StdMeshers::StdMeshers_ImportSource1D Interface Reference
interface of "Source edges" hypothesis. More...
Inheritance diagram for StdMeshers::StdMeshers_ImportSource1D:
void SetSourceEdges (in SMESH::ListOfGroups groups)
 Set edges to import from other mesh. More...
SMESH::string_array GetSourceEdges ()
void SetCopySourceMesh (in boolean toCopyMesh, in boolean toCopyGroups)
 Set to import the whole other mesh or not, and if yes, to copy groups of not. More...
void GetCopySourceMesh (out boolean toCopyMesh, out boolean toCopyGroups)
string GetName ()
string GetLibName ()
short GetId ()
 Get the internal Id. More...
boolean HasParameters ()
This hypothesis specifies groups of edges of other mesh to be imported in this mesh
◆ GetCopySourceMesh()
void StdMeshers::StdMeshers_ImportSource1D::GetCopySourceMesh ( out boolean  toCopyMesh,
◆ GetId()
◆ GetLibName()
◆ GetName()
◆ GetSourceEdges()
SMESH::string_array StdMeshers::StdMeshers_ImportSource1D::GetSourceEdges ( )
◆ GetVarParameter()
◆ HasParameters()
◆ IsDimSupported()
◆ SetCopySourceMesh()
void StdMeshers::StdMeshers_ImportSource1D::SetCopySourceMesh ( in boolean  toCopyMesh,
By default the mesh is not copied.
◆ SetHolderHypothesis()
◆ SetSourceEdges()
void StdMeshers::StdMeshers_ImportSource1D::SetSourceEdges ( in SMESH::ListOfGroups  groups)
◆ SetVarParameter()
in string  method
