StdMeshersGUI_SubShapeSelectorWdg Class Reference
#include <StdMeshersGUI_SubShapeSelectorWdg.h>
Inheritance diagram for StdMeshersGUI_SubShapeSelectorWdg:
Public Slots
void ActivateSelection (bool)
 Connect/disconnect to change of selection. More...
void deactivateSelection ()
Signals
void selectionChanged ()
void shapeSelected ()
void selectionActivated ()
 Emitted when selection is activated. More...
 StdMeshersGUI_SubShapeSelectorWdg (QWidget *parent=0, TopAbs_ShapeEnum subShType=TopAbs_EDGE, const bool toShowList=true, const bool toShowSelectBtn=false, const int minListWidth=300)
 ~StdMeshersGUI_SubShapeSelectorWdg ()
SMESH::long_array_var GetListOfIDs ()
bool SetListOfIDs (SMESH::long_array_var)
const QList< int > & GetSelectedIDs () const
void SetGeomShapeEntry (const QString &theEntry, const QString &theMainShapeEntry)
const char * GetMainShapeEntry ()
TopoDS_Shape GetGeomShape ()
TopoDS_Shape GetMainShape ()
QString GetValue () const
void ShowPreview (bool)
 Create a layout, initialize fields. More...
int GetListSize ()
void SetMaxSize (int aMaxSize)
vtkRenderer * GetRenderer ()
SMESH_PreviewActorsCollection * GetActorCollection ()
void ClearSelected ()
 Clears selected IDs. More...
void AvoidSimultaneousSelection (StdMeshersGUI_SubShapeSelectorWdg *other)
 Connect selection slots. More...
static GEOM::GEOM_Object_var GetGeomObjectByEntry (const QString &)
static TopoDS_Shape GetTopoDSByEntry (const QString &)
Private Slots
void onAdd ()
void onRemove ()
void onPrevious ()
void onNext ()
void selectionIntoArgument ()
void onListSelectionChanged ()
void updateState ()
void setFilter ()
 Install filters to select sub-shapes of mySubShType or their groups. More...
void updateButtons ()
void init ()
SMESHGUI * mySMESHGUI
LightApp_SelectionMgr * mySelectionMgr
SVTK_Selector * mySelector
SMESH::SMESH_Mesh_var myMesh
TopoDS_Shape myGeomShape
TopoDS_Shape myMainShape
std::string myEntry
std::string myMainEntry
vtkRenderer * myRenderer
QListWidget * myListWidget
QPushButton * myActivateButton
QPushButton * myAddButton
QPushButton * myRemoveButton
QLabel * myInfoLabel
QPushButton * myPrevButton
QPushButton * myNextButton
QList< int > mySelectedIDs
QList< int > myListOfIDs
QString myParamValue
bool myIsShown
int myMaxSize
TopAbs_ShapeEnum mySubShType
SMESH_PreviewActorsCollection * myPreviewActor
QList< SUIT_SelectionFilter * > myGeomFilters
SUIT_SelectionFilter * myFilter
◆ StdMeshersGUI_SubShapeSelectorWdg()
StdMeshersGUI_SubShapeSelectorWdg::StdMeshersGUI_SubShapeSelectorWdg ( QWidget *  parent = 0,
TopAbs_ShapeEnum  subShType = TopAbs_EDGE,
const bool  toShowList = true,
const bool  toShowSelectBtn = false,
const int  minListWidth = 300
◆ ~StdMeshersGUI_SubShapeSelectorWdg()
StdMeshersGUI_SubShapeSelectorWdg::~StdMeshersGUI_SubShapeSelectorWdg ( )
◆ ActivateSelection
void StdMeshersGUI_SubShapeSelectorWdg::ActivateSelection ( bool  toActivate)
slot
References myActivateButton, mySelectionMgr, selectionActivated(), selectionIntoArgument(), and ShowPreview().
Referenced by init().
◆ AvoidSimultaneousSelection()
void StdMeshersGUI_SubShapeSelectorWdg::AvoidSimultaneousSelection ( StdMeshersGUI_SubShapeSelectorWdg *  other)
other- another StdMeshersGUI_ObjectReferenceParamWdg
References deactivateSelection(), and selectionActivated().
◆ ClearSelected()
void StdMeshersGUI_SubShapeSelectorWdg::ClearSelected ( )
This is a workaround of a bug that SUIT_SelectionMgr::clearSelected() does not emit currentSelectionChanged
References mySelectedIDs, and selectionIntoArgument().
Referenced by StdMeshersGUI_PropagationHelperWdg::onAdd(), and StdMeshersGUI_PropagationHelperWdg::onListSelectionChanged().
◆ deactivateSelection
void StdMeshersGUI_SubShapeSelectorWdg::deactivateSelection ( )
slot
◆ GetActorCollection()
◆ GetGeomObjectByEntry()
GEOM::GEOM_Object_var StdMeshersGUI_SubShapeSelectorWdg::GetGeomObjectByEntry ( const QString &  theEntry)
◆ GetGeomShape()
TopoDS_Shape StdMeshersGUI_SubShapeSelectorWdg::GetGeomShape ( )
◆ GetListOfIDs()
◆ GetListSize()
int StdMeshersGUI_SubShapeSelectorWdg::GetListSize ( )
◆ GetMainShape()
TopoDS_Shape StdMeshersGUI_SubShapeSelectorWdg::GetMainShape ( )
◆ GetMainShapeEntry()
◆ GetRenderer()
vtkRenderer * StdMeshersGUI_SubShapeSelectorWdg::GetRenderer ( )
◆ GetSelectedIDs()
const QList< int > & StdMeshersGUI_SubShapeSelectorWdg::GetSelectedIDs ( ) const
◆ GetTopoDSByEntry()
TopoDS_Shape StdMeshersGUI_SubShapeSelectorWdg::GetTopoDSByEntry ( const QString &  theEntry)
References GetGeomObjectByEntry().
