SMESHGUI_MeshDlg Class Reference
Dialog for mech creation or editing. More...
#include <SMESHGUI_MeshDlg.h>
Inheritance diagram for SMESHGUI_MeshDlg:
enum  Controls { Obj , Mesh , Geom }
enum  Dimensions { Dim0D = 0 , Dim1D , Dim2D , Dim3D }
 Describes dimensions. More...
Signals
void hypoSet (const QString &)
void geomSelectionByMesh (bool)
void selectMeshType (const int, const int)
 SMESHGUI_MeshDlg (const bool, const bool)
virtual ~SMESHGUI_MeshDlg ()
void reset ()
 Resets all dialog fields. More...
void setTitile (const bool, const bool)
 Set dialog title. More...
void setHypoSets (const QStringList &)
 Sets list of available Sets of Hypotheses. More...
void setGeomPopupEnabled (const bool)
int getActiveObject ()
 Return ID of an active selection button. More...
SMESHGUI_MeshTab * tab (const int) const
 Gets tab with given id. More...
void enableTab (const int)
 Enable tabs. More...
void disableTab (const int)
 Disable tab. More...
bool isTabEnabled (const int) const
 Check if tab enabled. More...
void setCurrentTab (const int)
 Sets current tab. More...
int currentTab () const
 Return index of a current tab. More...
void setMaxHypoDim (const int)
 Enable/disable tabs. More...
void setAvailableMeshType (const QStringList &)
 Sets available types of mesh. More...
void setCurrentMeshType (const int)
 Set current index types of mesh. More...
int currentMeshType ()
 Get current index types of mesh. More...
bool toCreateAllGroups ()
 Return state of "Create all Groups on Geometry" check-box. More...
virtual void show ()
virtual void setContentActive (const bool)
 set all content to enable (parameter is true) or disable state More...
static int prefix (const QString &)
 Return hard-coded prefix using to differ overlapping types. More...
SUIT_Desktop * desktop () const
 find desktop of active application More...
SUIT_ResourceMgr * resourceMgr () const
 gets resource manager More...
Private Slots
void onHypoSetPopup (QAction *)
 Emits hypoSet signal. More...
void onGeomPopup (QAction *)
 SLOT called when a item of Geom selection popup is chosen. More...
void onGeomSelectionButton (bool)
 SLOT called when a Geom selection button is clicked. More...
void onChangedMeshType (const int)
 Emits selectMeshType( const int, const int ) signal. More...
QMap< int, SMESHGUI_MeshTab * > myTabs
QTabWidget * myTabWg
QToolButton * myHypoSetButton
QMenu * myGeomPopup
QComboBox * myMeshType
QCheckBox * myCreateGroupsCheck
This dialog is used for mech creation or editing.
◆ Controls
Obj
Mesh
Geom
◆ Dimensions
Dim0D
Dim1D
Dim2D
Dim3D
◆ SMESHGUI_MeshDlg()
SMESHGUI_MeshDlg::SMESHGUI_MeshDlg ( const bool  theToCreate,
const bool  theIsMesh
Constructor
theToCreate- if this parameter is true then dialog is used for creation, for editing otherwise
theIsMesh- if this parameter is true then dialog is used for mesh, for sub-mesh otherwise
Makes dialog's look and feel
References Dim0D, Dim1D, Dim2D, Dim3D, Geom, Mesh, myCreateGroupsCheck, myGeomPopup, myHypoSetButton, myMeshType, myTabs, myTabWg, Obj, onChangedMeshType(), setTitile(), and SPACING.
◆ ~SMESHGUI_MeshDlg()
SMESHGUI_MeshDlg::~SMESHGUI_MeshDlg ( )
◆ currentMeshType()
int SMESHGUI_MeshDlg::currentMeshType ( )
◆ currentTab()
int SMESHGUI_MeshDlg::currentTab ( ) const
tab ID
References Dim3D, and myTabWg.
Referenced by SMESHGUI_MeshOp::setFilteredAlgoData().
◆ desktop()
SUIT_Desktop * SMESHGUI_Dialog::desktop ( ) const
References MESHCUT::d.
◆ disableTab()
void SMESHGUI_MeshDlg::disableTab ( const int  theTabId)
Disable tab.
int- tab ID
References myTabs, and myTabWg.
Referenced by SMESHGUI_MeshOp::onAlgoSelected(), and setMaxHypoDim().
◆ enableTab()
void SMESHGUI_MeshDlg::enableTab ( const int  theTabId)
Enable tabs.
int- tab ID
References Dim3D, myHypoSetButton, myTabs, and myTabWg.
◆ geomSelectionByMesh
void SMESHGUI_MeshDlg::geomSelectionByMesh ( bool  )
signal
Referenced by onGeomPopup().
◆ getActiveObject()
int SMESHGUI_MeshDlg::getActiveObject ( )
◆ hypoSet
void SMESHGUI_MeshDlg::hypoSet ( const QString &  )
signal
Referenced by onHypoSetPopup().
◆ isTabEnabled()
bool SMESHGUI_MeshDlg::isTabEnabled ( const int  theTabId) const
int- tab ID
Referenced by SMESHGUI_MeshOp::isAccessibleDim().
