegmentsCreator ( )
◆ ~StdMeshersGUI_NbSegmentsCreator()
StdMeshersGUI_NbSegmentsCreator::~StdMeshersGUI_NbSegmentsCreator ( )
◆ attuneStdWidget()
void StdMeshersGUI_StdHypothesisCreator::attuneStdWidget ( QWidget *  w,
const int
w- control widget
int- parameter index
Reimplemented from SMESHGUI_GenericHypothesisCreator.
References SMESHGUI_GenericHypothesisCreator::hypType(), SMESHGUI_SpinBox::RangeStepAndValidator(), VALUE_MAX, VALUE_MAX_2, VALUE_MAX_3, VALUE_SMALL, VALUE_SMALL_2, and VALUE_SMALL_3.
◆ buildFrame()
◆ buildStdFrame()
◆ caption()
QString StdMeshersGUI_StdHypothesisCreator::caption ( ) const
Return dlg title.
QString- title string
References SMESHGUI_GenericHypothesisCreator::hypType(), and StdMeshersGUI_StdHypothesisCreator::hypTypeName().
◆ changeWidgets()
◆ checkParams()
bool StdMeshersGUI_NbSegmentsCreator::checkParams ( QString &  msg) const
bool- true if OK
Reimplemented from StdMeshersGUI_StdHypothesisCreator.
References SMESHGUI_GenericHypothesisCreator::checkParams(), myBeta, myNbSeg, myScale, readParamsFromHypo(), readParamsFromWidgets(), and storeParamsToHypo().
◆ create() [1/2]
void SMESHGUI_GenericHypothesisCreator::create ( bool  isAlgo,
const QString &  theHypName,
QWidget *  theParent,
QObject *  obj,
const QString &  slot
◆ create() [2/2]
void SMESHGUI_GenericHypothesisCreator::create ( SMESH::SMESH_Hypothesis_ptr  initParamsHyp,
QWidget *  parent,
QObject *  obj,
◆ customWidgets()
StdMeshersGUI_StdHypothesisCreator::ListOfWidgets * StdMeshersGUI_StdHypothesisCreator::customWidgets ( ) const
◆ dlg()
◆ edit()
void SMESHGUI_GenericHypothesisCreator::edit ( SMESH::SMESH_Hypothesis_ptr  theHypothesis,
QObject *  obj,
◆ editHypothesis()
◆ finished
void SMESHGUI_GenericHypothesisCreator::finished ( int  )
signalinherited
◆ getCustomWidget()
QWidget * StdMeshersGUI_StdHypothesisCreator::getCustomWidget ( const StdParam &  ,
QWidget *  parent,
const int  index
◆ getHelperWidget()
virtual QWidget * StdMeshersGUI_StdHypothesisCreator::getHelperWidget ( ) const
◆ getLabel()
QLabel * SMESHGUI_GenericHypothesisCreator::getLabel ( int  i) const
If isCreation(), the 1st label (supposed to be "Name") is not countered.
References SMESHGUI_GenericHypothesisCreator::isCreation(), and SMESHGUI_GenericHypothesisCreator::myParamLabels.
Referenced by StdMeshersGUI_StdHypothesisCreator::valueChanged().
◆ getMainShapeEntry()
◆ getNoGeomMesh()
bool SMESHGUI_GenericHypothesisCreator::getNoGeomMesh ( ) const
◆ getParamFromCustomWidget()
◆ getShapeEntry()
◆ getStdParamFromDlg()
◆ getVariableName()
QString SMESHGUI_GenericHypothesisCreator::getVariableName ( const char *  methodName) const
◆ getVariablesFromDlg()
QStringList SMESHGUI_GenericHypothesisCreator::getVariablesFromDlg ( ) const
◆ getWidgetForParam()
QWidget * StdMeshersGUI_StdHypothesisCreator::getWidgetForParam ( int  i) const
i- index of hypothesis parameter
QWidget*- found widget
References SMESHGUI_GenericHypothesisCreator::isCreation(), StdMeshersGUI_StdHypothesisCreator::myCustomWidgets, and SMESHGUI_GenericHypothesisCreator::widgets().
Referenced by StdMeshersGUI_StdHypothesisCreator::storeParams(), and StdMeshersGUI_StdHypothesisCreator::valueChanged().
◆ hasInitParamsHypothesis()
bool SMESHGUI_GenericHypothesisCreator::hasInitParamsHypothesis ( ) const
◆ helpPage()
QString SMESHGUI_GenericHypothesisCreator::helpPage ( ) const
◆ hypName()
◆ hypothesis()
◆ hypType()
◆ hypTypeName()
QString StdMeshersGUI_StdHypothesisCreator::hypTypeName ( const QString &  t) const
t- hypothesis type
QString- result string
Reimplemented in StdMeshersGUI_BlockRenumberCreator.
Referenced by StdMeshersGUI_StdHypothesisCreator::caption(), StdMeshersGUI_StdHypothesisCreator::icon(), and StdMeshersGUI_StdHypothesisCreator::type().