Referenced by SetGeomShapeEntry().
◆ GetValue()
QString StdMeshersGUI_SubShapeSelectorWdg::GetValue ( ) const
◆ init()
◆ onAdd
void StdMeshersGUI_SubShapeSelectorWdg::onAdd ( )
privateslot
◆ onListSelectionChanged
void StdMeshersGUI_SubShapeSelectorWdg::onListSelectionChanged ( )
privateslot
◆ onNext
void StdMeshersGUI_SubShapeSelectorWdg::onNext ( )
privateslot
◆ onPrevious
void StdMeshersGUI_SubShapeSelectorWdg::onPrevious ( )
privateslot
◆ onRemove
void StdMeshersGUI_SubShapeSelectorWdg::onRemove ( )
privateslot
◆ selectionActivated
void StdMeshersGUI_SubShapeSelectorWdg::selectionActivated ( )
signal
Useful to deactivate one Object Reference param widget when an other one is activated
Referenced by ActivateSelection(), and AvoidSimultaneousSelection().
◆ selectionChanged
void StdMeshersGUI_SubShapeSelectorWdg::selectionChanged ( )
signal
Referenced by onListSelectionChanged().
◆ selectionIntoArgument
◆ setFilter()
void StdMeshersGUI_SubShapeSelectorWdg::setFilter ( )
◆ SetGeomShapeEntry()
◆ SetListOfIDs()
◆ SetMaxSize()
void StdMeshersGUI_SubShapeSelectorWdg::SetMaxSize ( int  aMaxSize)
◆ shapeSelected
void StdMeshersGUI_SubShapeSelectorWdg::shapeSelected ( )
signal
Referenced by selectionIntoArgument().
◆ ShowPreview()
◆ updateButtons()
◆ updateState()
◆ myActivateButton
QPushButton* StdMeshersGUI_SubShapeSelectorWdg::myActivateButton
◆ myAddButton
QPushButton* StdMeshersGUI_SubShapeSelectorWdg::myAddButton
◆ myEntry
std::string StdMeshersGUI_SubShapeSelectorWdg::myEntry
◆ myFilter
SUIT_SelectionFilter* StdMeshersGUI_SubShapeSelectorWdg::myFilter
◆ myGeomFilters
QList<SUIT_SelectionFilter*> StdMeshersGUI_SubShapeSelectorWdg::myGeomFilters
◆ myGeomShape
TopoDS_Shape StdMeshersGUI_SubShapeSelectorWdg::myGeomShape
Referenced by SetGeomShapeEntry(), and updateState().
◆ myInfoLabel
QLabel* StdMeshersGUI_SubShapeSelectorWdg::myInfoLabel
◆ myIsShown
bool StdMeshersGUI_SubShapeSelectorWdg::myIsShown
Referenced by ShowPreview(), and updateState().
◆ myListOfIDs
QList<int> StdMeshersGUI_SubShapeSelectorWdg::myListOfIDs
◆ myListWidget
QListWidget* StdMeshersGUI_SubShapeSelectorWdg::myListWidget
◆ myMainEntry
std::string StdMeshersGUI_SubShapeSelectorWdg::myMainEntry
◆ myMainShape
TopoDS_Shape StdMeshersGUI_SubShapeSelectorWdg::myMainShape
◆ myMaxSize
int StdMeshersGUI_SubShapeSelectorWdg::myMaxSize
Referenced by onAdd(), and selectionIntoArgument().
◆ myMesh
SMESH::SMESH_Mesh_var StdMeshersGUI_SubShapeSelectorWdg::myMesh
◆ myNextButton
QPushButton* StdMeshersGUI_SubShapeSelectorWdg::myNextButton
◆ myParamValue
QString StdMeshersGUI_SubShapeSelectorWdg::myParamValue
◆ myPrevButton
QPushButton* StdMeshersGUI_SubShapeSelectorWdg::myPrevButton
◆ myPreviewActor
◆ myRemoveButton
QPushButton* StdMeshersGUI_SubShapeSelectorWdg::myRemoveButton
◆ myRenderer
vtkRenderer* StdMeshersGUI_SubShapeSelectorWdg::myRenderer
◆ mySelectedIDs
QList<int> StdMeshersGUI_SubShapeSelectorWdg::mySelectedIDs
◆ mySelectionMgr
LightApp_SelectionMgr* StdMeshersGUI_SubShapeSelectorWdg::mySelectionMgr
◆ mySelector
SVTK_Selector* StdMeshersGUI_SubShapeSelectorWdg::mySelector
Referenced by init(), and updateState().
◆ mySMESHGUI
◆ mySubShType
TopAbs_ShapeEnum StdMeshersGUI_SubShapeSelectorWdg::mySubShType