◆ onChangedMeshType
void SMESHGUI_MeshDlg::onChangedMeshType ( const int  isIndex)
privateslot
SLOT is called when a combo box "mesh type" is selected.
References Dim3D, myTabWg, and selectMeshType().
Referenced by SMESHGUI_MeshDlg().
◆ onGeomPopup
void SMESHGUI_MeshDlg::onGeomPopup ( QAction *  a)
privateslot
References GEOM_BY_MESH_INDEX, and geomSelectionByMesh().
Referenced by setGeomPopupEnabled().
◆ onGeomSelectionButton
void SMESHGUI_MeshDlg::onGeomSelectionButton ( bool  isBtnOn)
privateslot
References myGeomPopup.
◆ onHypoSetPopup
void SMESHGUI_MeshDlg::onHypoSetPopup ( QAction *  a)
privateslot
SLOT is called when a hypotheses set is selected. Emits hypoSet signal to notify operation about this event
References hypoSet().
Referenced by setHypoSets().
◆ prefix()
int SMESHGUI_Dialog::prefix ( const QString &  name)
Referenced by SMESHGUI_Dialog::SMESHGUI_Dialog(), and SMESHGUI_SelectionOp::typeById().
◆ reset()
void SMESHGUI_MeshDlg::reset ( )
References Dim0D, Dim1D, Dim2D, Dim3D, and myTabs.
◆ resourceMgr()
SUIT_ResourceMgr * SMESHGUI_Dialog::resourceMgr ( ) const
◆ selectMeshType
void SMESHGUI_MeshDlg::selectMeshType ( const int  ,
const int
signal
Referenced by onChangedMeshType().
◆ setAvailableMeshType()
void SMESHGUI_MeshDlg::setAvailableMeshType ( const QStringList &  theTypeMesh)
theTypeMesh- list of available types of mesh
References myMeshType.
Referenced by SMESHGUI_MeshOp::updateMeshTypeList().
◆ setContentActive()
void SMESHGUI_Dialog::setContentActive ( const bool  active)
◆ setCurrentMeshType()
void SMESHGUI_MeshDlg::setCurrentMeshType ( const int  theIndex)
Referenced by SMESHGUI_MeshOp::setFilteredAlgoData(), and SMESHGUI_MeshOp::startOperation().
◆ setCurrentTab()
void SMESHGUI_MeshDlg::setCurrentTab ( const int  theId)
Sets current tab.
Referenced by SMESHGUI_MeshOp::onHypoSet(), setMaxHypoDim(), and SMESHGUI_MeshOp::startOperation().
◆ setGeomPopupEnabled()
void SMESHGUI_MeshDlg::setGeomPopupEnabled ( const bool  enable)
◆ setHypoSets()
void SMESHGUI_MeshDlg::setHypoSets ( const QStringList &  theSets)
References myHypoSetButton, and onHypoSetPopup().
Referenced by SMESHGUI_MeshOp::updateHypoSets().
◆ setMaxHypoDim()
void SMESHGUI_MeshDlg::setMaxHypoDim ( const int  maxDim)
int- maximum possible dimension
References Dim0D, Dim3D, disableTab(), enableTab(), myTabs, myTabWg, and setCurrentTab().
◆ setTitile()
void SMESHGUI_MeshDlg::setTitile ( const bool  theToCreate,
Set dialog title.
References myCreateGroupsCheck.
◆ show()
◆ tab()
SMESHGUI_MeshTab * SMESHGUI_MeshDlg::tab ( const int  theId) const
theId- Tab identifier. Possible values are in "Dimensions" enumeration
SMESHGUI_MeshTab*- pointer to the tab or null if given parameter is invalid
Gets tab containing controls for definition of algorithms and AddHypotheses
References Dim0D, Dim3D, and myTabs.
Referenced by SMESHGUI_MeshOp::createSubMeshOnInternalEdges(), SMESHGUI_MeshOp::currentHyp(), getTabDim(), SMESHGUI_MeshOp::nbDlgHypTypes(), SMESHGUI_MeshOp::onAlgoSelected(), SMESHGUI_MeshOp::onHypoCreated(), SMESHGUI_MeshOp::readMesh(), SMESHGUI_MeshOp::setCurrentHyp(), SMESHGUI_MeshOp::setFilteredAlgoData(), and SMESHGUI_MeshOp::startOperation().
◆ toCreateAllGroups()
bool SMESHGUI_MeshDlg::toCreateAllGroups ( )
Referenced by SMESHGUI_MeshOp::createMesh().
◆ myCreateGroupsCheck
QCheckBox* SMESHGUI_MeshDlg::myCreateGroupsCheck
◆ myGeomPopup
QMenu* SMESHGUI_MeshDlg::myGeomPopup
◆ myHypoSetButton
QToolButton* SMESHGUI_MeshDlg::myHypoSetButton
◆ myMeshType
QComboBox* SMESHGUI_MeshDlg::myMeshType
◆ myTabs
QMap<int, SMESHGUI_MeshTab*> SMESHGUI_MeshDlg::myTabs
◆ myTabWg
QTabWidget* SMESHGUI_MeshDlg::myTabWg