◆ icon()
QPixmap StdMeshersGUI_StdHypothesisCreator::icon ( ) const
◆ initParamsHypothesis()
SMESH::SMESH_Hypothesis_var SMESHGUI_GenericHypothesisCreator::initParamsHypothesis ( const bool  strictly = false) const
◆ initVariableName()
bool StdMeshersGUI_StdHypothesisCreator::initVariableName ( SMESH::SMESH_Hypothesis_var  theHyp,
StdParam &  theParams,
const char *  theMethod
◆ isCreation()
◆ makeReverseEdgesWdg()
QWidget * StdMeshersGUI_StdHypothesisCreator::makeReverseEdgesWdg ( SMESH::long_array_var  edgeIDs,
[in]edgeIDs- ids of reversed edges to set to the widgets
[in]shapeEntry- entry of a sub-shape of a sub-mesh if any
QWidget* - new StdMeshersGUI_SubShapeSelectorWdg; new StdMeshersGUI_PropagationHelperWdg is stored in myHelperWidget field.
References SMESHGUI_GenericHypothesisCreator::getMainShapeEntry(), SMESHGUI_GenericHypothesisCreator::getShapeEntry(), StdMeshersGUI_StdHypothesisCreator::myHelperWidget, StdMeshersGUI_SubShapeSelectorWdg::SetGeomShapeEntry(), StdMeshersGUI_SubShapeSelectorWdg::SetListOfIDs(), and StdMeshersGUI_SubShapeSelectorWdg::ShowPreview().
Referenced by StdMeshersGUI_StdHypothesisCreator::stdParams().
◆ onDialogFinished
◆ onReject()
void StdMeshersGUI_StdHypothesisCreator::onReject ( )
◆ onValueChanged
◆ readParamsFromHypo()
◆ readParamsFromWidgets()
◆ removeOldGroup()
void StdMeshersGUI_StdHypothesisCreator::removeOldGroup ( const char *  oldName,
const char *  newName,
[in]oldName- old group name
[in]newName- new group name
[in]type- group type
References SMESH::_PTR(), SMESH::GetMeshesUsingAlgoOrHypothesis(), SMESHGUI_GenericHypothesisCreator::hypothesis(), and StdMeshersGUI_StdHypothesisCreator::type().
Referenced by StdMeshersGUI_StdHypothesisCreator::storeParams().
◆ retrieveParams()
◆ setInitParamsHypothesis()
◆ setMainShapeEntry()
void SMESHGUI_GenericHypothesisCreator::setMainShapeEntry ( const QString &  theEntry)
◆ setNoGeomMesh()
void SMESHGUI_GenericHypothesisCreator::setNoGeomMesh ( const bool  noGeom)
◆ setShapeEntry()
void SMESHGUI_GenericHypothesisCreator::setShapeEntry ( const QString &  theEntry)
◆ stdParams()
bool StdMeshersGUI_StdHypothesisCreator::stdParams ( ListOfStdParams &  p) const
p- list of parameters
bool- success flag
Is called from SMESHGUI_GenericHypothesisCreator::buildStdFrame(). Parameters will be shown using "standard" controls: Int by QtxIntSpinBox Double by SMESHGUI_SpinBox String by QLineEdit getCustomWidget() allows to redefine control for a parameter
References StdMeshersGUI_StdHypothesisCreator::customWidgets(), SMESHGUI_GenericHypothesisCreator::dlg(), StdMeshersGUI_RadioButtonsGrpWdg::getButtonGroup(), SMESH::GetHypothesisData(), SMESHGUI_GenericHypothesisCreator::getMainShapeEntry(), StdMeshersGUI_NameCheckableGrpWdg::getName(), SMESHGUI_GenericHypothesisCreator::getShapeEntry(), SMESH::GROUP_EDGE, SMESH::GROUP_FACE, SMESHGUI_GenericHypothesisCreator::hypName(), SMESHGUI_GenericHypothesisCreator::hypType(), SMESHGUI_GenericHypothesisCreator::initParamsHypothesis(), StdMeshersGUI_StdHypothesisCreator::initVariableName(), SMESHGUI_GenericHypothesisCreator::isCreation(), StdMeshersGUI_StdHypothesisCreator::makeReverseEdgesWdg(), SMESH::MESH, SMESHGUI_GenericHypothesisCreator::StdParam::myName, SMESHGUI_GenericHypothesisCreator::StdParam::myValue, SMESHGUI_GenericHypothesisCreator::onValueChanged(), SMESHGUI_SpinBox::RangeStepAndValidator(), StdMeshersGUI_RadioButtonsGrpWdg::setButtonLabels(), StdMeshersGUI_RadioButtonsGrpWdg::setChecked(), StdMeshersGUI_NameCheckableGrpWdg::setDefaultName(), StdMeshersGUI_SubShapeSelectorWdg::SetGeomShapeEntry(), StdMeshersGUI_SubShapeSelectorWdg::SetListOfIDs(), StdMeshersGUI_FixedPointsParamWdg::SetListOfPoints(), StdMeshersGUI_FixedPointsParamWdg::SetListOfSegments(), StdMeshersGUI_NameCheckableGrpWdg::setName(), SMESHGUI_GenericHypothesisCreator::StdParam::setNoName(), SMESHGUI_SpinBox::SetValue(), StdMeshersGUI_SubShapeSelectorWdg::ShowPreview(), and StdMeshersGUI_StdHypothesisCreator::type().
