interface of "Body fitting Parameters" hypothesis. More...
| void | SetSizeThreshold (in double threshold) raises (SALOME::SALOME_Exception) |
| Set size threshold. More... | |
| double | GetSizeThreshold () |
| boolean | IsGridBySpacing (in short axis) |
| Return true if the grid is defined by spacing functions and not by node coordinates in given direction (X==0,...) More... | |
| void | SetGrid (in SMESH::double_array coords, in short axis) raises (SALOME::SALOME_Exception) |
| Set coordinates of nodes along an axis (countered from zero) More... | |
| SMESH::double_array | GetGrid (in short axis) raises (SALOME::SALOME_Exception) |
| void | SetGridSpacing (in SMESH::string_array spaceFunctions, in SMESH::double_array internalPoints, in short axis) raises (SALOME::SALOME_Exception) |
| Set grid spacing along an axis. More... | |
| void | GetGridSpacing (out SMESH::string_array spaceFunctions, out SMESH::double_array internalPoints, in short axis) raises (SALOME::SALOME_Exception) |
| void | SetAxesDirs (in SMESH::DirStruct x, in SMESH::DirStruct y, in SMESH::DirStruct z) raises (SALOME::SALOME_Exception) |
| Set custom direction of axes. More... | |
| void | GetAxesDirs (out SMESH::DirStruct x, out SMESH::DirStruct y, out SMESH::DirStruct z) |
| void | SetFixedPoint (in SMESH::PointStruct p, in boolean toUnset) |
| Set/unset a fixed point, at which a node will be created provided that grid is defined by spacing in all directions. More... | |
| boolean | GetFixedPoint (out SMESH::PointStruct p) |
| void | SetToAddEdges (in boolean toAdd) |
| Enable implementation of geometrical edges into the mesh. More... | |
| boolean | GetToAddEdges () |
| void | SetToConsiderInternalFaces (in boolean toTreat) |
| Enable treatment of geom faces, either shared by solids or internal. More... | |
| boolean | GetToConsiderInternalFaces () |
| void | SetToUseThresholdForInternalFaces (in boolean toUse) |
| Enable applying size threshold to grid cells cut by internal geom faces. More... | |
| boolean | GetToUseThresholdForInternalFaces () |
| void | SetToCreateFaces (in boolean toCreate) |
| Enable creation of mesh faces. More... | |
| boolean | GetToCreateFaces () |
| void | SetToUseQuanta (in boolean toUseQuanta) |
| boolean | GetToUseQuanta () |
| void | SetQuanta (in double quanta) raises (SALOME::SALOME_Exception) |
| double | GetQuanta () |
| void | ComputeOptimalAxesDirs (in GEOM::GEOM_Object shape, in boolean isOrthogonal, out SMESH::DirStruct x, out SMESH::DirStruct y, out SMESH::DirStruct z) raises (SALOME::SALOME_Exception) |
| Return axes at which a number of generated hexahedra is maximal. More... | |
| SMESH::double_array | ComputeCoordinates (in double x0, in double x1, in SMESH::string_array spaceFuns, in SMESH::double_array points, in string axisName) raises (SALOME::SALOME_Exception) |
| Compute node coordinates by spacing functions. More... | |
| string | GetName () |
| Get the Hypothesis typeName. More... | |
| string | GetLibName () |
| Get the Hypothesis plugin library Name. More... | |
| short | GetId () |
| Get the internal Id. More... | |
| void | SetVarParameter (in string parameter, in string method) |
| Set the variable parameter. More... | |
| string | GetVarParameter (in string methodName) |
| Return the variable parameter used for Hypothesis creation by name of method setting this parameter. More... | |
| void | SetHolderHypothesis (in SMESH::SMESH_Hypothesis hyp) |
| Store a hypothesis wrapping this not published one. More... | |
| boolean | IsDimSupported (in Dimension type) |
| Verify whether hypothesis supports given entity type. More... | |
| boolean | HasParameters () |
| Return true if a hypothesis has parameters. More... | |
This hypothesis specifies
| SMESH::double_array StdMeshers::StdMeshers_CartesianParameters3D::ComputeCoordinates | ( | in double | x0, |