◆ stdParamValues()
QString SMESHGUI_GenericHypothesisCreator::stdParamValues ( const ListOfStdParams &  params)
staticprotectedinherited
◆ storeParams()
QString StdMeshersGUI_NbSegmentsCreator::storeParams ( ) const
QString- text representation of parameters
< equidistant distribution
< scale distribution
< distribution with density function presented by table
< distribution with density function presented by expression
References NbSegmentsHypothesisData::myBeta, NbSegmentsHypothesisData::myConv, NbSegmentsHypothesisData::myDistrType, NbSegmentsHypothesisData::myExpr, NbSegmentsHypothesisData::myNbSeg, NbSegmentsHypothesisData::myScale, NbSegmentsHypothesisData::myTable, readParamsFromWidgets(), and storeParamsToHypo().
◆ storeParamsToHypo()
◆ type()
QString StdMeshersGUI_StdHypothesisCreator::type ( ) const
◆ valueChanged()
void StdMeshersGUI_StdHypothesisCreator::valueChanged ( QWidget *  paramWidget)
◆ widget()
template<class T >
T * StdMeshersGUI_StdHypothesisCreator::widget ( int  i) const
◆ widgets()
◆ myBeta
SMESHGUI_SpinBoxForbiddendRange* StdMeshersGUI_NbSegmentsCreator::myBeta
◆ myConv
QButtonGroup* StdMeshersGUI_NbSegmentsCreator::myConv
◆ myConvBox
QGroupBox* StdMeshersGUI_NbSegmentsCreator::myConvBox
Referenced by buildFrame(), and onValueChanged().
◆ myCustomWidgets
◆ myDirectionWidget
StdMeshersGUI_SubShapeSelectorWdg* StdMeshersGUI_NbSegmentsCreator::myDirectionWidget
◆ myDistr
QtxComboBox* StdMeshersGUI_NbSegmentsCreator::myDistr
◆ myDlg
◆ myExpr
QLineEdit * StdMeshersGUI_NbSegmentsCreator::myExpr
◆ myGroupLayout
QGridLayout* StdMeshersGUI_NbSegmentsCreator::myGroupLayout
◆ myHelperWidget
QWidget* StdMeshersGUI_StdHypothesisCreator::myHelperWidget
◆ myHypName
QString SMESHGUI_GenericHypothesisCreator::myHypName
privateinherited
◆ myHypo
◆ myHypType
QString SMESHGUI_GenericHypothesisCreator::myHypType
privateinherited
◆ myInfo
QLabel * StdMeshersGUI_NbSegmentsCreator::myInfo
◆ myInitParamsHypo
◆ myIsCreate
◆ myLBeta
QLabel * StdMeshersGUI_NbSegmentsCreator::myLBeta
◆ myLExpr
QLabel * StdMeshersGUI_NbSegmentsCreator::myLExpr
◆ myLScale
QLabel* StdMeshersGUI_NbSegmentsCreator::myLScale
◆ myLTable
QLabel * StdMeshersGUI_NbSegmentsCreator::myLTable
◆ myMainShapeEntry
QString SMESHGUI_GenericHypothesisCreator::myMainShapeEntry
privateinherited
◆ myName
QLineEdit* StdMeshersGUI_NbSegmentsCreator::myName
◆ myNbSeg
SalomeApp_IntSpinBox* StdMeshersGUI_NbSegmentsCreator::myNbSeg
◆ myNoGeomMesh
bool SMESHGUI_GenericHypothesisCreator::myNoGeomMesh
privateinherited
◆ myParamLabels
ListOfWidgets SMESHGUI_GenericHypothesisCreator::myParamLabels
privateinherited
◆ myParamWidgets
ListOfWidgets SMESHGUI_GenericHypothesisCreator::myParamWidgets
privateinherited
◆ myPreview
StdMeshersGUI_DistrPreview* StdMeshersGUI_NbSegmentsCreator::myPreview
◆ myPreviewRow
int StdMeshersGUI_NbSegmentsCreator::myPreviewRow
◆ myReversedEdgesBox
QGroupBox* StdMeshersGUI_NbSegmentsCreator::myReversedEdgesBox
◆ myReversedEdgesHelper
StdMeshersGUI_PropagationHelperWdg* StdMeshersGUI_NbSegmentsCreator::myReversedEdgesHelper
◆ myScale
SMESHGUI_SpinBox* StdMeshersGUI_NbSegmentsCreator::myScale
◆ myShapeEntry
QString SMESHGUI_GenericHypothesisCreator::myShapeEntry
privateinherited
◆ myTable
StdMeshersGUI_DistrTableFrame* StdMeshersGUI_NbSegmentsCreator::myTable
◆ myTableRow
int StdMeshersGUI_NbSegmentsCreator::myTableRow
◆ myToDeleteInitParamsHypo
bool SMESHGUI_GenericHypothesisCreator::myToDeleteInitParamsHypo
privateinherited