| in double | x1, | ||
| in SMESH::string_array | spaceFuns, | ||
| in SMESH::double_array | points, | ||
| in string | axisName | ||
| raises | ( | SALOME::SALOME_Exception | |
| x0 | - lower coordinate |
| x1 | - upper coordinate |
| spaceFuns | - space functions |
| points | - internal points |
| axisName | - e.g. "X" |
| void StdMeshers::StdMeshers_CartesianParameters3D::ComputeOptimalAxesDirs | ( | in GEOM::GEOM_Object | shape, |
| in boolean | isOrthogonal, | ||
| out SMESH::DirStruct | x, | ||
| out SMESH::DirStruct | y, | ||
| out SMESH::DirStruct | z | ||
| void StdMeshers::StdMeshers_CartesianParameters3D::GetAxesDirs | ( | out SMESH::DirStruct | x, |
| boolean StdMeshers::StdMeshers_CartesianParameters3D::GetFixedPoint | ( | out SMESH::PointStruct | p | ) |
| SMESH::double_array StdMeshers::StdMeshers_CartesianParameters3D::GetGrid | ( | in short | axis | ) | |
| raises | ( | SALOME::SALOME_Exception | |||
| void StdMeshers::StdMeshers_CartesianParameters3D::GetGridSpacing | ( | out SMESH::string_array | spaceFunctions, |
| out SMESH::double_array | internalPoints, | ||
| in short | axis | ||
| double StdMeshers::StdMeshers_CartesianParameters3D::GetQuanta | ( | ) |
| double StdMeshers::StdMeshers_CartesianParameters3D::GetSizeThreshold | ( | ) |
| boolean StdMeshers::StdMeshers_CartesianParameters3D::GetToAddEdges | ( | ) |
| boolean StdMeshers::StdMeshers_CartesianParameters3D::GetToConsiderInternalFaces | ( | ) |
| boolean StdMeshers::StdMeshers_CartesianParameters3D::GetToCreateFaces | ( | ) |
| boolean StdMeshers::StdMeshers_CartesianParameters3D::GetToUseQuanta | ( | ) |
| boolean StdMeshers::StdMeshers_CartesianParameters3D::GetToUseThresholdForInternalFaces | ( | ) |
| boolean StdMeshers::StdMeshers_CartesianParameters3D::IsGridBySpacing | ( | in short | axis | ) |
| void StdMeshers::StdMeshers_CartesianParameters3D::SetAxesDirs | ( | in SMESH::DirStruct | x, |
| in SMESH::DirStruct | y, | ||
| in SMESH::DirStruct | z | ||
| void StdMeshers::StdMeshers_CartesianParameters3D::SetFixedPoint | ( | in SMESH::PointStruct | p, |
| in boolean | toUnset | ||
| void StdMeshers::StdMeshers_CartesianParameters3D::SetGrid | ( | in SMESH::double_array | coords, |
| void StdMeshers::StdMeshers_CartesianParameters3D::SetGridSpacing | ( | in SMESH::string_array | spaceFunctions, |
| in SMESH::double_array | internalPoints, | ||
| spaceFunctions | - functions defining spacing values at given point on axis |
| internalPoints | - points dividing a grid into parts along an axis |
| axis | - index of an axis counterd from zero, i.e. 0==X, 1==Y, 2==Z |
Parameter t of spaceFunction f(t) is a position [0,1] within bounding box of the shape to mesh or within an interval defined by internal points
| void StdMeshers::StdMeshers_CartesianParameters3D::SetQuanta | ( | in double | quanta | ) | |
| void StdMeshers::StdMeshers_CartesianParameters3D::SetSizeThreshold | ( | in double | threshold | ) | |
Set size threshold.
A polyhedral cell got by cutting an initial hexahedron by geometry boundary is considered small and is removed if it's size is threshold times less than the size of the initial hexahedron. threshold must be > 1.0
| void StdMeshers::StdMeshers_CartesianParameters3D::SetToAddEdges | ( | in boolean | toAdd | ) |
If this feature is disabled, sharp edges of the shape are lost ("smoothed") in the mesh if they don't coincide with the grid lines
| void StdMeshers::StdMeshers_CartesianParameters3D::SetToConsiderInternalFaces | ( | in boolean | toTreat | ) |
| void StdMeshers::StdMeshers_CartesianParameters3D::SetToCreateFaces | ( | in boolean | toCreate | ) |
| void StdMeshers::StdMeshers_CartesianParameters3D::SetToUseQuanta | ( | in boolean | toUseQuanta | ) |
| void StdMeshers::StdMeshers_CartesianParameters3D::SetToUseThresholdForInternalFaces | ( | in boolean | toUse | ) |
